Oops. I was rounding the boom and the gaff in my drill and was a little too aggressive. These start square, being from a laser cut thick sheet. There’s a couple of precut holes, which in a nice gesture, but it also makes the wood really weak around the hole.
Model Expo has a parts request page to order a replacement part (https://modelexpo-online.com/parts). In addition to ordering a new sheet with the boom and gaff, I also asked for another PE sheet because there weren’t enough long pieces for the pintles.
Shaped the oars for my Pram; similar to what was done for the Dory. I added the “leather”, paper that I painted with Vallejo Leather Belt. There’s a wide (3/4”) single layer of paper for leather against the oar locks. There’s a thin 1/16” strip wrapped around several times that’s to prevent the oar from slipping out. I first painted one layer on a sheet of paper. Then after it dried I cut into strips (3/4” for the single layer, 1/16” for the other). For both, I first glued just the end of the paper to the oar and let it dry. For the thin one that goes multiple times around, I glued a little at a time. After they were all glued and dried a bit, I protected the bare wood on the oar shafts with Tamiya tape and added another layer of paint. You really need the second layer of paint for the sides of the thin strip that’s looped multiple times.
I’m not sure if I’m misreading what to do or the wrong parts are included in the kit. I’m adding the oarlocks. Each is (I think) supposed to be made from the oarlock piece itself, the brass base with a hole for the oarlock, and two holes for two pins cut short (simulating bolts). Unfortunately, the pins supplied were too wide to fit through the holes. Instead of trying to drill the holes larger, I simulated bolts using a drop of copper paint.
Edited by palmerit
broke mine today in the exact same spot.
Current Builds
Billings Boats Norden
Trumpeter R/N Fiume
Upcoming Builds                                                   Completed Builds
Midwest Maine Lobster Boat.                           Model Shipways Norwegian Pram
Billings Boats RCMP St Roch                            Midwest Models Lobster Smack
        Model Shipways Dory
I stream my builds live, join me at  https://www.twitch.tv/bartbandy
yikes.   hopefully when i get there it will not break
In progress
Lady Eleanor by JIm M - Vanguard Models - 1:64
On hold
Norwegian Sailing Pram - Model Shipways
18th Century Merchant half hull planking - NRG
On the shelf
Muscongus Bay Lobster Smack - Model Shipways
Peterborough Canoe  - Midwest Products/Model Shipways
Batelina - MarisStella
Junco China - Disarmodel
Completed
Model Shipways Lowell Grand Banks
Grand Bank Dory - Midwest Products/Model Shipways
Finished adding the fixtures to the main mast of my Pram. I think I want a mini drill press? (Question mark intentional.) While I found shaping the mast without a lathe (using my drill) just fine (some said it’s easier with a drill), I really struggled to get the small holes lined up right using a small hand drill. Maybe there’s a trick I don’t know about.
This step seems to be another case of a disconnect between the plans (which I had to zoom to 103%) and the written instructions and photos. The plans show a small “eye” near the bottom of the mast. The instructions and photos instead show a small copper wire loop (which I shaped with my new round nose pliers). And then plans show a “shroud eye” with an asterisks to “see instructions for alternative fitting” (with the instructions instead showing a pair of copper straps). And finally, the plans show a single hole at the top for a halyard block but the instructions have you make a halyard sheave (simulating I think a block inside the mast). It’s fine to give different ways to build the model, but when you’re new (this is supposed to be the second beginner model) you think you’re just misunderstanding. The instructions say nothing (unless I missed it) about these being alternatives (except for the lone asterisk about the shroud eye).
I’ve now seen a bunch of other build logs note that the pins they supply are way too wide. The pins that came with my Sherbourne fit.
The pins supplied with the kits are too wide.  Apparently it every Shipwright series kit that they assemble has this QA oversight.  I replaced the nails with some brass sewing pins that should be available just about anywhere that has sewing supplies.
