Hello MSW! - I'm starting a new adventure building Cazador.
The images show this to be an interesting and attractive build. We shall see. I've always liked lateen sails so this fits nicely. The kit also has some ornaments (although only Britannia) and I have never done any of that. Just to be honest, other than maybe some wood swaps, I have no intention of bashing this build too much - reasons explained below.
I originally thought this might be a fictitious ship, just built similar to the Xebec of those times, but it looks like it was a real ship. Designed by Spain to combat the Moorish pirates in the Mediterranean.
I have moved to this build after giving up on my previous build. That literally dragged out for years and I had barely got past the hull. This was due mainly to the horrendous instructions/plans (or lack off). I just got so frustrated that I didn't even want to work on it anymore. A lot of lost idle time. I feel like I have lost my edge when it comes to modeling so it is time to move on. I need to get my Mojo back 😏.
After perusing thru my kits I decided on this one mainly because the plans appear very well put together. I needed a kit that I could concentrate on planking, decking, rigging etc. without having to muddle thru 5th world instructions. Just get back to basics.
After reviewing the plans, I think they are prepared in a format that makes sense to me. There is a booklet that has actual photographs in numbered sections. The instructions are in another booklet - well written in good English. There is a matching instruction section for each image in the other booklet. Very easy to follow.
Also included was an inventory of all parts & pieces. Another page showed all the precut plywood sheets and each piece is numbered. No confusion.
Pretty hard to mix things up!
As far as the parts and materials go, I'm not going to bore you with pix of all that. The sticks and strips are of typical kit quality. I may replace some - maybe. I will say the laser cutting for the precut pieces is excellent!👍  Not a single missed or partial cut in any of the plywood sheets. It has been easy to cut all the parts out of the plywood. Maybe the best I have seen.
The Britannia ornaments are nothing to write home about - pretty bland. But since my goal for this build is pretty basic, I will probably go with them.
So as I stated, my goal is to get my build skills  and confidence back again. Just work with the materials the kit provides. I am amazed how that previous build just totally drained me. Three years wasted. But I am ready to get back in the game again.
So hop on board if you are interested. There aren't too many logs of this build to see.
C'ya soon
Edited by mikiek
corrected log title
Getting started with the hull. It's the typical false keel with a bunch of frame pieces. Nothing really of note there. I won't bore you with hull pix you've seen many times before. That assembly was uneventful.
The next step is going to be fixing a false deck to the top of the frames/keel. It gets kinda interesting now. A side view of the keel shows it slopes upwards from midship to the bow.
A view from the bow shows a downward slope (I don't remember the term for this) from the keel outwards to what will be the bulwarks.
So the false deck is going to have to bend upwards to the bow and also laterally from the keel center to the outer edge. Hmmm.🤨 I had a similar situation with my Enterprise build. In that case the false deck was even thicker than this kit. It was evil. There was no way to clamp the parts so I ended up literally holding the deck to the frames until the glue dried - about 40 minutes. Even then many frames popped from the deck and had to be re-glued.
The instructions say lay some glue on the upper frames and keel, lay the deck down and start nailing the deck to the under supports. First off, the nails are the usual brass pin nails, maybe 1/2" in length, and I seriously doubt they are going to hold anything unless I bang in a few hundred. Not happnin'. Kit nails are useless.
Even worse there are notches in the false deck that have to sync up to protrusions in the frame pieces.
If I start gluing and nailing and then discover that one of the notches doesn't sync with the frame, what then? It seems like I need a couple of extra hands. It gets worse towards the bow as none of those notches are going to sync until the deck is firmly fitted on the keel. Again, how would adjustments be made when half the deck is already glued down midship?
I may be entirely missing something, wouldn't be the first time. My first inclination is to take the false deck and slice it up into smaller sections that could be secured easier. The deck is going to have planks on top of it so none of that would show in the final build.
Would appreciate any ideas.
One more observation - after manually fitting the false deck to the forward frames, it appears that there will be a need to "fare" the gap in those frames to match the slope of the false keel so the deck will sit firmly on top. Hope that made sense.
I am obviously struggling with the application of the false deck. The keel and the frames  produce 2 opposing angles for laying the false deck - both a horizontal and vertical bend. The flat piece used for the deck doesn't want to bend in both directions.
Am I making too big a deal out of this? Something simpler?
