Rigging Mast Deadeyes Order
Go to solution Solved by barkeater,
When do you install the mast deadeyes? Rig it on each mast section then install the sections together or assemble the masts sections and then rig the deadeyes? Seems to me that installing the deadeye rigging before assembling the masts sections would be the better way as the fighting platforms (aka crows nests) wouldn't been the way. Thanks for your replies.
Allen
Current Builds: Mayflower - 1:60; Golden Hind - 1:50
Past Builds: Marie Jeanne, Bluenose, Bluenose II, Oseberg, Roar Ege,
Waiting to Build: Swift; Skipjack
  • Solution
I install all sections of the masts and platforms prior to adding the shrouds. Even if you tied in the shroud just distally, you still have to have the platforms in place as your lines need to go outside of the crosstrees and bolsters. Plus, you attach the shrouds in a specific order. The order could get messed up if hanging free for any length of time. You have to leave enough room to fit in the heel of the topmast or topgallant and this is tight. Easier to fit the lines one at a time rather than all at once and still keeping them looking neat and in correct order. Also, the topmast and topgallant have to a fit tightly together and adjustment with shrouds in place may make it more difficult. You want to get your masts all aligned midline and with the correct angle. I feel for me this is easier to set this up all at once and glue it rather than doing it in stages.
Rich
It should not be any great problem to pass the eye of the shrouds up through the lubber hole in the tops and then over the mast head before settling them down in the proper sequence over the bolsters.
Regards,
Henry
Henry
Laissez le bon temps rouler !
I have my bottom and top masts set up and ready to rig. I was just over thinking it. I'll start Wednesday with trigging the main mast shrouds and work my way up then move to the fore mast and finish with the mizzen mast. Thanks for the help and getting m y mind to quit overthinking it!
Allen
Hi Allen. I am currently working on the rigging of my own model at the moment and have dealt with the standing rigging not that long ago.
Myself, this is how I would tackle it. Start with the shrouds on the lower mizzen mast. This will in effect set this mast as the anchor of the forward masts. Then add the lower stay from the mizzen mast to the deck or base of main mast as it will put some strain on your mizzen mast shrouds and is easier to attach without the lower main mast shrouds in the way. Attach the lower main mast shrouds and follow that up with the lower main mast stays. Then the lower foremast shrouds and fore stay. Finish off the lower level of standing rigging by attaching the bob stays of the bowsprit. After that go up a level and start back at the mizzen mast topmast shrouds, backstays and topmast stays. By now you are probably seeing a pattern to this method. I always think of it as trying to maintain a rake of the masts so that they have a slight bias of leaning aft. As for the shroud attachment, I attach them to the base of the mast and then pass them down the lubber hole or cap.
Of course there are others who may have an easier or more convenient order of rigging. This is just my take. Incidently, I am rigging the ratlines last. This will allow me to reach inside the standing rigging to attach the running rigging. Working inside to out so to speak.
Good luck with this next stage of your model.
Cheers,
Peter
Edited by petervisser
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Thanks for your method. I may give it a try.
Allen
I always rig the topmast deadeyes and shrouds off model before I set the mast.  Much easier that way.
Current build:
Finished build:
Current build(On hold):
  I did the same for my Grimage-ce2bcf42.webp.4b750b580482bf2cdd3c286dcf1fd826.webpeat Republic.  Once the shrouds are fixed to all the masts the easy part comes by adding the yards.
Current build:
Finished build:
