HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
3 hours ago, Dr PR said:
7 in 36 = 11 degrees
7.5 in 36 = 11.8 degrees
That's better than my measurements from the small illustrations in the books.
Phil,
I am guessing these rake measurements are for the Prince? They don't apply to other 1812 built schooners, do they?
Mark,
I have no way to know if any other schooner did or did not have the same mast rake as the Prince.
As I said earlier, I examined plans and drawings for 17 Baltimore clippers and found the mast rakes to be:
Fore mast - 11.5 degrees average, with a range of 7-16 degrees
Main mast - 13.75 degree average, with a range of 8-22 degrees
So it is certainly possible that other schooners could have had the same rake as the Prince. The angles are close to the average for this type of vessel.
Phil
Current build: USS Cape MSI-2
Thank you, Phil,
Barring any other source of contradicting information, I will be adopting these measurements for my Lynx build. I truly appreciate your input, sir.
Salty,
Chapelle has a good description of the Lynx in The Search For Speed Under Sail (pages 215-218). There is a full page plan drawing on page 217, and a full page sail plan on page 219. He says the vessel did not have an extreme sail plan.
From the drawing I estimate that the rake of the fore mast was 11.5 degrees and the main mast is 13.5 degrees, both relative to the water line.
Phil
Once again, I appreciate your help Phil. I have a few books on the 1812 era vessels that should be arriving today (see image below). The one you mention above is not among them, I will have to go and look for that one. I know for sure that the Lynx will not be my last Baltimore Clipper/Schooner build. I love these boats!
@coyote_6, Sorry we are taking up your blog with this discussion sir :)
Steve,
I guess we have gotten off track here. But for all Baltimore Clipper and topsail schooner fans, I should advise getting Chapelle's The Baltimore Clipper. It may well be the definitive book on the subject.
And now we return to the scheduled programming ....
Phil
@Dr PR  Like they say - "Godfather of Schooner Rigging".
Sorry Phil, I can't resist!  But bro, your knowledge on these subjects is stellar and I am so glad you are here to share.
@SaltyScot  Mark, for me I learned early on that kit plans are not the end all be all of what a ship was or should be (especially Constructo's plans). I treasure the shipbuilding library I have been assembling, and many informative books can be had used on amazon or Abe's for a pittance.  The Search for Speed Under Sail Phil references above is a great resource to check out for yourself.  The Lynx is just an amazing subject - I would recommend running down some old resources on your own to get a feel for here design/history - it is one of my favorite parts of this build to date.  Kind of like a nautical Indiana Jones experience.  Chapelle's books (and a sharp eye at my modeling guild meeting) saved me from Constructo's bow sprit disaster after all.
As an aside, the paper and inks used to print books in the 50s to 70s is a treat to touch compared to some modern books.
Recommendations include:
Generally anything by Chapelle on the topic of sailing vessels.
Ashley's Book of Knots (particularly the chapter on Marlinspike Seamanship).
Ship Model Builder's Assistant by Davis.
The Global Schooner by Marquardt (hat tip to @Dr PR for the recommendation)
Steve
San Diego Ship Modelers Guild
No problem from my end gents.  I love the discussion.
But I guess now I'll have to actually get something done on the Prince so we can get back to our regularly scheduled program.
Baltimore Clippers/Schooners are an addiction methinks.
Edited by Coyote_6
Steve
(and note I was typing book recommendations WHILE you guys were discussing book recommendations so I think we're all on the same track here!!)
Steve
Gentlemen, I have started a thread here about the books we have been discussing and my answers to your most recent posts. That way, Steve can get back to his blog :)
I seem to recall reading that individual captains could alter the rake of the masts in order to get the best performance from the vessel--basically by altering where the center of force of the sail was located. Is that something that could be done at sea or would it need to be done in port? If so... doesn't that mean that the rake could vary during the life of the vessel?
Interesting question. I have heard that also, but have never seen a reference.
I have always thought that the foot of the mast rested in a fixed mast step, so that end couldn't move without removing the mast and rebuilding the step.
There is some space around the mast at the "partners" - where the mast passes through the main deck. This space is filled with wedges to fix the mast in place. I suppose by using thick and thin wedges properly spaced around the opening the angle of the mast could be varied a bit, both fore and aft (rake) and side to side. I can see where this might change the angle of the rake by a degree or two. Again, I think this would have to be done in port. All of the stays and shrouds would have to be loosened and adjusted, and you wouldn't want that to happen at sea!
Phil
Learning the ropes so to speak.  Finished all the carronade breaching lines.
Working on my first gun train tackles, I am truly questioning the sanity of people who build model ships.  0.125" blocks??
Pencil for reference...
But we persevered.  My first ever gun train tackle!
And then the second.
Now trying to coil the ropes, Olha Batchvarov style.  She does hers off the ship.  My work is not that precise, to say the least.  Waiting on the glue to dry.  (Story of my life...)
