The only reference to when a boat was double banked versus single banked that I have been able to find so far is on page 219 in Lavery's The Arming and Fitting of English Ships of War where he writes that "in 1783 it was ordered that all launches should be equipped to row double banked."  Looking at the boat scantlings for launches circa 1800 in May's The Boats of Men of War, the smallest launch that he shows has a length of 24 feet and a breadth of 7 feet 10 inches.  OK, that seems like a lot of room to be double banked.
My quandry is whether there was a minimum breadth required for any type of boat to be double banked.  Lacking other information one could make the argument that any boat that had a breadth of 7' 10" or more would/could be double banked, but that kind of assumption is probably a bad idea.   Was there a rule that stated a minimum breadth for any boat that would be double banked or single banked?  Mays has a photo of a contemporary model of a 37 foot barge that has a breadth of 7 feet that is single banked.  On the same page he shows a contemporary plan of a 32 foot barge (no breadth given)  that is double banked, adding to my confusion.  I would appreciate any information.  Thanks
Allan
If you look at the mechanics of a lever, I believe that the single/double bank issue is like gearing in a car.  Boats intended to travel at high speeds benefited from two oars per thwart.  On the other hand, heavy workboats like longboats and launches benefited from the added leverage gained by one oarsman per thwart using the breadth of the boat to gain leverage.  At least that’s how I arranged thole pins in my Longboat model.
I also see no reason why these boats could not have been converted back and forth from single to double banked and vice versa as needed as thole pins could be added or removed from holes in the gunwales.
In researching these boats carried aboard warships IMHO there are many details that we know little about.
Roger
Your reasoning makes a lot of sense Roger.  There is indeed very little outside of the Lavery and May books.  At least there are reasonably close scantlings and details that would help anyone building a ship's boat for the ship model with hand tools.     There are also a lot of contemporary drawings that show the diversity even within a given time period.
Allan
Eric McKee in his 'Working Boats of Britain' looked a bit into the mechanics/ergonomics of rowing and I think gives some dimensions, if I remember correctly, for spacing thwarts, inboard vs. outboard lengths of oars etc. Rowing efficiency, both from the purely physical perspective as well as from the physiological perspective is quite complex. While in the 18th/19th century, of course, there were no scientific studies on this, people had a lot of experience.
I gather there are in principle x different rowing arrangements in ships' boats:
- one man per thwart with two oars (in small boats only)
- one man per thwart with one oar (single bank)
- two men per thwart with one oar each (double bank)
- four men per thwart with two men per oar (in large boats only)
You will need an inboard length of the oar of around 3 feet minimum to give a reasonable fulcrum, whereby one hand is placed on the handle and the other more or less at shoulder width further towards the thole pins. This means that you would need a minimum of around 6 to 7 feet for a double banked boat, while a single-banked one could be as narrow as about 4 feet, with the men off-set to each side of the boat.
Faster, lighter boats could have proportionally longer oars with wider space between the thwarts to allow for longer strokes, propelling the boat faster, while heavy working boats would have closer spaced thwarts with shorter oars, as here you need the 'torque' of the oars at slower speed.
Thanks Eberhard.   As with so many things in those days, there is a lot of diversity.  Understandable with many yards building boats, but there were contracts with scantlings that help to some extent.  The following is one example of a contract transcribed (with notes)  from the original at the National Archives in Kew by  Mark Porter.
