VIOLIN block
Go to solution Solved by allanyed,
Does anyone know approximately when violin blocks (aka fiddler blocks) were used on galleons? I remember reading maybe in somewhere in the 1700's.
Bill
  • Solution
Hi Bill,
What nation and which lines are you referring to for the long tackle blocks (fiddle blocks)? I cannot speak for earlier dates or nations, but according to James Lees on page 68 of The Masting and Rigging of English Ships of War, fiddle blocks  were used from 1719 until 1806.  On page 166 he describes them being used on yard arms and where ordinary double blocks could foul up.   Regarding those on the yard arm, before and after that period two single blocks were stropped together.  Hope this helps
Allan
Bill,
To my knowledge there are only three (small) sizes of these properly-shaped "violin blocks" (double blocks) available from Syren Ship Models. There may be others available but I have yet to discover other quality sources. Here's a link:
(https://syrenshipmodelcompany.com/boxwood-rigging-blocks.php#!/New-improved-9-32-7mm-Boxwood-Fiddle-block-Laser-Cut-Kit-Build-it-yourself/p/39688217/category=5764703
If the scale you need can't be found among these three options, then I believe you'll need to scratch them, which could be a Big Pain with lots of delicate carving involved. In the photo below my arrow points to the Syren Fiddle Blocks I used on a recent model. These accurately fashioned blocks are made from boxwood; I stain them a reddish hue to simulate Chestnut, a typical wood used for rigging blocks for centuries. As you can see, all the other blocks in the photo are the same color (excepting the upper deadeyes).
In this photo, located near the tip of a main course yardarm, the violin block works to lift the yardarm (inner, small part) and the larger part (outer) guides a main topsail's tack control rope.
Hope this helps! (but humbled apologies if you know all this info already).
Ron
Former Director, Nautical Research Guild, 2021-2025
@modelshipdood on Instagram
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
Lees (or me😀) may have this wrong or it may just be a matter of terminology but on page 80 and page 91 of The Masting and Rigging of British Ships of War he describes the larger lower block of the pair, or larger sheave if a fiddle block, as used for the topsail sheet, not a tack.  He makes no mention of there being a tack for the topsails.
Allan
Allan
You are correct Allan. Topsails have no tack. The sheet holds them confined to the lower yard.
Regards,
Henry
Henry
Laissez le bon temps rouler !
Thank you all for your time and replys. The galleon I am currently building is from 1558 and a Spanish Galleon.
I see (again) the manufacturer has made a error. Will it never end???
Bill
I stand corrected, the larger portion of the block is, indeed, a sheet block and not for a tack! So perhaps only half my advice may be helpful to Bill (sourcing violin blocks), the other half - not so much.
Thanks for the correction Alan and Henry. I'm obviously still learning the ropes.🤭
I love the photo of the blockmakers workshop sign: there's so much information in that beautifully-carved tableau!
Ron
Bill
Hi Bill,
It will not end: there are virtually no contemporary models from that era, no technical drawings of specific ships.
So: any model of an early spanish galleon is a product of knowledge, and fantasy. And the ratio of those two does vary between kitmakers.
So, forgetvthe idea of building an exact model, shop around in pictures and build something that looks like the picture, and is pleasing your own eye. But don’t get annoyed by the ‘an other error, again’.
Even kits of well documented ships have errors (small or large). You can go down the lane of research, but even then, you will for ever have the doubt whether you followed the correct source.
Try googling the dutch maritime painters of around 1600, they have proven to be pretty spot on when it comes to depicting ships of the period, and they did some spanish galleons of that era as well. For earlier ships: do what you like :)
Jan
21 hours ago, amateur said:
Hi Bill,
Jan
Thanks Jan.. I will look around at various pictures but pictures are from the artist's perspectives and oftertimes are inaccurate as well.
On 10/22/2023 at 6:30 PM, amateur said:
Try Adam Willaerts and Cornelis Verbeeck.
Both Dutch painters active around 1600. Both known in their time and now for rather accurate depictions of ships, including correct depiction of the rigging of those ships.
Jan
Thanks Jan I will look for their works.
