Table of contents
Pre-building
Log #1: research and preparation
Log #2: Unboxing and review
Hull Construction
Log #3: Frame assembly
Log #4: Transom, Fairing and Keel
Log #5: Bulwarks
Log #6: First planks
Log #7: First layer planks - pt 2
Log #8: Finishing and sanding first layer planking
Log #9: Starting the second layer planking
Log #10: Completing the first band
Log #11: completing the second layer planking
Hull painting
Log #12: Priming the hull
Log #13: Painting the hull
Hull details
Log #14: Bulwarks and Wales
Log #15: Bulwarks and wales pt 2
Log #1: Research and preparation
This is the start of the Sherbourne build log, the kit won’t be arriving for another 2-3 weeks but anything that I should be aware of or extra parts I should get please let me know.
I will be replacing all rope with
Ropes of Scale and the kit blocks with Syren blocks.
Edited by Isaiah
Would you like to do some research on the real ship?
"Bee nott afrayed of anny man thatt walks beneath the skys,
tho big he bee or small you bee, for I will equalize"
- carved into the grip of a Colt army revolver, 1870's
An accurate build is a good looking build. When it comes to ships, usually accuracy equates to beauty pretty well.
1 hour ago, Pitan said:
I stand to be corrected, but, I thought Vanguard uses Ropes of Scale?
Though the supplied standing rigging is black in this kit, and you may want brown?
I’m following your build as well.
It’s not Ropes of Scale. I think it might be Amati cord. Ropes of scale rope only comes in 6 metre lengths.
Good point about the standing rigging. Coal or black tar came much later so brown or pine tar would be better.
Edited by Isaiah
2 hours ago, wvdhee said:
File the edges, paint them black and they look perfect imho.
This is true of a lot of the PE. You can make it look significantly better by filing them or in some cases glueing two pieces together to make them thicker.
Looks interesting.
The kit has a hull cradle sized to support the hull at the frames (even before planking), but I can see other stages in the build where your jigs will be useful.
A modification of your cutting jig might be very useful when working on my mast and spars.  I wonder? Pondering ...
3 hours ago, Isaiah said:
I just realised I have to add blocks to the jig to fit in between the bulkheads. Otherwise the bulkheads won’t be able to slot all the way down.
Absolutely no need. The Vanguard system makes jigs etc. superfluous.
Simon.
Current builds
  • HMS Speedy v2023 - Vanguard Models
  • Nisha - Vanguard Models
  • HM Gun Brig Adder - Vanguard Models
Previous
51 minutes ago, Isaiah said:
most other kits I’ve seen require keeping the keel straight while planking
You can prevent this by using filler blocks in some places, which also give the planking a greater surface area to adhere to.
2 hours ago, Pitan said:
That looks like nice progress, Isaiah.
That hull should be nice and straight by now?
The hull had a slight twist along the length. I’ve currently got it under tension while the glue around all the bulkheads dries. Should work.