Edited by SiriusVoyager
  - Eric
The replacement parts I ordered from Model
Expo arrived today. They were a bit delayed in shipping (holidays and inventory). But they were free (free replacement parts, free shipping).
I’m shaping the boom and gaff by hand with sandpaper. I’ll probably leave them a bit oval just to minimize the chance they break at the spot of the predrilled holes (like last time).
My first stab at anything approaching rigging. The instructions are not entirely clear and I’m trying to follow them.
First use of my quad hands (quint hands). (Don’t order one from amazon - order directly from the company - I’ve seen scam versions on amazon and then people complain that they don’t work.)
Edited by palmerit
Those quad hands and  third hands are very useful tools for rigging, good work on your  Pram .
Bob M.
Edited by Knocklouder
Guessing typos lol
                   WASA
                   USRC Harriet Lane
21 hours ago, palmerit said:
I don’t know how I would have added the fore stay and two back stays to a mast that’s not intended to be glued in place without quad hands.
@palmerit ohh those quad hands look good.
By the way have you found any more quality issues?
In progress
On hold
On the shelf
Completed
Not a quality issue, but I ended up having to order a new sail because I followed the instructions of taping the sail to a cutting mat. While the mat was clean, it had been used some, so some of the green from the mat ended up staining the sail. I tried airbrushing with some paint but that didn’t work. Next time maybe I’ll try putting some Saran Wrap down and then taping to that.
I have to say that I’m really not sure how someone would mount the mast and add the rigging (and have the rigging taught) without helping hands. Maybe I could have held the mast with my mouth? I suppose I could have done something to clamp the mast in place.
If you get one, order directly from quadhands.com. The real ones had the logo on the heavy base and have high quality arms. And on the real quad hands, the arms are attached to the base with strong magnets so that they can be moved around. I saw some posts various places of quad hands not working - mainly that the arms wouldn’t stay in place - and the photos or videos they had didn’t have the quad hands logo (they were painted the same color and kind of looked the same). Clearly they were knockoffs.
Take two making a sail for my Pram after getting a new sail from Model Expo. It took a couple email pokes, but it was finally shipped.
Take one I made a couple mistakes. First, I used yellow PVA glue (did the same on my Smack) which naturally gave the sail a yellow tone. This time I used a white bookbinders glue. Second, I had taped my sail to my green cutting mat. It was clean but because it had been cut up a bit, some of the green stained sail. This go around, I put Saran Wrap down first.
Tomorrow I’ll add the corner stays, and when they’re dried I’ll drill the holes for the line, and then try to figure out how to attach it. The instructions from the Pram are a bit more extensive than they were for the Smack but still not very clear.
Edited by palmerit
Starting to raise the sail. I think I understand what to do.
I originally thread the halyard through both holes at the top of the mast then realized it went only through one.
It seems odd to me that the halyard and downhaul lines are both secured on the same cleat. I would have thought there’d be separate cleats for separate lines.
Edited by palmerit
Nicely done Sir,  I usually wait 20 to 30 minutes to enjoy the build, then start a new log lol. What do you have planed next?  Congratulations   :cheers:.
                   WASA
                   USRC Harriet Lane
I gotta finish my Smack (almost done) and my Sherbourne (was waiting to do the rigging on the Pram and Smack before getting to that).
I have more models in the cellar on a shelf than I can count. I was probably going to go peruse them in a bit and pick the next one.
I decided I'm going to wait to begin the Duchess, which I had said would be my second model. Then I decided to do the Dory, Pram, and Smack, and the NRG half hull. Then I got caught up in Black Friday sales and decided to buy some of the Vanguard fishing boats since they were easy models. And I somehow late at night pulled the trigger on some other models. Oh, and I inexplicably ordered the Pavel Nikitin Oseberg v3 last week. What was I thinking? I literally have about 10 years of models. I need to stop. Or take a pill.
Edited by palmerit
Nice looking model.  Well done.
Robert Chenoweth
In the research department:
Nothing at this time.
