24 minutes ago, Old Rentner said:
Now I feel like throwing the whole thing into the waste basket
I feel your pain. I don't use the waste basket for builds like this, but I do have a "shelf of shame" where incomplete models go to languish in whatever state my lack of mojo left them in.
On 1/29/2024 at 2:41 PM, jerome said:
Perhaps you could sand the ink runs off with 400 grit?
light pressure on the sand paper of course.
Thank you.  I did try sanding but the staining seemed to be quite deep and there were too many other structures (windows etc) nearby that were prone to further damage.  I did not want to make the mess even worse.  When it happened the first time I did sand, repaint white and redo the windows but it was not a great success.
I’ve painted the ‘tears’ white but, of course, the white in my paint pot is not the exact white of the hull, and I’ve covered the whole ‘mess’ with matt varnish from a bottle (no spray solvent) and I don’t think that I should mess with it anymore.  I won’t respray it - too much of a risk!  Now it’s a bit like the English man’s view of the bagpipes - fine when heard/viewed from afar (preferably from Scotland to England) but although I agree about my Canberra, I love the pipes.
The next problem is the rigging and radio wires which abound around the bridge.  The scale necessitates that they be very fine but more importantly they have to be attached somewhere.  The mast attachments should not be too difficult but where/how can they be attached to the bridge structures?
It’s nearly ‘finished’!  The funnels, railings, propellor mechanisms and the stabilizers are in place.  It’s difficult to understand how the latter could stabilize a big hull but I guess that they did?  The mast and foredeck structures remain and then it’s the railings and ariels etc.  How to do them, how to fix them and where to fix them, I know not!
Help please!!
Without railings the aft decks look pretty dangerous!!!
Edited by Old Rentner
2 hours ago, Old Rentner said:
It’s nearly ‘finished’!  The funnels, railings propellor mechanisms and the stabilizers are in place.  It’s difficult to understand how the latter could stabilize a big hull but I guess that they did?  The mast and foredeck structures remain and then it’s the railings and ariels etc.  How to do them, how to fix them and where to fix them, I know not!
Help please!!
Not quite sure  how  you  could create the  hand rails  without  having some  PE   ones  to hand, might be  difficult,  I have found  two  pics  of the front  masts   etc  and   securing  lines, also  the  rear  showing the  railings   -  double click  on both  or  drag  them with  the  right click mouse   to enlarge them.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
The problem is how to make them, tension them and fix them to the bridge structures.  Thank you for the pictures.  The scale makes them very thin!
You could  buy the  PE railing  sets  I thunk they  do them in 600scale   or  you  might get away with 700scale,  because they are thin metal  you would need to use super glue  to attach them.
OC.
Current builds
Completed works.
OC.
I did manage to get a set finally!  My god they are small!
Indeed  -  requires  some delicate  handling,  but very  nice  when  on,    there  are  different ways  to   attach  them  -  some  people like  to  do small   lengths  at a time, others   do  longer  runs, also  there  are different  ways  to  apply the  glue (super glue)  you  can use a  fine  wire  or needle  to  apply  on the  ship  where  you  want to  fix the  railing,  or  you  could  make a  small  puddle  on a  scrap  piece of  flat  board  etc,  and  gently tip the  bottom of the  railing  using some  fine tweezers  just to coat the  bottom  of the  railing  -  then place on the  ship.   Its  all about finding the way that  works  best  for  you.
OC.
Current builds
Completed works.
Also  be  Very  Careful  cutting them  off the  fret  -  they need   a   very sharp  blade  and  a  solid  flat  surface underneath  -  like a  tile  or  similar  to  stop  them  from  bending.
OC.
Current builds
Completed works.
OC.
Thank you very much for the tips, may I ask about painting?  If I use primer and a top coat how can I avoid clogging the spaces between the  rails.  The spaces between the rails are thinner than four coats of paint I think?
Just a  case  of  playing  with  the brush  to  get the  paint on  while  clearing the  gaps,   just  technique  -  a bit fiddly  but do able.
OC.
Current builds
Completed works.
I tried soaking the PE sheet in vinegar as advised but the paint did not stick!  I then lightly sanded the surfaces and sprayed them with primer.  It seemed to work and there was no ‘clogging’.
