A friend of mine saw a person about to throw out a model of the Berlin into the garbage bin. He grabbed it and brought it around and gave it to me. It is in a pretty poor state but I am detirmend to rebuild it. I have been looking at a Berlin build by Ferit Kutlu. Have included a photo of my HMS Victory by Jotika. 4 years and just about finished, life boats and that's it.
Will keep you all up to date as I slowly rebuild the Berlin.   John Edwards
Hi John and Welcome to MSW
Looks like you have a bit of challenge ahead of you with the Berlin although from the your photos the hull looks to be in fairly good nick. Was it complete model broken up when it was thrown out or in pieces already?
Good luck with your reconstruction of the Berlin.Going on the job you have done on your Victory I don't think you will have much trouble repairing the Berlin. I will follow your build or should I say rebuild with interest
Your Victory looks fantastic it looks like you have done a very professional job with her and is that the Corel cross section next to her? The two together  make a very interesting display
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
AL Swift 1805; Colonial Sloop NorfolkHMS Victory Bow SectionHM Schooner Pickle
I applied a new deck using walnut strips that I found in my collection of timber. The hull was re planked and I removed a section of the forward top deck so I can mount the 2 front cannons etc, making it a lot easier.
Edited by blueyAU
A very interesting resuscitation project - good luck!
hamilton
Finished the new hull planking,Also a couple of pics of the Berlin I think it is called a diorama. I built this a few years ago and found it in my trunk with a few other bits and pieces. Will have to have a good clean up and see what else I have put away.
Just about finished the hull planking etc, and have restored the forward decking.
Can anyone assist me in the coiling of the rope for the cannons. Am using 0.025mm thread which is pretty thin.
Looking great!
hamilton
I am waiting on some 3.5mm double blocks from England so I can finish the cannon rigging. So I am doing the rigging and assembling the masts. It looks a bit of a mess but will eventually start to look ok.
Hi John,
Very nice re-work.  Keep it up.  You're doing a fine job.
Hi John,
She is coming along nicely.
If you are still after an idea to make rope coils there are two differnt methods I use, the firet if you want a stacked coil is to wrap the rope, four or five times around a small cylinder, like a pen or piece of dowel and then clip the ends with an aligator clip to keep them taught and then give it a coat of diluted PVA glue let it dry and slide it off the dowel.
To make a flat coil I use two 25mm square pieces of plastic card about 0.75mm thick,Ipierce one side with a dress makers pin and insert the rope through the hole then insert the pin to trap  the rope cover the surface of the the plastic with Diluted PVA glue and thea push the pin through the second piece of plastic to form a sanwich, coil the rope in between the two pieces of plastic to the desired diameter and let it dry. Pull the top off and you should have a nice rope coil which can be easily adjusted to your requirements
I did have photos of this process but I cannot find them at the moment. I got this idea from another modeller 'pompey' on the old site
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
  • 4 months later...