Closeup for details:
All comments, tips and constructive criticism welcome!
Edited by Coyote_6
Steve
Coils dried so now they are glued to the deck.  One down, 17 to go!
:pirate41:
Steve
I like the way you coiled those ropes, I was thinking how I could do that on the Endeavour's deck and make it look neat, now I know how :) Don't beat yourself up mate, this is some fantastic work!
@Dr PR  Hey Phil!  Yeah, the hooks are homemade.  K&S brass 8159 0.020" diameter.  Used a Beadsmith round nose pliers.  I want to get a different round nose to make smaller hooks.
Got any tips for me?
Here's a couple prototype hooks.  I am getting better at it.  Forming.  Knowing where to cut and pinch.
Steve
@vossiewulf That is awesome!!  Thank you!
Steve
I use chain nose pliers (round node pliers) to start the loop and hook, and then to finish to a desired size I use ordinary needle nose pliers to tighten them around the shank of an appropriate size drill bit clamped into a vise. I do the same to make eye bolts and such. While holding the loop closed with the pliers I give the wire a tug to make a sharp bend at the loop where the shaft of the eye bolt or hook leads away from the loop.
I do recall seeing someone with several chain nose pliers of different tip diameter to make different sized loops.
I use K&S brass rod instead of ordinary brass or copper wire. The rod is hardened and much stiffer. It makes sturdier hooks and eye bolts. A friend who makes model railroad scenery kits showed me how to straighten and harden ordinary brass wire by clamping one end in a vise and giving the other end a hard jerk. It works, but I still prefer the brass rod. I think I have seen someone using piano wire, but it is very hard and stiff, and harder to work than the brass rod.
I finish the loop by soldering - I originally left the loop end unsoldered, but really fine rope and thread sometimes managed to slip through the gap (with Murphy's help). I use a citrus based liquid flux (I like the orange smell), placing a small drop at the wire end. I have a soldering iron with a small tip. I place a small drop of solder on the tip and touch it to the joint. The liquid flux draws the solder into the joint.
Sometimes I have too much flux or solder and the solder flows into the loop on the hook. I do have some woven copper solder remover - or you can use ordinary multistrand wire - to remove the excess solder. But I usually just clean the soldering iron tip (on a wet sponge) and then put the tip into the loop and draw the solder back down the shaft of eye bolts. For hooks I use a small diameter drill bit to drill out the solder from the loop.
After the soldering and shaping is done I use Birchwood Casey Brass Black to blacken the hooks and eye bolts.
Hooks.jpg.9044c61ca93db5080bc86e9c6c2e6df0.jpgHere are some of my home-made hooks on the right, and Syren 4 mm plastic hooks on the left. My metal hooks are stronger, but I have not mastered the technique enough to get consistent hook sizes.
For more consistent results I think I need to make jigs of several sizes that the hooks can be wrapped around.
I also haven't worked out a way to get the mousing tip on the hook. Steve seems to have figured that out. I'll have to practice a bit more.
On real hooks the mousing end is tapered to a point, but I think that is a bit more detail than I want to attempt on these tiny hooks.
Phil
@Dr PR  Beautiful hooks Phil.  Look pretty consistant to me!  I definitely think brass is the way to go - I hope Murphy doesn't catch on to my unsoldered eyes!!
Also I am running out of eyepins and see manufacturing those going forward as well.  I like the performance of the solid brass in these applications.
Edited by Coyote_6
Steve
That feeling when you don't actually know what the metal is (non-magnetic) but the gun blue blackens it nicely - and then you realize you may be confronted with no anchors and a pile of black dust tomorrow!
Steve
A while back someone (don't remember who know) posted pictures of metal anchors from an old model kit that had started crumbling into dust.
I hate it when that happens!
If your anchors survived the toxic and corrosive bluing process they will probably stay intact for quite a while. But maybe you should handle them with gloves. Gun bluing contains some pretty nasty heavy metals.
Edited by Dr PR
Phil
@Dr PR I think I saw the same post - that's what got me thinking.
Initially I was swabbing on the blue but in the end dipped them with a stainless forceps.  I will take due care sir!
Hopefully the anchors survive - they look good right now. :dancetl6:
Steve
And it took me a month but coiled the last of my carronade gun tackles today.
On to chase guns and anchors.
Edited by Coyote_6
Steve
Well worth the effort. The ship is looking very good.
Under construction: Mamoli Roter Lowe
Completed builds: Constructo Enterprise, AL Le Renard
Up next: Panart Lynx, MS Harriet Lane
In need of attention: 14-foot Pintail in the driveway
1 hour ago, Chuck Seiler said:
Those rope seizings look really good.
Thanks Chuck!  Means a lot coming from you sir!  I used some nylon fly tying line.  I pretended I was done with breeching lines but I need to do two more for her chase guns.
Steve
Let's certainly hope not, Steve! Right now they look very nice.
