Whilst playing around with a shroud pair to see how it looked/worked out, I noticed a several problems with the mizzen top. The main issue: how will someone get onto the top from underneath? There are no futtock shrouds, because the top mast has no shrouds according to the rigging drawing. Do I remove the planking and leave the crosstrees? Or cut an access hole through the planking? Or something else?
There is no detail for this in the plans. I haven't been able to find a reference in Underhill's "Masting & Rigging. Doesn't mean it isn't there, I may have missed it. Suggestions are most welcome.
Regards,
Grant.
First suggestion: Make the title of your post something other than "oops" -- you'll be far more likely to get an answer to your question. I fixed this one for you -- no charge! 😉
Hi Grant
What ship, year, nationality?
By the way, Luigi Boccherini's Celebrated Minuet in cello concerto No. 9 is one of my favorite classical pieces.
Allan
Edited by allanyed
2 hours ago, TBlack said:
The mizzen has no shrouds? Hard to believe.
Tom
Tom
He said no futtock shrouds...the means to climb up and over the top from the lower shrouds to the top shrouds...  And no topmast shrouds from the tops...Weird.  I think the addition of the tops should be eliminated and only cross trees are required.  Still you need shrouds to access above the tree.  Weird...again.
Rob
Edited by rwiederrich
Current build:
Finished build:
Current build(On hold):
Possibly the term *spreader* is being utilized to describe the cross tree.....?
Rob
Current build:
Finished build:
Crosstree, thanks, that was the word I was looking for…
but the ship is the Harriet McGregor, and I cant’t find sny pics of her (or any model of her) showing a mizzen top with shrouds. At least not with enough shrouds to have a full set of futtock shroulds, or ratlines to the top of the mizzen mast.
Hence my question whether the top as shown on the model is correct
Jan
I found some pictures at the State Library of South Australia of the Harriet McGregor. The photos are not very good but a couple of them seem to show mizzen topmast shrouds. And if they had shrouds there would have to be futtock shrouds to carry the force back in to the mast.
Also, I found a photo of a painting of the ship that shows mizzen topmast shrouds. I know that a painting is not necessarily a definitive source, but it is out there.
Harold Underhill, in Masting and Rigging the Clipper Ship and Ocean Carrier, has shrouds and futtocks for barque and barquentine fore and aft masts.
Personally, I feel that there has to be something there to counter the sideways forces from the sail.
Regards,
Henry
Henry
Laissez le bon temps rouler !
Chris,
thanks for the intervention.
Allan,
1860, Harriet McGregor. Boccherini, an underappreciated composer. His guitar quintets grabbed my attention, particularly this: https://www.youtube.com/watch?v=IgEaS_d6qUE . I'll have a listen to the "Celebrated Minuet in cello concerto No. 9"
Amateur,
that picture has a very similar mizzen set up as my plan (which shows no clear detail of the top). I now know that my top, taken from "Masting & Rigging", may not be correct for the ship.
Henry,
I forgot I had this picture from the Hobart Maritime Museum (?), which seems (possibly), to show a pair of crosstrees/spreaders with shrouds terminating half way up the mast and futtock shrouds connecting onto the main shrouds part way down.
Is this the painting you are referring to:
Rob,
Thanks for your input.
My rigging plan also shows no spanker boom guys, yet "Masting and Rigging" includes them in the description of rigging for spanker booms. The book also describes the boom sheets as having 2 blocks, my plan shows only one. Harriet McGregor was a small ship, 330 tons for memory, would this explain the rigging oddities?
Regards,
Grant.
John,
thanks for the photo. it shows some differences from Underhill's drawings. Different point of time in the her life?
I have squinted very hard at the far side of the mizzen top / top mast. There seems to be a pair of shrouds with ratlines, not 100% sure though.
Regards,
Grant.
Hi Grant,
Sorry to have taken the string off track....I just listened to the Fandango, it is great, thanks for the tip!   Also - String quintet in E Op.11, No. 5   Very familiar melody.
Allan
John,
I've had a closer, magnified look at the picture, I suspect you're right about the 1 spreader/crosstree. Late middle age eyesight often sees what it wants to see. Would the spreader would be fore or aft of the mast?
Rectifying the error should be fun.
Thanks again for your help.
Allan,
no worries. I'll get to your recommendations over the weekend.
Regards,
Grant.
Grant, this is a much-zoomed detail of the mizzen mast.  The spreader appears to be on a collar around the mast and to be centred on the mast.
If you save the image and then open it, right click and hit 'zoom to fit', you should get a reasonably clear full screen size image to study.
John
780839285_HarrietMcGregor(2)-DeNoiseAI-standard.jpg.a3b60ce73fa709b26420aa223722eb34.jpg
Thanks Henry. Great painting. Mr. Green had an eye for detail.
John,
thanks for that, I can't enlarge it much. It starts to pixelate (right word?). I can't imagine the spreader being a single piece of metal poking out from the collar, probably wouldn't be strong enough. A "T" section spreader? Any thoughts?
Regards,
Grant.
According to Underhill, the tops for the mizzen, or other fore and aft rigged masts, were constructed the same as the Fore and Main tops. They are essentially platforms nailed on top of the usual trestle trees and cross trees. On the Fore and Main there were fitted additional spreaders to take the backstays, but the mizzen often did not have spreaders fitted. Sometimes, the platform itself was omitted from the mizzen top leaving only the cross trees to lead the futtock plates through.
Regards,
Henry
Henry