Dilute white acrylic (two coats) was applied with the PE sheet on a paper underlay so that the paper seemed to absorb the paint between the railings.  Cutting the railing presented no problems but trying to glue the railing to the aft games deck was another disaster!  The super glue took so long to dry that I could not hold the rail in position correctly so I abandoned the task.  I must get some quicker drying super glue I think?
What you could do   (Dont know if you have any Tamiya Tape)   is to  attach it around the  edge of the decks where  you want the  railings  to  go, then place the  railings  touching the  tape  -  but gently,  then  remove the  tape  (gently) when set,  this  might help  to keep the  railings in place till  set.
OC.
Current builds
Completed works.
Hi,
Assuming your super glue is CA there is a product, CA accelerator, in an aerosol spray can, that will almost instantly cure the glue joint with just a slight squirt.
I think the one I use (not often) is called Zip Kicker.  I would test it on some expendable painted parts before hitting your model with it just to be safe.
Of course, you may still need three hands to hold everything together and give it a shot.
That's a nice looking ship btw.
Good Luck,
mcb
Thanks for the suggestions.  I had read about using tape but was frightened that, with my luck, I would not get it off without major damage!
I also read about accelerators but with all the problems that I seem to have had with ‘spraying’ I decided against trying one.
I’ve ordered some quicker drying super glues so will have a go again tomorrow.  They’ll probably dry before I get the rail in place though!!!
I’m personally not a CA glue user but have read, here an the forum and elsewhere, that the hardening reaction depends on moisture.  Blowing on it gently can speed the reaction.
An alternative to CA glue is nitrocellulose based  clear nail polish; a close relation to the model airplane cement that we used as kids.  I prefer it to CA.
Roger
Well, at last, passengers on the upper decks won’t fall off the aft areas!  I plucked up courage and set to work with the newly arrived glues.  The ‘3 second’ one did not set in three seconds but it was much better than the gel.  I managed to hold sections of the rail sequentially around the edge and was fairly pleased with the result.  Unfortunately some areas of paint came off and the glue when dry is glossy so I will have to do a lot of touching up.  Ladder rails were very difficult because the rails were so small!
Touching up won’t be easy I fear?
Thats  made a  big difference  -  they  really add   to the  details.
OC.
Current builds
Completed works.
At last, the more difficult railings are in place!  I redid one but the others were as good as I could make them I thought.  Placing the very small ladder rails, with my wobbly hands, was not too easy!!!  The final gluing will have to do for my model.
Now for the boat deck rails - I’ll have to do each one separately I’m afraid - there is no quick way as far as I can think.  If I just put in an entire strip of PE rail it would either be too far inboard (I could not glue it either) or it would be outside of the hull!
After the boat deck rails, some filling and retouching the areas where paint came off during gluing and manipulation with my tweezers.  Then, finally, I hope, the wireless/radar wires etc.  How to do that, at reasonable scale, with tension, I have not worked out yet!
Looking really nice  -  all  those additions  so make a  difference.
OC.
Current builds
Completed works.
At last, 40 individual boat deck and upper deck railings glued in ‘place’.  Sadly, they are not all as ‘squarely’ glued as they might be but my wobbly hands could not do better.  Overall, the boat looks more realistic.  During gluing some paint came off the rails so now it’s time for the mass ‘touch up’.  After I’ll apply some clear matt varnish to help protect the paint on the rails which has not bonded very well to the PE brass.
To glue the rails I used curved tweezers, a darning needle and a tool that I made by knocking a needle into a meat skewer and then cutting off 3/4 of the ‘eye’.  I used the latter to spread glue where I wanted the rail, then applied glue to the bottom of the rail by drawing the rail through a drop of glue on a piece of baking paper(learnt from you tube), and then held the rail in place in till the glue was firm.  When the glue was set I adjusted the angle of the rail to straighten it as well as I could.
Now for the massive ‘touch up’!
Touched up as well as possible, now the radio lines etc. but how to fix and keep tight at this scale?  Any suggestions please?
There are so many variations in different pictures of the boat - some are white others black, some seem to attach to different places even?
