Hello,
This is my first wooden ship model kit, I have built other models of wood, and ships and tanks from plastic. This is the San felipe by Occre, I got this kit in july and started in early august and hope this will turn out good.
Hope anyone that watches this build log progress will enjoy, thanks.
Update #1
started doing the sides, boy this part was stuff especially the curving part of the sticks (if that is what it is called)
hopefully the filing of the bow and stern to round them, was pretty tough to determine how much to file and not to file too much
How is yr build coming on, you certainly got of to a great start, but i would look again at ensuring the planks fitted to the hull are in full contact with the bulkheadsimage.jpeg.7950ef2711b8feae14da2fc4ba2a205c.jpeg
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
  • 5 months later...
Well, I have been gone for a while and didn't have time to really work on the model, but last 2 weeks were open so here is a small update, I put satin varnish on the decks, and completed the deck on one side, the other will wait to next update, I have put wood filler and sanded it (yes this is after sanding and it is smoother than it looks), other than that this build has double planking so the second one is the smooth one, this is fine imo
Sadly due to a poor quality station for the ship, and me using too much strength i broke the side and tried fixing it.
if there are any tips on masking the damage, I would welcome help
you could cut the broken side panel and remove, and place some support under the deck and reapply
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Roy, I have two models of San Felipe, both inherited and started, the smaller came with two SF-boxes with items hopefully to make one complete ship.
Please get back to your build as it looks really good.
Respectfully
  • 2 months later...
Epoxy, I would remove top piece, square up edges and use slightly thinner filler. Basically like using bondo on a car repair….
only the inside shows I believe.
Tony
Savannah, Georgia
Multi hobby nut.
I am building this kit and believe I will plank the inside of that area. Have not got that far yet, but to me stained plywood is sorta unrealistic. I have used commercial veneer in the past on other kits.
Tony
Savannah, Georgia
Multi hobby nut.
  • 2 months later...
So, I haven't posted in a while due to having to do some stuff and moving to a new home
but i now finished doing the planking of one side of the ship, and in the process of the other.
i also put a second hand of filler on the bottom (might not look best, but its pretty smooth now) to make sure its shaped well and smooth for the next stages.
Also thanks for the tips and kind comments.
I will try to post more often as the ship progresses.