I have made multiple dry fittings - putting a few nails thru the deck into the keel. I then try to bend the deck down to the outer edges of the frames. If the nails don't pop out they at least come loose from the keel. I'm considering soaking the deck for a day and then putting a permanent crease in it from bow to midship down the centerline. That might relieve some of the stress and wouldn't require manhandling the deck quite as much.
I must say, I am disappointed in the related logs regarding this situation - both at MSW and elsewhere. All suggest "just glue the deck down and start planking". Well IMO it isn't that easy.
I'll try to provide some pix showing what I am experiencing.
C'ya
From my experience building a similar boat (Chebec Requin) from a different manufacturer (CAF Model), the only way to plank the deck is to do it one plank at a time.
As you indicated, the deck is convex in one direction and concave in the other direction, and as such a flat piece of wood will never fit. It is one of the most difficult vessel to build, because nothing is flat or straight.
In your instructions manual (Figure 06), it seems that you have to trace lines on the sub-deck and then cut along these lines and install the various panels, one at a time.
Yves
Edited by yvesvidal
Nice start, I'll follow along.  I have this kit in my stash.  I was inspired and very impressed by @Katsumoto's heavily bashed build of this kit and knew I wanted to try it some day.  Then late last year I realized that this kit was no longer shown on OcCre's web site, as if it had been discontinued.  But I found that Ages of Sail still had it in stock so I bought one for the stash.   Not sure when I will attempt it.
As for the deck, maybe it would work to first just glue and nail down the center line of the deck along the spine.  Then once that glue dries, work from the center out to the edges.  I know you said you tried something similar but you did not mention any glue or letting it dry.  Putting nails into the edge of plywood is not the most secure way of fastening something, as you found out when you tried to bend the edges down.
Yves - thanks for looking in. Those penciled lines are to give you a guide on where to apply glue. What the instructions didn't say was you need to pencil those lines on both sides on the sub deck. The lines on the other side can be used as a guide on where to drive nails.
Gary - welcome. I bought the kit about 10 years ago. I agree with you that working out from the spine is the way to go. Then I can go one frame at a time front to back to finish the process. Using a syringe with a needle, it shouldn't be to hard to get some glue on the frame surface and then drive a few nails.
Welcome to both of you!
Mike,
The curvature lengthwise is called sheer. It is lower midships than at the bow and stern. The transverse curvature (crosswise from port to starboard) is called camber. It is higher on the center line and lower at the hull sides. The resulting shape of the deck is a hyperboloid. That isn't a nautical term!
How thick is the false deck? Is it plywood?
I like Gary's idea of gluing it along the centerline first, curved along the sheer. But if you do this glue along the centerline only - you want the bulkheads to have a bit of freedom to move fore and aft at the outer edges so you can mate them up with the slots in the false deck.
Personally, I wouldn't bother with the nails to try to hold the deck edges down. Pounding the nails into the bulkheads may rattle something loose. But the nails aren't useless - you can use them to simulate bolt heads.
I would use rubber bands that are looped around the bottom of the keel and deck edges. LOTS of rubber bands. I used some 7 inch bands (the loop is 7 inches long without stretching the bands) and doubled them to hold the deck edges down on my MSI build. I used 1/16 inch (1.6 mm) plywood for the false deck and the bands held it down OK when I used enough of them. Sometimes it helps to put a piece of square dowel at the edge of the deck where the rubber band(s) comes up and over. This sandwiches the deck between the dowel and the top of the bulkhead. That seems to apply more downward force at the deck edge.
It looks to me as if the bulkheads are pretty widely spaced. Too wide for a single planked hull. I have added extra bulkheads in between the widely spaced ones on some kit builds to ensure a far curvature in the planking. Another way is to fill the space between the bulkheads with balsa blocks. If it is a double planked hull it may not matter, but you want to be careful that you don't gat "flat spots" in the planking between the widely spaced bulkheads.
Phil
Current build: USS Cape MSI-2
"The curvature lengthwise is called sheer. It is lower midships than at the bow and stern. The transverse curvature (crosswise from port to starboard) is called camber. It is higher on the center line and lower at the hull sides. The resulting shape of the deck is a hyperboloid. "
Thanks Phil. I hate it when I don't remember stuff like that. Makes me feel old😒
A lot of times when nails are called for I apply spaced dots of CA with a run of white glue in between. The CA can behave like nails and hold until the white glue dries.
