BUILD DAY 24: 0.5 hours / Total 44 hours
Photo 252-254: Fore outer planking patterns now properly dried, aligned and glued perfectly in place. I followed the recommendation in the instructions: applying diluted white glue on the hull.
Current :
HMS Sphinx by Vanguard
Completed:
Orient Express Sleeping Car by Amati
Bluenose II (Artesania Latina)
Istanbul Tram - Occre
Bluenose II - Artesania Latina
Bosphorus Sandal Fishing Boat
Riva Aquarama - Amati
Titanic - Mantua
Bosphorus Fishing Boat - Tersane Model
San Juan Nepomuceno - Artesania Latina
Bluenose - Billing Boats
BUILD DAY 25: 1 hour / Total 45 hours
Photo 255-258
Aft Outer Planking Patterns (271, 273),
Front lower Outer Planking Patterns (305, 307),
Rear lower Outer Planking Patterns (306, 308)
are also now glued in place, after soaking and bending where necessary.
Current :
Completed:
Titanic - Mantua
BUILD DAY 26: 1 hour / Total 46 hours
Photo 259: Continued planking with two rows of pre-cut pear planks and one row of pear strips.
Current :
Completed:
Titanic - Mantua
BUILD DAYS 27-30: 14hrs / Total 60 hours
Photo 260: 2nd planking is finished. Now the hull is ready for preparing to remove the jigs and its parts before sanding.
I used UHU Hart glue and spots of super glue for securing quickly at the ends.
Current :
Completed:
Titanic - Mantua
Build Day 30: 1,5 hr / Total 61,5 hours
Photos 261-262
Removing jigs and nubs which are not needed anymore.
Hull is now ready for sanding. Engravings covered with masking tape to prevent accidental sanding.
By the way this brings me to step 185 in the instructions.
Edited by aydingocer
Current :
Completed:
Titanic - Mantua
Photos 263-266: Preparing to smoothen below the waterline. I used diluted Liberon Natural Wood Filler applied with a brush. This is now the first round, waiting for the filler to dry before fine sanding. Waterline marker is from Hobbyzone.
Current :
Completed:
Titanic - Mantua
Build Day 31: 1hr / Total 62 hours
After sanding, one layer of wood filling looks good enough to me. I prefer the wood plank patterns exposing a little under the paint than having a perfectly smooth painted hull. To me it gives a more handmade look than ready made hull. It is a question of taste.
Photos 267-269: Main whale patterns soaked in hot water for 30mins and pinned temporarily in place to dry and get the shape. These are thicker than the parts we did the same procedure earlier (1mm vs 0.8mm) therefore 30 mins is the minimum you should keep them in water. It was enough to soak only the front section where it will bend. Now it will rest at least 24 hours.
Current :
Completed:
Titanic - Mantua
Build day 32: 2.5hrs / Total 63.5 hours
Photos 270-271: Main Whale patterns dried nicely to shape. Now it is time to glue them and strakes above them in place.
Current :
Completed:
Titanic - Mantua
Photos 272-273: Stern counter (inner) and Sten facia (inner). Yes, there is a visible gap but it will be hidden later after outer patterns and with trim strip.
Current :
Completed:
Titanic - Mantua
Photos 274-276: Quarter gallery patterns bevelled as instructed and glued. First photo showing an example of before and after bevelling.
Used another piece as spacer while the glue dries.
Current :
Completed:
Titanic - Mantua
Photos 277-278: Masking and painting with airbrush.
Current :
Completed:
Titanic - Mantua
Photo 279: Cleaning the airbrush is crucial after each paint job :)
Current :
Completed:
Titanic - Mantua
Photo 280: Preparing the next parts while the paint is drying. Now coffee time!
Current :
Completed:
Titanic - Mantua
Photo 281: Paint dried, masking tapes removed. Looking good enough.
Current :
Completed:
Titanic - Mantua
Build day 33: 3.5hrs / Total 67 hours
Photo 282: Stern upper counter pattern (outer) and Stern fascia (outer)
Current :
Completed:
Titanic - Mantua
Several photos showing the progress of Quarter Gallery windows installation. Here there is quite a bit of rasping and bevelling of the parts. It mostly went smoothly but at some parts I used wood filler to achieve smooth transition. At this stage sanding is not complete yet. Most of this section will remain under paint and decoration.
Photo 283: Bevelling of the roof part.
Photos 284-285: Windows on both sides.