A point to note with dating is that in contracts it was often written as 7ber, 8ber, 9ber & 10ber
Contracted the 9th of 7ber [September ] 90 with the Honoble Tho[mas] Willshaw, Esqre one of the Principall Officers  & Commrs of their  Majties Navy, for and behalf of their Maties, by me  Tho[mas] Oxford of Gosport Shipwright and I  doe hereby oblige my self to deliver into their Majties Stores at Portsmouth, by ye end of 8ber [October] next ensueing the  Pinnace and Yawle undermentioned  of the Dimensions and Scantlings folling  (viz)
                           Long              Broad            Deep
Pinnace   of         30ft:   -----      6ft:  ------     2ft: 7ins   -------
Depth of the Keel: 5 ins  breadth 4 ins, Scantlings of the timbers 1 ½ ins Roome and space 13 ins,   depth of the Gunwales up & down 4½: ins  in and out 2 ins & 1½ in, Scarph of ye Timber 18 ins, breadth of ye Stem thwartships 3½ ins fore and aft 7 ins, Stern post 3ins, Rising 4½  in, footwales 4½ ins and one inch in and out, Keelson 8 ins X 1½  in thick, to be fitted with 12 Iron Knees 5 bound thwarts wth Iron Knees & two Transom Knees, with gang boards) and Scarr boards [Wash boards?], benches three  lynings, Grounds  & mouldings, plankshires turn[e]d off,  back board one,  bottome boards two, Keel band 22 ft Ring bolts two,  Rother iron two paire, Rother one  once primed at the Rate of fourteen shillings per foot.
Yawle of        Long                            Broad                     Deep
                                                          ft                             ft
                    23 ft                               5   7 ins                  2    5 ins                  One
Railes for the upper strake to be made out of ye whole wood up & down Gunwales stuck,
3 thwarts bound with Iron knees, & ye transoms with two Iron knees.
The State Room (stern sheets, or officers’ seating area) stuck (presumably meaning ‘struck’) with an O:G. & plansheer for the Gunnwales with pannels on each side the back board, a locker under the after bench & lynings under the benches,  keel thwart shipps 4 ins up and downe, 4 ½ ins X 4 ins  Keelson 6 ins broad of 1 ½ ins planck timbers of 1 ½ ins with 13 ins roome and space and 18 ins Scarph, the flower [floor] timber heads to Naile to ye lower edge of ye binding strake, with bottom boards, & shear boards, Keelbands and Iron bolts and Rings for stem and stern, to row with six Oars to be graved and primed to the water line and paid with stuff in the inside to ye Riseing att 12s per foot
Edited by allanyed
G'day Allan,
So if this is 1690 (Thomas Wilshaw fits with that) and we have 23ft boats being fitted with "iron knees" doesn't that open up a new can of worms? How common were iron knees? Does it perhaps mean that the RMG boat drawings not specifically showing wooden knees had iron knees? 'shudder' too much to think about.
EDIT, I just looked up Mays Boats of Men of War and the scantlings table ca1800 gives iron knees for Barges, Pinnaces, Yawls and Wherrys. I don't see anything for earlier but the contracts show that it might have been true for a long time.
Edited by iMustBeCrazy
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
For double banked barges and pinnaces the instructions for embarkation given in "Aide Memoire to the Military Sciences" are:
Quote
If there is any motion, care must be taken not to overload the boats, for fear of
their swamping; there will therefore be room for the crew to pull . As many of the
troops as possible must be made to sit down in the boats: in a barge or pinnace one soldier between each rower and the rowlock, before the oar, looking aft, and one abaft each oar, with his back to the gunwale,
In launches or larger boats there will be room for men to sit or stand in the centre of the boat between the two lines of rowers, in addition to those marked for barges , &c. The head and stern sheets of old boats to be packed as close as possible consistent with safety.
If the water is perfectly smooth , the boats may be laden much deeper, the men standing as close as possible together ; but in this case they must be towed , for two reasons : 1st , the crew have no room to pull ; 2nd , when boats are very deep, the men cannot get the blades of the oars out of the water so as to pull with effect.
It must, however, be remembered that it is slow work towing a heavy boat by a light one ; load , therefore, the boats employed in towing as deeply as you can without inconveniencing the rowers.
Boats employed in landing troops are to have neither guns , masts , nor sails; their equipment to be - gang -boards, oars, grapnels and painters, boat - hooks , bailers , hammers and nails , sheet -lead, grease , and canvas ; the latter articles are to enable them to stop a small shot-hole in case of accident.
Edited by Lieste
  • 2 years later...
Perhaps the banks without tholes are meant to seat marines during landing operations?