Get on and do it! I did the first step on attaching the sub deck to the frame. I applied glue down the top edge of the false keel - shown here
In between the white glue I added a few drops of CA - to hold the deck until the white glue dries. Then I laid the sub deck.
As you can see instead of the stupid nails I just used a few pin vises to hold it down. The trick is you need to get the deck situated in the first frame before anything else.
After getting that I just ran my finger down the keel and it all kinda slipped into place. The deck won't just fall into place, but forcing the back end into place  puts a natural slope into it an the rear 2/3's of the deck just ended up fitting like a glove.
In all this exercise, it's the forward 3 frames that may cause problems. Mainly because they are in the middle of the most outrageous sheer (Thanks Phil). Ensuring that those frames are squared and their top surfaces are fared (a little poetry?) is really crucial.
Rather than nails I just used a few pin vises to hold the whole deck down. I imagine the pin vises can be used in the upcoming step of fastening the deck to the outer portions of the frames.
So for me the biggest takeaway is to seriously fare the top edge of the frame to match the sheer of the false keel. You will not get good contact with the sub deck otherwise.
I might have made too big of a deal from all of this but it is planning and dry runs that makes this step work. If you don't get the deck laid right, you will have multiple problems down the line.
I REALLY wanted to start gluing the deck to the frames tonite, but I will give the glue a chance to dry every last drop before proceeding.
C'ya
Hey everyone. The sub deck is secure on the false keel so I have started to glue the deck to the outer edge of the frames. I will post a report on this tomorrow.
Mean time - a quite bizarre thing seems to have happened. The instructions have disappeared.😕 Both the booklet with the images and the booklet with the written instructions. Not in the house, not in the garage (my shop). Maybe the strangest thing that has happened to me in over 20 years in this house.
Tomorrow I will dump out the trash and recycle bins to see if there is anything there.
Unbelievable!
Evenin' - I'm still working on gluing the subdeck which is proving to be time consuming so far. I started at the bow because I knew that was going to be the most trouble. I glued frame #1 when I glued the deck to the false keel so I started with #2. Bending the deck outwards to the edge of the frame was not easy. In fact it might be called a struggle. A little unexpected since the deck is not all that thick, but there is some serious camber in the frames. Gluing and pinning did not hold. With that in mind I would ignore the instructions telling you to nail the deck. Fortunately some clamps were big enough to reach so that's what I used.
On frame #2 I tried to glue both sides of the deck at the same time as seen in the first image. This really didn't work very well but I was too far into it to do anything else. On frame #3 I focused on one side. Problem here is given the stress the deck was under, I wanted to wait until the glue thoroughly dried (minimum 8-10 hours). At that rate it might be a week to get everything glued. So my impatience lead me to glue one side of frame #4 as well shown in image below.
I suspect after #4 the going should get easier and faster.
So there is some time to kill between frames so I started looking for other things to do in the meantime. I pulled out all the Britannia ornaments and decide to paint those. As I said before "mediocre" might be a stretch, but I have no intention of bashing any of it. Bashing is not a goal for this build. I did see that the background of most pieces is painted black and the relief parts are painted gold. There are some pretty fine nooks and crannies. So my challenge for the ornaments will be to do a good job hand painting them. Definitely going to need to pull out some reading glasses for that.🙄  I checked my paint brushes and came across a few that had tiny hairs - didn't even know I had them. They should help with painting the details.
It rained here today so I was not able to dump the trash & recycle to look for the missing plans. Hope all this isn't in vain. I can plank & deck with no plans but not sure how much beyond that I could go without them.
Talk to ya soon...
Wooh hooh - forward sub deck is attached. I offer one photo for proof, but I won't bore you with 10 more 🙂
Gonna redo one side of frame #4 as the deck did not get flush with the frame protrusion. Had to soften up the glue with some alcohol and have reglued and reclamped that. For deck planking I am going to go with 120mm planks with 4 plank pattern. The deck has been marked off accordingly. Looks a little crooked here but I think that is just the angle this shot was taken.
Looking ahead, I'm reviewing the deck planking instructions. Hmmm, there aren't any. Photo #8 in the instructions shows the subdeck, photo #9 shows the deck planked - as if by magic. On a related note, here is the bunch of sticks that the decking is supposed to come from.
