Cutter Cheerful 1806 by Freebird - Syren Ship Model Company - 1/48
1 hour ago, Paul Le Wol said:
Hi Rick, in the first photo where you are using the t-pin, the batten seems to cut straight across the space between the bow filler and bulkhead M. Maybe you can try putting some bend in the end of the batten so that it will enter the rabbet at the stem at a better angle. Then see how it sits moving aft. Looking good!
Paul, thank you for the look! As you can see from the pictures above, a lot has changed. Thoughts?
 Best Regards …. Rick
Link to comment
Share on other sites
Unlike a double planked hull (and this is why they are double planked) you can’t correct uneven fairing by sanding that first planking. With a single planked hull you have no more than the thickness of a 3/64th plank.  It’s understandable to want to call it done and move on, but it is essential to have the fairing as near perfect as you can get it. Don’t just pin the batten, slide it up and down, top to bottom with your fingers at multiple sections, you can feel the imperfections if there are any, it should feel smooth and flow evenly.  The infrastructure is of course the basis of every thing else you do, it’s worth taking the time to do it right. There is some opportunity to so a little shim work as you plank, but not much.
I said it in jest, there is though a bit of zen at the stage. From what I can tell you’re doing a great job of this.
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Glenn, that’s exactly what I’m doing. The batten runs very nicely across all bulkheads the length of the hull. I’m actually very impressed that I don’t have any bumps or dips. I’m sure that some tweaking will be needed when I start planking.
Thanks for checking in and having my back!
Link to comment
Looking good and I think I’m ready to start the sills. The batten has a nice flow from stem to stern. What I found remarkable was that each laser mark was .470” from the top of each bulkhead extension. Also, when fairing the starboard side, I made the exact same mistake on bulkhead L and it too needed a shim. At least I’m consistent.
I have a Byrnes 4” disk sander on order that should be here in a day or so. I’m going to wait on doing the sills until the sander arrives so I can give it a test drive. Here’s a few pictures.
Link to comment
New toy arrived today, Byrnes 4” disc sander with an extra disc. This will make life a whole lot easier! No more using the monster disc sander that’ll sand a finger to the bone in less than a second. The accuracy is amazing! Now on the the sills!
Link to comment
IMG_2755.MOV
On my wish list.
Link to comment
Slow progress, I completed the starboard ports and then checked the alignment with a batten, all looked good. Then I thought for the port side why not use the batten to align the sills. So I placed the batten just touching marks. I made the sills and alignment was quick and easy. Now to add the port uprights.
Link to comment
Ok, who ever thought that gun ports on model ships was a good idea should be hanged from a yardarm! I’m a pretty good modeler, but gun ports have brought me to my knees. They’re a whole lot more work than I anticipated. I had to tear out some sills (only 2) and several port uprights. Lots of lessons learned! Stay tuned!
Link to comment
This is a step you want to get right or you’ll be chasing it all the way through planking. They don’t follow the waterline but the sheer of the deck, they aren’t square as a result. I would have been lost without the reference lines, but depending on the bulkhead could be a little off. You’ll figure it out, and later as you’re planking, will be glad you did.
Have fun.
Regards,
Glenn
Link to comment
Thanks Glenn for the sage advice. Gun ports is something I’ve never done before, and it’s quite a challenge. I’ve been looking at build logs, including yours, for ways to get them ship shape. I’m having a lot of fun with this build and it’s teaching me a lot for when I get to my Winnie. One thing I really like about Cheerful, is the amount of bulkheads, I think it made fairing easier to get a nice flow.
Also, just for giggles I put the stern parts on the hull to see what’s it going to entail. I can already see that there’s a lot of room to mess things up. Again, this is a first for me.
Link to comment
Its looking great....Dont over think it.  That can be paralyzing to a project.  Just go slow and steady and it will all work out in the end.
Chuck
Link to comment
This marks the completion of chapter 1. Lots of rework required and a lot of measurements taken. Gun ports are a lot more complicated than anticipated. A few I messed up by over sanding (a bad habit of mine), and some were improperly installed. What ever didn’t measure up was removed and replaced. The sills have a nice flow and the battens sit snug on the bulkheads from stem to stern, no humps or bumps. I thinned the bulwarks to 1/8” before cutting the forward chase posts. All of this work is a new frontier for me and I’ve really enjoyed it! It took 30 days to complete this chapter, just some time here and there, no hurry needed here!
Thanks to everyone for the likes and to those that have offered advise, much appreciated!
Now onto another first, the stern.
Edited by Freebird
Link to comment
9 minutes ago, Freebird said:
This marks the completion of chapter 1. Lots of rework required and a lot of measurements taken. Gun ports are a lot more complicated than anticipated. A few I messed up by over sanding (a bad habit of mine), and some were improperly installed. What ever didn’t measure up was removed and replaced. The sills have a nice flow and the battens sit snug on the bulkheads from stem to stern, no bumps or bumps. I thinned the bulwarks to 1/8” before cutting the forward chase posts. All of this work is a new frontier for me and I’ve really enjoyed it! It took 30 days to complete this chapter, just some time here and there, no hurry needed here!
Very impressive.  I hope my skill levels will get to this level some day.
Link to comment
Looking good to me Rick 👍 I have just got mine, but this is going to be a steep learning curve for me too, so i hope you don't mind if i follow along? 😬
Oh and i freely admit that if i see any good ideas i will probably steal them lol
Edited by CaptnBirdseye
Link to comment
Thanks Diver, I think you’re more advanced than I am. This is my second build, first was Chuck’s Medway longboat, this is far more advanced than I thought.
20 minutes ago, CaptnBirdseye said:
I have just got mine, but this is going to be a steep learning curve for me, so i hope you don't mind if i follow along? 😬
Thanks Captain, you’re more than welcomed to pull up a chair and follow along, I enjoy the company! There’s a lot of Cheerful logs with lots of great ideas to steal, err…..I mean to use. You’re going to love this build, such a pretty vessel with nice lines.
Link to comment
Started framing the stern. Z frames are laminated and glued into place. I used some bubble levels to make sure the frames were level with the bow and no adjustments were needed. Hard to see in the pictures, but all is level. I’ve also made the square tuck piece. Just need to fair the outer frames first and then glue the X & Y frames in place.
Edited by Freebird
Link to comment
Holy accuracy! The X/Y frames are just sitting in place and I decided to tape the stern template in place. Dang! Can’t ask for better alignment. I know I’m not this good, a great testament to Chuck’s design and laser skills. I’m loving this build! Thanks Chuck!
Edited by Freebird
Link to comment
Link to comment
No you are good to go as is....Just keep following the monograph chapters.   Its coming along very well.  You will be taking care of the inboard side of those outer stern frames in Chapter 3.....
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
