Hi All,
I started this model last Christmas, sorry I have been so long in starting a log :(, but I was alsostill building the 'Norfolk'. Then the kit went back on the shelf while I finished the 'Norfolk' and I contemplated a problem I was having with the planking, that lasted for about 5 months!!
I finally got her out of storage a couple of weeks ago and have been slowly building again in between house renovations.
I have taken heaps of photos so please be patient while I upload them to catch up to where I am currently with the build.
I would like to make a few comments about the kit. The timber and laser cut parts are all of good quality, however all of the planks including the deck planks are walnut this makes for a very dark interior on an open model. I think they should have supplied a lighter timber for the deck planks as a contrast. all of the fittings are of high quality material although the bow figuere head does seem a bit large and akward. There were a few parts missing which I have replaced. I also have brought some extra blocks  and eye pins so I can fully rig the guns and some heart blocks to replace the 3 hole blocks they supplied for the forestay.
I intend to fully rig  the guns on the middle and upper gun deck and to rig at least the breeching ropes on the lower gun deck.
My plan is to fit the middle and upper gun deck after the hull has been completed so I can rig the cannons on each deck before fitting the deck above. We will see how that plan works out :o  :o
Here are some pic's of the kit
I will post some more pics later Enjoy :D
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
AL Swift 1805; Colonial Sloop NorfolkHMS Victory Bow SectionHM Schooner Pickle
Hello Jeff.
Look's like a nice kit.
Sounds like a good plan on the sequencing.
Keep the decks sealed from dust as you progress upward on the next deck's. Oil and stains collect the dust and it's hard to remove after. ):
Will follow this build as I like my cross sections and was looking at this one for the future.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Hi Anthony and Patrick,
Thank you both for looking in.
 Anthony this is the first cross section I've attempted so it will be a learning curve but I do like all the extra detail you get with a cross section of the different decks that you don't see on a normal model.  I hope you enjoy the build
Patrick , I have not seen a cross section of the stern in kit form but it would be interesting, maybe a scratch build in the future ;)
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Hi All,
First off acouple of pic's of the plans
They are basic drawings but give you the necessary dimensions
The next lot of photos is of the keel, frames and decks cutout also the assembly plan
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
The rest of the decks
And now the frames and decks dry fitted. These all fitted together very well with minimal adjustment required
Well that is all for now I will post some more progress tomorrow
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Hi Jeff,
I shall be following this with interest as I too am building this kit – although it is on hold at the moment whilst I finish my present build, the cutter Sherbourne.
Like you I agree that it is an interesting model, and that the interior as built is rather dark and drab, so I intend to paint a lot of it white. I am also thinking of some interior lighting. I intend to do quite a bit of kit - bashing, which I hope will improve it considerably, by fitting out the various decks as close to the actual ship as possible. Leaving off some of the planking on one side might also be an option. I have also decided to extend the length of the model by adding an extra frame, which will make her end at the break of the fo'c'sle, and am thinking of giving her a full-height foremast (the latter necessitating the former, to accomodate all of the shrouds and backstays). I have even thought of making her a waterline diorama (!) partly to do away with the rather awkward stand, but I shall have to think more about this when I resume work on her.
I am not too happy with many of the fittings supplied. For instance I think the figurehead is very poor, and the guns I will probably replace. I also believe there are rather too many pillars shown on the plans – and some are actually in way of the guns.
Anyway, enough about my bow section. I hope yours goes well and, as mentioned, I shall be following with interest.
Kester
Current builds: Sherbourne (Caldercraft) scale – 1/64th;
Statsraad Lehmkuhl (half model) 1/8th" – 1'.
Victory Bow Section (Panart/Mantua) scale – 1/78th  (on hold).
Previous build: Bluenose ll (Billings) scale – 1/100th.
Ahoy Jeff :D
Interesting subject, thanks for posting that great review
Looking forward to your progress
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Hi Kester, Jared and J.Pett,
Thankyou all for looking in and I hope you enjoy the build.
Kester I too intend to paint the interior walls and ceilings white on the orlop adnd the lower and middle gun deck. I think the upper gun deck walls were yellow ochre and the cieling was white, while the in the hold the walss were left unpainted  but the ceilng was white. That is based on photos of the ship as she is now from the official site but she may weel have had a different interior colour scheme at the time of Trafalgur.
Your ideas to modify your kit sound great :D  but I don't think my skills are up to that stage yet so I will build this one pretty much as comes out of the box with a few modifications as I go along.
The figure head is the one part that I may change when I get to that stage. i have heard that the Caldercraft one is very good and much closer to the correct scale.
Jared your seat is reserved :)
J.Pett thank you for your kind words :)
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Hi All,
After dry fitting the frames and ensuring a good fit the next step was to roughly fair the first three fames and the bow planking supports because I would not be able to support them properly once they were glued to the keel and it was easier to shape the bow planking supports before fitting them.
