In an effort to maintain my last unbroken New Years resolution (finish all started projects). I completed an experiment with the 1/700 Hobby Boss HMS Astute. I have a few submarine models and it always puzzles me to find a good way to display them. I have also been impressed by modellers who have encased their finished project in resin. I wanted to try it but had no real idea about how to build a casting tank, the right resin, release agents, does the curing heat damage the model or the decals etc. So this is less about building Astute and more about trying to set in an epoxy sea.
The Hobby Boss kit has few parts and the submarine has a simple black paint scheme. The decals are a bit of a challenge with lots of long thing bands to place on the hull
The casting tank is made of 1/8 Perspex and held together and sealed with hot glue (first mistake). I sprayed the inside of the tank with Future polish as a release agent
The plan was to present the model on the surface so the craft sticks, double sided tape and Lego bricks set the sub at the right depth in the tank
The project was going to sit on the brand new dryer while the resin cured. It seemed a good idea to put the tank in an extra container - just in case.
There was a bit more resin than I expected in the first pour but I put it all in and was not terribly happy to find that the tank had a leak on one of the sides. - but I was thrilled that I had decided to use an extra container and I decided to carry on.
Then winter hit Florida for a week and I didn't want to try the second pour in case it didn't cure properly. I resumed with a different brand of resin and made three further pours to get the depth I wanted. They all cured nicely
The leaked resin peeled off the bottom of the casting easily
The sides of the tank released with a bit of force and the basic casting seems to be successful with a couple of caveats.
The long delay between first and second pours resulted in a definite interface between the two pours. Also the second resin has a slight tan cast to it. I had planned to try to colour the resin but couldn't think of a way to get a consistent colour. It belatedly occurs to me that I should have coloured one part of the two part mix which would then be used in all the pours.
There are small bubbles - I'm not sure how to improve that
I added some waves and wakes with artists gloss medium but it wasn't very visible against the clear resin so I added some medium with micro balloons added. I think it was a bit too much and its stark against the clear resin
So i added a sea blue base which has got closer to the effect I wanted
Far from perfect but it answered some basic questions for me and I'm happy with a first attempt. I have a part built 1/700 USS Gato for the next part of the project - full immersion.
I have a couple of Flyhawk U boats that I would like to make up into a single display with one surfaced and one submerged. They are much too nice to pour resin over until I know what I'm doing,
Thanks for looking in.
Alan
Thats a  toough  job  to  pull  off  Alan   as  i  know  it  falls  to  the  security  of  the  case  (as I  read  in other  resin  ship/sub dio's)    as  you  know   I have my  Flyhawk  Hood  on hold  that  I plan to  make  her  in the sinking role dio.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Alan, that came out really well!  I've always wondered how to do the resin pour approach like you did, so thank you for posting the process.  I have a couple of models in mind for a similar approach.  I forget exactly, but from others online, I think the bubbles might be caused by too fast a pour, or it might be from the heat as the resin dries.  In any case, adding a little color to the resin might minimize their appearance, if not look more natural.
Great job!
OC.
I think your Hood diorama will be great. It's worth practicing with your chosen resin before committing to the main task. I found a half inch layer cured no problem. A few stray bubbles aren't going to be an issue with all the mayhem of the sinking.
Alan
Great job!
Thank you Mike
I plan to try colour in the next attempt. I also probably stirred the mix too fast. It's a bit scary committing your finished model to the resin but for some displays it's a great look. I have a handful of 1/700 submarines that I want to use this technique for
Alan