Photo 286: Lower finishing patterns, made up of three parts, dry fitted. This will substantial amount of rasping and sanding to get to shape.
Photo 287: Looks about like this after shaping
Photos 288-290: Wood fillers to cover impurities. I will sand them more later.
Current :
Completed:
Titanic - Mantua
Photo 291: A waterline can be painted in any color, as long as it is black 😆.
Well, I thought over this a lot and finally chose black instead of white. As I wrote earlier I like slightly visible planking patterns rather than a completely smooth surface, as it gives a more hand made like look. In my opinion black would suit better than white in this case. I am happy with the result.
Current :
Completed:
Titanic - Mantua
Build day 34: 2hrs / Total 69 hours
Today I spent roughly 2 hours on preparing rail patterns. These are among the most delicate and fragile parts.
Photos 292-293: Sheer and Waist Rail patterns, removed, soaked (for 20 mins) and pegged on location, waiting to dry for at least 24 hours. As instructed, I used scrap planking strips to apply even pressure and prevent from being damaged.
Current :
Completed:
Titanic - Mantua
While they are drying, I prepare the other ones (that need no prior bending). I used my Dspiae sanding stick to remove laser char as good as I can, focusing mainly on more visible areas. I also use clamps to help strengthen against sanding stick strokes.
Photo 294: Parts carefully removed from the wooden sheet.
Photo 295: Here is a comparison, chars removed vs not removed.
Photos 296-297: Use of clamps and sanding stick.
Current :
Completed:
Titanic - Mantua
Build day 35: 4hrs / Total 73 hours
Today I spent about 4 hours on
- masking and aligning the rails,
- varnishing the hull,
- painting,
- gluing the rails.
Photo 298: Sliced approx. 2mm wide strips from my masking tape for covering the areas where the rails will sit, to prevent from varnish.
Current :
Completed:
Titanic - Mantua
Photos 299-300: Rail patterns masked, ready for varnish. I applied acrylic matte white Admiraly varnish from Caldercraft using brush.
Current :
Completed:
Titanic - Mantua
Photo 301: Painted in Vallejo Prussian Blue and Vallejo Air Color Red. The blank areas in the middle will be covered by rail patterns.
Current :
Completed:
Titanic - Mantua
Photo 302: Started gluing the rail patterns.
Current :
Completed:
Titanic - Mantua
Gluing the rail patterns is complete.
Photos 303-305: At one part you need to remove part of the upper wale so the fender will sit into it.
Current :
Completed:
Titanic - Mantua
Build day 36: 3hrs / Total 76 hours
Today I spent about 3 hours on
- Side Fender Patterns and Chess Tree Patterns,
- rudder (still in progress)
Photos 306-307: Removed the Side Fender Patterns (2 for each side) and Chess Tree Patterns from the sheet and glued in place. I didn't check ahead if the sides will be hidden or not later but I still removed laser char from the sides.
Current :
Completed:
Titanic - Mantua
Rudder construction.
Photo 308: Removed 3 rudder pieces. The central piece is thicker, while the two outer pieces with engraved patterns are thinner.
Photo 309: Glued together carefully ensuring that the pinholes align.
Photo 310: First photo ethced work of this construction. Very delicate parts. We need PE-31 to P-35 for rudder.
Current :
Completed:
Titanic - Mantua
Photo 311: Also removed the Rudder and Gudgeon Pintle Patterns. I had to check from the manual several times to spell this part name correctly :)
Photo 312: Parts ready for assembly.
Current :
Completed:
Titanic - Mantua
Photo 313: Need to shorten the nails (to around 2mm) to insert them from both sides. Instructions say we will need the cut-off pieces later so I keep them.
Current :
Completed:
Titanic - Mantua
Photos 314-317 : Photos showing the progress.
Current :
Completed:
Titanic - Mantua
Build day 37: 2hrs / Total 78 hours
Rudder ready and installed in place. Also glued the horseshoe and fishplates in their places. I don't have a copper color so I chose a Vallejo Old Gold which was available in my paint box. It is a bit more on the red spectrum and looks good enough for copper on small surfaces such as these ones.
Photos 318-319: Rudder, fishplate and horseshoe
IMG_0369.thumb.jpeg.1cfc972963ae858588282852bb385a85.jpegIMG_0359.jpeg.a1d8240241fd0de4c3a7cc2be7257550.jpeg
Current :
Completed:
Titanic - Mantua