Be very careful because as of the inventory list, there are 4 different dimensions of white wood in this bunch. Some obvious, some not. Once I started measuring the sticks I quickly found that the deck sticks which were stated as 1mm x 3mm varied in the range of .65mm x 3.25mm and all ranges in between. Typical but annoying.
I'm going to get on a soapbox for a minute. When I was beginning to build I used to take deck sticks or hull sticks and cut them to my preferred length and just drop in a big pile. The idea was when I needed another I just grab one from the pile. Many articles here at MSW claim that's the way to go. BIG problem with that logic. Let's say I lay down one piece (plank) for decking. Now I need another plank to continue the strake, so I grab one from the pile. Given the fact that kit sticks never match up in width, the plank I just grabbed likely doesn't match the width of the plank I just laid. Things can get out of whack in a hurry. These days I tend to work with one stick for as long as I can. Then move to another.
So besides the subdeck I am painting the Britannia ornaments. In most cases the pieces have a background and a relief. So I started most pieces by painting the background color (black) on all pieces. Then I am taking my detail brushes and hitting the raised (relief) parts of the piece with gold leaf. Obviously I had to break out my paints, most of which  have been sitting on a shelf of my bench for 6-7 years without opening.
As you might observe I use Tamiya paints exclusively (no affiliation), mainly because I always liked their jars/tops. Rather than the usual circular cardboard insert in the cap, the Tamiya tops have a shaped plastic insert that IMO does an incredible job of sealing the jars. So far every jar I have opened is unchanged from the first day I opened it 6+ years ago. I'm impressed.
Here's a shot of some of the Brit pieces in progress.
Will start planking the deck tomorrow.
C'ya....
Have begun deck planking. Nothing really unusual except that the dimension of the sticks is all over the place - as mentioned in the previous post. I'm weeding out the sticks with borderline measurements. Should be 1mm x 3mm but I'm seeing a lot of .65mm x 2.85mm and also quite a few 1.15mm x 3.25mm. I hope it's just crappy milling.
I have got to say, it is  joy to get back to basic operations. Decking is always a chore but given the last kit I was working on, this is a dream. I'm really having a good time even though I have hosed up a few planks on the deck.
Will have a few pix soon.
Hi Mike,
This is a nice kit to build. Maybe you can pull some inspiration from my log and perhaps it will help you on your way. I wish you all the best with this kit, and hopefully you make a beauty of her.
regards,
Peter
Edited by Katsumoto
Glad you got the subdeck applied, and the painting looks good.
As mentioned, I have this in my stash.  If you can't find the instructions, I can probably scan them in and send the files to you.
Peter - I have definitely read your log. Your talent is amazing.
Gary - That was one thing I forgot to post. I did find the instruction booklet in the recycle bin. I can only guess they got picked up with some other trash and dumped. It's pretty strange, I don't usually do stuff like that.
Planking and painting continues. I should have the starboard side of the deck finished tonite. I can only paint the details on the ornaments for about 10 minutes. I start getting bug eyed after that.🤪
I did finish the starboard deck planking and started to move out from center to portside. I completely missed the fact that the deck at the #4 frame on the port side was totally askew from the frame. This is strange because I noticed this a few posts back and thought I had fixed it. Whatever!
Sorry, I should have made some pix to show my response. I have several lab squirt bottles and one is filled with 90% alcohol. This was useful in getting alcohol right where it was needed to soften up the glue between the underside of the subdeck and the frame surface. It took a lot of squirting, scraping, cleaning to get all the previous glue out of the way so I can try to reglue. After several dry runs, I did glue and clamp the deck again. From what I can see, it looks like I was successful.
I need to look ahead to see what other items I can be working on while the usual hull processes move forward. The ornament painting is fun but my eyes can only handle 10-15 minutes (under magnification) before they just go nuts. I may consider working on the ship's boat to kill idle time.
Thanks to everyone that is looking in. I expect things to get more exciting after the basic stuff (deck, hull) is done. Hang in there!
Decking is getting close to done but I am noticing something. Used to be I liked showing a heavy caulk line between planks. I guess I just liked showing the amount of work that went into laying everyone of those planks. I always used a Sharpie to get a good dark line. Seems like these days I'm not liking that so much. The Sharpie is a bit of overkill. Add to that it can bleed into the planks especially at the ends.