In principle yes and it was also my first thought, but I think the images above show actually relatively wide double-banked boats.
Yes Druxey, one can see that you are right:  sailor on thwart a operates oar in thole 1 and so forth. Considering the moulded breadth  of 6 feet, 4 inches (= approx. 190 cm) offers a  powerful lever arm for the rower sitting on the opposite hull side of the  dedicated thole.
Joachim
Like so:  https://preview.redd.it/whats-the-point-of-bucket-rigs-and-why-does-bucket-rigging-v0-odtwdx3gsi9a1.jpg?width=1080&crop=smart&auto=webp&s=d447a1c12b029eee1b31ae9a39ed0306fef1a42f
2 hours ago, Fritzlindsay said:
there are a lot of plans that do not show the offset tholes in the overhead view
The problem is a lack of standards. There were no drafting text books so it was a case of doing as you were taught.
Some drawings such as the one above may, for example, depict a half hull model while others the whole boat.
When depicting the whole boat, sometimes objects the far side of the centreline are drawn dashed, sometimes solid.
Sometimes extra details are depicted on the half breadth, sometimes not.
Ultimately these drawings are not the engineering drawings of today, they are general guides backed up by scantling details and contracts which we rarely see.
which might be the reason some kits get it wrong
Or the might be right, but I don't think so.
Craig.
This is what I can come up with for pinnaces:
Craig.
Thank you bringing up this topic again, as I am at the moment working on that.
After working on the sweeps and oars, the question was arising, as the oars prooved too long for double banked use. This thread nicely shows the solution as mostely single banked were used was for the "slimmer" boats. Nicely to be seen for my 1800 subject in the 1765 model of victory.
I have the feeling too, that for single banked use oars with a curved blade were used, while for double banked use sweeps with a straight blade were preferred. At least the choice of RMG suggests this.
Some more hints from the RMG, sorry I did loose the reference numbers on those ones.
alternating single banked with oars
e9006_09.jpg.92c1cda8c5196c551fdf22296f8484b4.jpgd4049.jpg.58ec3ecfbce69b42e0abde5514fd9527.jpg
f7834_001.jpg.f50e29144b78fb91ad0c277c32a6dab5.jpgf8843_001.jpg.21c08ccceb3a6b7fa23d3b806595d832.jpgf9246_001.jpg.d3e534e546f1967449ef682e6aaf869c.jpg
double banked with sweeps:
f3875_5.jpg.236c8a0176b61ae78a03e3e2a5467d26.jpgl2421_001.jpg.4573608f9ca350828cc3b35c5eab9b1e.jpgf8913_001.jpg.407d7022897d41d59cefa41a295ef8bd.jpg
Special both versions?
perhaps single bancked for 4 oars or alternatively 2 pairs of sculls?
l2288_001.jpg.ea281e4fdc1aef555aef50e038bdc800.jpgl2288_002.jpg.326f99f6316759ef8a9271cb73e0a644.jpg
Edited by dafi
I came across this pic of Police on the Thames which opens a new can of worms:
Craig.
On 2/11/2025 at 6:12 PM, Fritzlindsay said:
Thanks, it appears there is agreement that pinnaces were single banked and the pinnaces that show some thwarts with no tholes are incorrect.  An example is below.
Wonderful, once I saw this info I already found plenty of otherwise very true models showing this "feature" 🙂
But I would expect an even number of twarts for single banked, but there is quite often an uneven number. Does this mean the lesser side had to pull harder or was there one thole left free?
Also there seems no rule as to what side of the boat has the most foreward thole.
XXXDAn
Edited by dafi
5 hours ago, druxey said:
Looks like a highly posed photo! Look also at the blade angles....
Certainly, but the boat is fitted with as a hybrid rowing system.
4 hours ago, dafi said:
But I would expect an even number of twarts for single bancked, but there is quite often an uneven number. Does this mean the lesser side had to pull harder or was there one thole left free?