I then glued the frames to the keel. The first frame was squared to the keel, glued on and allowed to dry then the other three frames were glued on using the decks, which were temporarily pinned and clamped to the frames to keep them square.
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
While I was waiting for the frames to dry I made up the magazine store which will be fitted to the hold deck
It was then planked with 0.5 x 4mm walnut strips
And finally the door was made up and fitted
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Hi All,
After the frames were dry I faired them some more, very carefully, with a smooth file.
As I said before I am going to paint the inside of the hull so my next job was to mask up and paint the frames before all the decks are fitted. the walls of the hold deck and the area below it, the bilge, will be left natural timber. So the frames in this area will be stained with a walnut stain.
Afte masking up the frames I glued on the false deck for the hold and then painted the frames.
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Jeff,
Looking good so far, and it's probably a good idea to paint various parts before installing them, when you then can't get to them easily – like the frames.
Btw, have you any of the books on the Victory, that you might use for reference. They might help the rather poor instructions (nothing new there).
Kester
Hi Kester,
Yes I do have a couple of reference books to help me . I have C Neapean Longridges 'The Anatomy of Nelsons Ships' and John Mckay's 'Anatomy of the 100 Gun Ship Victory', the latter gives an excellent breakdown of each deck, which does differ somewhat form the model.
I agree that the instructions are poor in some respects especially when it comes to the rigging they are also some what confusing in the build sequence.
I will try to paint as much of the interior as I go as some spaces will be impossible to get to when the planking is finished
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Hi All,
Just A small update to complete the hold deck. It was planked with 0.5 x 4mm walnut strips in a 2 butt shift pattern, I will follow this pattern for all of the lower decks as you won't be able to see them once the model is complete however i will do a 4 butt shift pattern on the fo'csle.
The deck waas then sanded and the magazine store was fitted
Also as you can see in the last 2 photos the lower frames have been stained with walnut
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Hello Jeff.
Looking real nice and you are a fast builder.
The kit looks really nice from the pictures you have posted :)
Keep up the good work and plan ahead.
Regards Antony.
Completed Mayflower
Hi Anthony,
Thank you. I'm really not that fast a builder as this part of the build was completed earlier this year before I put her into hibernation while I finnished the Norfolk. Sorry for any confusion :(
I am currently just finnishing off the first planking and hope to catch up with that stage here soon :)  :)
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Hi Jeff,
Magazine is looking sweet.  Is there a lot of 'furniture', fixtures and fittings on the decks? these are thetype of things I like doing most on a build.
cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Hi All,
Once the hold deck was complete 3 coats of clear varnish was applied to the deck of which I thought I had taken a photo of before the next deck was fitted, but if I did I can't find it :o
So it is on to the next deck the Orlop. John Mckay's book shows a single companionway leading from the Orlop deck to the hold but the kit has 2 companionways going down. I have decided to stick with the kit version as I said in my opening post that this would be an out of the box build with a few modifcations.
I lined the companionway openings with 0.5 x 4 mm walnut and the sanded them down to the thickness of the false deck. This was not in the instructions but I did it to cover the ply which would be seen when finished.
The next job was to paint the underside of the false decks, the ceiling of the hold deck.
The deck was then glued on ensuring the mast hole aligned with the deck below
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
The fo'csle was left temporarily pinned for stability of the upper frames and to check the mast  alignment with the lower decks
The deck was then marked for planking and the planks laid
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Hello Jeff.
Are the faces of the frames/bulkheads faced or is it plywood ??
I see you are also a fisherman .. The weights are a giveaway :)
The last photo really shows the decks camber nicely.
Well done. Will keep looking in on this build.
Regards Antony.
Completed Mayflower
Hi Jeff,
This is an interesting build which I will follow closely.  Been thinking seriously of taking on a build like this as space is a premium.
I have loads of questions which I wont ask because the answers will become evident as you progress.
Your doing good work here so keep it up.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hi Anthony, Mobbsie and Patrick,
Firstly thank you all for your kind words :D
Anthony, the frames are just plywood although I don't know what type :( and yes the weights are a bit of a give away but sadly i have not had much of chance lately to use them what they are intended for :(
Mobbsie , Space to display the model is one of the main reasons I am doing this kit. At the moment I am living in a small 2 bed townhouse and space is a bit of a premium but it also an interesting kit.
Please ask as many questions as you like I just hope I can answer them :o
Patrick, No I don't intend to frame below the decks. I would consider doing it if part of the decks were going to be cut awayand the planks left off but i wont be doing that on this build
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
Hi Jared,
The hinges are made form 2 pieces of 0.75mm brass wire and the door knob is the round head of a brass nail.
Sorry the door is not fuctional
Thanks for dropping in and for your comments :)
Jeff,
Thanks for the info about the door knob and hinges. No need to appologize that the door isn't functional. I was just curious.
The build is looking great! Thanks for sharing the updates.
In Progress Build:
Robert E. Lee by Scientific a.k.a "The Bob"
Completed Build:
Swift 1805 by AL
-Jared