Looks kinda sloppy. Sanding doesn't get it all out. It's too late to change for this build but I'm going to be looking for something different going forward.
Painting ornaments continues but it seems like a never ending battle. Paint with gold one day and get some gold on the black areas. Paint with black the next day and get some black on the gold.🤨
I hate looking at paint work in images. It always looks so bad.
I did get the deck reglued to frame #4 but that has created a problem. I had to really clamp down the deck to make contact with the frame. So much so that the deck has a bow in it at that spot. Not sure what happened. The frame was glued in snug and at a good angle to the keel. Hope this doesn't give me problems down the line.
I should finish the deck this evening.
Talk to ya soon...
Maybe you could consider staining the deck a bit darker to reduce the contrast?  But it does not look that sloppy to me, and I think a lot of the deck will be hidden in the end.
Ye-haw - the deck is planked! I really appreciate everyones suggestions. As I mentioned before, using a Sharpie for "caulking" just doesn't work for me now (at least how I was using it). I used to outline each plank on all four sides. This really doubled the amount of blackning between each plank. I still want to get away from the Sharpie but at least for this build I think I came up with a decent solution. Nothing I thought up but I think I have seen this in other posts. Instead of darkening all four sides of a plank, I just did two sides, a long side and a short side (leaving two sides unmarked). Gluing an unmarked side to a marked side gives a more reasonable rendition of caulking.
If you check the port side you will see what I am talking about. Big difference. The other big difference, the port side (done after starboard) has the planking much more aligned, strake after strake. Rather than going with specific measurements (like I did on the starboard side) I ended up just eyeballing the lines on the port side. Guess I can trust my eyeballs..
OK - it ain't gonna' be beautiful, but I will get my mojo back before this build is finished🙂
Following the instructions, I continued on with planking of the quarterdeck face. That's my term - what I see in the instructions and inventory list is many of these surfaces are generically called "linings". For instance, I just finished the foredeck lining. Then the quarterdeck face is called the frame lining (very misleading).
I should have done a better job of shaping the bottom of the face planks to match the camber of the deck. I may run a stick across the deck butted up to the facing to clean that up.
While the glue is drying on the facing I took a few moments to think ahead about the coloring of my work so far. With almost any wood (white or colored) I almost always go to a natural stain for decking. The go to product is MinWax "Natural". It doesn't have any pigments in but it gives any wood a nice "wet" look.
The quarterdeck facing was done with the same Ramen sticks as the deck. I think there needs to be some differentiating tones between the two. I have a Red Chestnut and a Walnut stain on hand so here's what they look like - Red Chestnut on the left. I show the Britannia door painted in flat brown with the two stain samples. No real reason why the door needs to be flat brown. And of course, I couldn't possibly get this far without making a mess on the deck 😕
I think Natural on the deck for sure and Red Chestnut on the facing.
Suggestions?
Hey everyone. First off regarding the stain mentioned in my previous post - I decided not to go with a dark stain on the facing. After looking at the finished images on the kit box cover, there is some serious overhang of the quarterdeck. You can barely see the facing, so no reason to go overboard trying to make it look great. If I did use a dark stain on the facing the Britannia door would have to be painted some contrasting color or you would never see it.
Finishing up the facing, I trimmed the edges to get the even with the frame. The instructions make a good note about being sure there is still a notch in the frame for the quarter subdeck to drop into, so I sanded a little extra at the edge of the notch to get some good sharp angles.
There is also a gotcha that the instructions don't mention. The frames are 5mm ply. The frame where the facing is glued to has now become 6mm.
The notches cut out in the subdeck are 5mm wide.
No big deal to scratch an extra mm into the deck notch, but just be aware.
I'm also seeing that the last 3 frames are not equally level. The middle frame somehow got off kilter from the other two. I noticed this after attempting a dry fitting of the subdeck.
Hard to see I know. I'm trying to figure out how that could happen. The groove in the frame and the groove in the keel were a snug fit, so it's not like there was some slop in that fitting. And rechecking shows the frame is perpendicular to the keel.🤔 A poorly cut frame? Dang, I was bragging on the precuts earlier.
The dry fitting also shows it's going to be another fight to get that deck laid over the camber of the frames. At least it's only 3 frames this time.
Talk to ya soon....
