Congratulations on finishing your Pram.  It is a nice looking model.
Ryland
               - Nautical Research Guild
Thank you everyone!!! :)
Current Builds
Billings Boats Norden
Trumpeter R/N Fiume
Upcoming Builds                                                   Completed Builds
Midwest Maine Lobster Boat.                           Model Shipways Norwegian Pram
Billings Boats RCMP St Roch                            Midwest Models Lobster Smack
        Model Shipways Dory
I stream my builds live, join me at  https://www.twitch.tv/bartbandy
Nicely done,  Congratulations.   :cheers:
                   WASA
                   USRC Harriet Lane
On 11/5/2024 at 8:49 PM, MBerg said:
I think he's referring to the notch for the tiller.
Coming to this late, as I'm catching up on build logs before starting my pram. One point that I won't remember to note in my own build log, so I'll put it here for whatever help it may be to others:
I don't think that's a notch for the tiller. I think it's intended for sculling the boat (with one oar) or maybe steering with an oar when sailing in shallow water. If it was for the tiller, it would either have to be in line with the axis of pintles and gudgeons or else much wider, to leave space for the swing of the tiller, side to side.
That's a small point but I've seen one or two build logs where the rudder was mounted low, so that the tiller fitted in the notch. The rudder needs to be high enough for the tiller to sweep, side-to-side above the transom.
Trevor
