Bonjour à tous, heureux de rejoindre une communauté de modélistes aussi talentueux.
Hello, sorry for my English, it's not my native language.
I have actually been browsing this forum for quite some time but have never introduced myself. My name is Christian, I live in a small town on the south shore of Montreal in Quebec, Canada.
I did model making when I was young (plastic model), then I started again with a wooden model in my thirties which I had to stop before it was finished. The Amati’s 1934 Endeavour America’s Cup J Class. I intend to finish it, because there isn't much left, some ropes, sails, and a few details. I have another model waiting, the HSM Pandora from Constructo which I bought about twenty years ago.
After seeing the immense talent of the members of this forum as well as the gigantic source of information available, I will most likely greatly modify this kit, because I am inspired by your extraordinary manufacturing methods. Unfortunately, I don't yet have the time to devote myself to my hobby, so I will continue to be inspired and learn from your great achievements in the meantime.
Thank you for welcoming me among you.
In the meantime, here are some images of my Endeavour.
Thank you
Christian
 Christian, welcome to MSW. Your Endeavour is a beauty. Glad to have you aboard.
:sign:
On 3/5/2024 at 9:19 AM, Ogontz said:
Hello Cbill,
A beautiful model to be sure!
What product and method did you use to achieve such a flawless high gloss finish on the hull and topsides?
Thank you very much Ogontz,
I used to work in the body shop of a car dealership, so I used automotive paint products.
And for the technique, here are the steps
- After finalizing the hull planking, I covered the now blue part with polyester finishing putty to cover the wood.
- Once sanded (180/220/320 grit paper), this section has been primed
- Sanded with 600 sandpaper
- This section was painted with a blue base coat
- Then the blue and the wood of the hull were covered with two layers of clear coat
- Then everything was wet sanded with 800 water sandpaper
- The two white vinyl pinstripes 1/8" and 1/16" were installed on the sanded surface
- Everything was covered with two coats of clear
- Re-sanded with 800 wet sandpaper to remove pinstripe demarcations
- Two more coats of clear
- Then sanded with 1000, 1500 then finally 2500 with water
- Polish with a polisher with 3M polishing compound, then with a foam polishing pad with a ultrafine polish and finally a polymer wax.
A lot of time and a lot of steps, but the hull has been painted for more than twenty years and the finish is still as new, it hasn't lost its shine.
Thank you
Christian
On 3/8/2024 at 10:19 AM, Ogontz said:
Thank you for the detailed steps in the process! Would I purchase the polyester finishing putty at an auto supply store?
And other than where noted, are you using the wet/dry paper in a dry state?
Hi
Yes, you can buy polyester finishing putty in an auto supply store as long as they stock automotive paint products.
From the moment the hull receives its first coat of clear, the following sandings are done with water.
The Clearcoat I used was Glasurit, but I don't remember exactly which one. Here is the link to the Glasurit clears.
https://www.glasurit.com/en-int/all-products?type[]=108&category[]=27
But any brand would do.
Thank you
