I assume that at some point you will wrap rope around the steering drum. That means the rope needs to pass through the deck. I didn't see any provisions for that. Should you rig the ship's wheel, here are some photos to help you do that.
OK, so this was very interesting to me.  My apologies, Mustafa, for taking up this space in your build log. Your ship's wheel looks awesome in its place on the deck!  Great pictures, Jon.  So, I wondered where do those ropes wrapped around the drum go after they go through the spar deck?!?  Should we be able to see them somewhere on the gun deck, then?
Well, I did my own research (I've learned so much from you guys!), and found the plans on the USS Constitution Museum website related to the steering.  I saved these files as pdf's, and can't figure out how to show them as a picture here, but hopefully the pdf will open up ok.  It appears the cables go through the gun deck and then travel along the ceiling of the berth deck where they attach to the tiller and the rudder.  Very interesting! It appears that on the gun deck, they are going through some sort of conduit located in the Commodore's pantry (circled in red on the PDF), which is why we don't see it on the Museum's virtual tour website.  Jon may have been able to get in that area during his actual visit to the ship.
Anyways, I thought that was interesting, and thanks to Jon for pointing out the cable on the ship's wheel drum.  Again, this all looks fantastic on your Constitution, Mustafa!
Steering_Cables.pdf
Edited by GGibson
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
I have a lot of images of the Constitution, I mean a LOT of pictures. However strange it may sound, I do not have any images of the interior of the Commodore's pantry. I suspect, and this my opinion only, the Navy staff uses that small area for storage, something the public doesn't need to see. I have visited the ship at least 3 times, the last time was November 31, 2014 just before her last refit, but never got a private tour which would have allowed me to see things the general public did not have had access to. Had I joined the NRG sooner when they had one of their yearly conventions in Boston, I would have had that private tour. So sorry, no pictures of the interior of the pantry. I do have pictures of the tiller room where the steering cables hook up to the rudder should you want them.
Jon
Thank you so much for the pictures Jon.
Thanks Greg. I was wondering where these ropes go and wanted to do a virtual tour to see them, but as you said, they go through the pantry.
One more silly, stupid question before the end of my day, Mustafa.  Just so I understand how you are doing your awesome work.  You placed the decking under the ship's wheel and brought it back so it begins to surround the mizzen mast.  In order to do that, to have the decking rest solidly, I'm assuming you placed some type of "dummy" support beam between the fife rail and where the ship's wheel sits, somewhat like where I drew the red line in your picture below?  I will also assume you will also place decking, then, on the aft side of the mizzen mast, as well, to help support the mast and to have the mast base (can't think of its proper name now) sit on.
Again, apologize for taking up space on your build log, but I love to see how you are doing things with this exposed deck.  Thank you, sir! Carry on!
Gregg
Never hesitate to ask anything Greg. I'm here to answer questions.
Yes, I did exactly as you said and added a beam there. There are a lot of auxiliary beams on the original ship that I didn't add to my model anyway. And yes, I'll plank the aft side of the mizzen mast later.
Edited by mtbediz
I am working on captain's skylight. I prepared a hexagonal prism and a hexagonal-based conical prism from pear wood, adding details cut from 0.5 mm pear strips. I used black paint to represent the windows and made the window bars out of 0.5 mm brass wire. Finally, I finished it with a matte varnish."
Edited by mtbediz
Compared to mine, your skylight is simpler to construct and just as visually effective if not more so. Excellence job in placing those horizonal brass bars. That was not easy to do. Breath wrong or have a slight hand tremor, and it's messed up. Well done.
Jon
Thank you Jon.
For the aft skylight, I cut the base plate from 0.3 mm brass sheet and blackened it. I made the railing of the skylight from 0.7 mm brass wire, but I couldn't clean up the excess solder using my old files. So, I ordered a new set of files. I'll work on that later. Nothing is glued in place yet.
Edited by mtbediz
Out of curiosity, how did you set up your soldering jig for the skylight railing?
Jon
Jon
I didn't use a special jig for this. I just fixed the rail onto a flat surface with tape and soldered the stancions to it while holding them with my hand. By the way, I use soldering paste for soldering, so my hand is free and I can hold the stanchion with my hand.
Edited by mtbediz
Wow!
Still, Wow!
Well done. I would have never have thought of fabricating the binnacles in that manner. Since I don't have a true drill press, just my Dremel drill stand and a Proxxon X-Y table, I'll have to give some thought as to how I could successfully accomplish the same thing as you (alignment issues) when the time comes . That is, if I ever finish these #$%^& canopy frames.🤬
Jon
I really wanted the canopy to have the center ornament that others had made. I committed myself and I will finish them before the decade is done🙃!
Jon
2 hours ago, JSGerson said:
...and I will finish them before the decade is done
Why do I hear the Jeopardy theme in the background?!? 🤷‍♀️🤣
Awesome work by both of you gentlemen!  Inspiring!
Gregg
16 hours ago, mtbediz said:
I completed the binnacles and installed them in their places.
Great work on the binnacles, Mustafa!  Showing me all sorts of ways to use that mill! 👍🏆
I find it interesting that Model Shipways' USS Constitution Instruction Manual discusses the binnacle on page 23 and I'm assuming addresses it in the plans (although mt plans are still neatly folded in the Model Shipways book on the shelf), yet the binnacle is not on display in the online USSC Virtual Tour (actually you don't see the ship's wheel either, so maybe both were under repair when the virtual tour video was created) and you don't see the binnacle placed in the Spar Deck General Arrangement plans on the museum's Modeler Resources page. 🤷‍♀️
Love seeing all your spar deck details, Mustafa!
Gregg
Thanks Greg. Life is pretty easy with that mill. :)
On 3/19/2025 at 10:26 AM, JSGerson said:
Of course, it helps to have the proper tools, like a drill press sitting over a lathe.
Jon,  I just purchased that accessory for the Proxxon mill.  It's the Dividing Attachment for MICRO Mill MF 70 and MICRO Compound Table KT 70.  I wish that I'd had that earlier in the build, but once I see a tool I think I'll use (and I saw this before in Mustafa's build log), I must have it.   Mine arrived last week, and I can't wait to use it.
In the box of cool tools I got from Quentin, there was a drawplate.  Next time I'm in the shipyard, I'll see if I can't produce some really thin dowel with it.  I'm dubious, but if Mustafa thinks it can work, I'm game.  He can do anything!
And Mustafa,  You never cease to amaze.
Tech support to the rescue.  In Windows, press and holds these three keys to get to a utility that let's you select as much or as little of what you want in a screen shot:
Then use your mouse to surround the part of the screen you want to capture.  That puts the image into the clipboard.  Merely paste it into your post - like I just did.  Google Screen Shot using Windows, Shift and S keys to get at Youtube videos that explain how to use this awesome feature.
I would love to have the dividing attachment, but for the cost and the amount of times I could use it in the future, I can't justify the cost. That and the fact my Dremel drill stand is not what you would call a precision instrument. Setting up the X-Y table on the drill stand is a pain because it's held in place with clamps and alignment is done by eyeball and trial and error.
As for the draw plate, I got mine from Byrnes Machine Tools and it was worth every penny. I bought it because the drawplate had from Micro-Mark just wasn't a precision tool especially for the fine holes. I've learned not to buy tools before I need them, because invariably, I didn't need them. The other side of the coin is not having the tool when you need it and it's too late to buy it, like the dividing tool.
I wish you well on you new acquisitions.
Jon