I suspect it was something like preventing resentment of the rest of the crew if the bowman was carried around like an Admiral. ¯\_(ツ)_/¯
Anyway, I thought trying to nail down terminology might be worthwhile. I think this is how it goes:
Starting with OAR, basically every paddle worked against a fulcrum (THOLE)  is an oar.
Oars are broken down into two types, SCULLS and OARS. (there is also SWEEPS which are 'larger OARS' used on ships or boats).
SCULLS are operated by one man SCULLING with one oar over the transom or one or more men operating two oars each on the one thwart (also called SCULLING).
OARS are operated over the sides of the boat by one or more men per OAR. They can be single (one oar per thwart) or double banked (two oars per thwart), single banked would tend to use SWEEPS
Operating a boat with one or more men per OAR, with the oars over the sides, is known as ROWING.
To add to the confusion, an OAR operated over the transom could be called a SCULL if used for propulsion or a SWEEP if used for steering. And SCULLS and OARS were also the two types of "water taxis" used on the Thames.
Maybe.
Craig.
As my quest started with the design of the oars, I was coming from the other direction, but leading my straight to the heart of this topic.
Having created oars and sweeps respecting Steel´s data, I was putting them to the test on some of my boats.
This lead first to the confimation of the knowledge, that my kit´s versions of boats are not really suitible for the job. Apart from missing all structure and details they also had the thwarts far too high. After reworking the 32 ft pinnace by using only the shell and reconstructing a more true interior it was getting nearer to the real thing.
Now I was able to put some crewmen and oars. As a good landlubber I placed immediately two of each on each thwart as suggested by the tholes.
But here began my surprise. As Steel indicated: "A leather button is nailed on the foreside, about two inches from the loom, and that edge rounded, to work easily in the rowlock: ..." This lead to the fact, that the oars were far too much in for a double banked use. Basically a crewman should be sitting on the opposite side to be able to grab the handle of his oar, thus crossing the other one.
The other fact that can be seen is that in this configuration the crewmen sit far too much on the outside of the boat, resulting in a ridiculus lever for rowing, as already mentioned by Roger in #2. So even if the leather buttom was ignored and the oar taken more out, it would have been a problematic setup.
This resulted in the only realistic setup with single banked use and everything looked much more logical.
The lengths of the oars fit, the leather button on the right place and a realistic lever for rowing.
On the other side I also tried a more broad launch.
For these Steel indicated straight sweeps without leather buttom.
[note: This is still the original kit´s version, but I think it will do the job this time.]
Here we have the space for double banked use. The sweeps do not collide in the middle and the crewmen have enough distance to the rowlock to get a workable lever. This confirmes Allans original quote of Lavery's The Arming and Fitting of English Ships of War where he writes that "in 1783 it was ordered that all launches should be equipped to row double banked."
And so I am thankful for the topic here, as it was filling the gaps of my puzzle and giving the right contemporary sources to finish it off. This means with my single banked 32ft pinnace from the first pictures I will fill every second thole, alternating on each side. Also the originally intended number supplied of oars (as for double banked and seen in the first pict) for this boat can be halved.
Another question concernes the uneven number of oars on each side, in my 32ft pinnace 4 versus 3. Was this in use as for the uneven propulsion or was the bow place then left free? On the other side in the models of RMG there are many boats with a uneven number of tholes regarding the boat´s sides.
As someone once called it "experimental archeology in miniature" 😉
I hope it supports or even confirms all the informations to be found in the previous posts.
XXXDAn
PS: Had a fast Photoshop and eliminated the supernumerary tholes.
This gives a nice detail in between single and double banked boats even in stowed position. 🙂
Edited by dafi
Steels tables break down in to SWEEPS, OARS and SCULLS:
As you can see from the inboard length compared to the breadth he hasn't included oars for double banked boats. The sculls would fit but they are for one rower with two oars.
Double banked oars should (I think) have 10" handles, a total inboard length of under half the breadth and be shorter than single banked oars.
NOTE: The button is 2" down the body so has been added to inboard and subtracted from outboard. The rows in red don't add up to the sweep.
Craig.