Hey everyone - given the 1"+ overhang of the quarterdeck (once installed), I figured I better do whatever I want on the facing while it was easy to get to. So I painted that, glued the Britannia door and placed a coaming  at the facing base. I painted it all. I even decided to go ahead and stain the deck (Minwax Natural). I took some pix but then realized I probably needed to varnish it just to show it finished. So I've done that and will have final images.
One thing I did pick up that has been really useful is tack cloth, sometimes known as painters cloth. If you know what I am referring to then skip this. The product is something like a strip of cheesecloth coated with a waxy substance. It is fantastic at pulling up dust, grit, etc. from surfaces after they have been sanded/filed. It just picks up every last bit of everything before you paint/stain. All the big box stores sell it, I sure you could get it on Amazon as well. Highly recommended. It did a great job of cleaning up the deck before staining. Also works great on hull planking.
Hello Everyone - I think I am finished with the foredeck and facing. Although I have learned that when you paint/stain/finish early on in your build, you usually end up having to do some touch up down the road.
Last post mentioned tack cloth. Here's what I used and is typical of the product. Again it's great for picking up all the grit and grime from a surface before painting.
I won't bore you with 10 images of the deck but here I offer proof that it is finished 🙂
I'm seeing my pics are getting worse. I'm using a 15 year old point & shoot. Several of the manual controls no longer work. I'm debating whether to just pull out the big guns (my DSLRs) or look into a new P&S.
Anyways, it looks like fastening the quarterdeck subdeck is next on the agenda. I'm not looking forward to this. There is some serious camber in the frames and a dry run did not go well. The subdeck is going to have to bend quite a bit. The same material was not cooperative for the foredeck.
Hey Everyone - As I start gluing the quarterdeck subdeck I think I got lucky. Probably from at least 6 dry runs on the install. On run #1 I could see that the keel was not in line with the foredeck which obviously put all the quarterdeck frames out of line. After a couple more dry runs, I figured if I could get the deck and the first frame (the frame with the facing and cabin door) glued, I could bend the rear of the keel and the other frames would line up with the deck.
This exercise and the similar one for the foredeck would be better handled if you could get the Admiral or a Seaman to help hold things. It was incredibly difficult for me to hold and make an image at the same time.
Here is what the deck should be glued to.
Be aware that those frames need to be faired to provide a decent surface to glue the deck to. The instructions do not mention this.
So, after all the dry runs it's time to put the money down. Glue needs to be applied to the frames, the deck needs to be positioned and clamps need to be applied. I got really lucky and nailed that all in the first attempt. Without question, the dry runs made that possible.
Obviously I had to use pretty large clamps. Setting the hull down somewhere to let the glue set was not easy. I had to wedge the hull into a drawer and let the clamps hang outside.
And finally, I wanted to show the bend in the subdeck to match the camber of the frames. I couldn't get a perfect angle but this might help.
It's strange. The deck is plywood but only 2mm thick. But it just doesn't want to bend at all.
I want to give this first gluing (white glue) a full 24 hours to cure. Hopefully tomorrow I can get the rest of it done.
C'ya
Evening! - Here's a summary of several days work. Gluing the quarterdeck subdeck to the first frame worked out pretty well and the result looks OK. There was a decision as to whether to glue in succession the second frame then the third or the third and then second. I did several dry runs each way and then took a look at how the unglued frame would be affected. Given the fact that the keel was not straight and that whichever way I went there was going to be some forcing the frames into the deck notches I decide to do them in order.
The second frame actually went down pretty easy.
What I did notice is that there is a pretty big gap between the end of the deck and the transom. I assume planking will cover that.
This pic also shows the uneveness of the frames/keel. The starboard notch not quite making it onto the frame without some force.
Time goes by. The second frame glued pretty well but I noticed a couple of things.
There's a support on the transom that the deck is supposed to rest on. As you can see there is no contact between the two.
Even when I force it down there is not much contact area. This support needs to be faired just like the frames. No mention of this in the instructions.
Last frame glued.
Final result.
This is the camber in the frames I was fighting. It doesn't look like all that much but it did cause some grief.
To be sure all the dry runs made this step go a lot smoother. Not just seeing what happens to the frame you are working with, but what happens to the other frames.
One other note. Because I was not not totally sure how the frames were going to fit in the deck notches, I cheated and enlarged the notches a fair amount. It will all be covered by decking
Thanks for following....
16 hours ago, Dr PR said:
You did not "cheat." You improved the chance of success!
