Interesting little build you have going on. I don't like that kit supplied rope either. I think I'll change it as well. Good job, looks neat.
Regards, Scott
Completed builds:
Awaiting construction:
I bet the tea would do a nice job, just about as realistic as you can get. It dosnt stain even and goes patchy slightly which I think is realistic.
Regards, Scott
Completed builds:
I used the darkest blackest tea leaves I had. Brewed a very strong cup and dunked the sails in it for about 10 minutes, swirled it around and rinsed under cold water and washed with soap to neutralize the reactions. Tea is full of tannins.
The rope is a joke. I used the .80mm only for the anchors and all the rest of the rope came from the Syren M.C from C. Passaro.
This kit is heavily bashed. Lots of items and where they are placed are not correct. I used some of my Dutch language books of flat bottom boats to compare and the book on the Statenjacht Utrecht. Then there are numerous paintings on the NET from Willem van de Velde and the Elder and they have detailed paintings from VOC ships with Staten and Royal yachts.
Marc
Started on the shrouds, I use hemostats the pinch the ropes together around the dead eyes so I can serve them.
Once all the dead eyes are in place, I connect them and use small clamps (weight) to keep the rope taught. Then I adjust the rigging so shrouds are not too slack, the mast is as straight as possible and the dead eyes are even. Once it looks good, I will complete the shrouds.
I use little levels to keep the boat straight. Of course the work table has to be straight as well.
Completed sails with bolt rope, clew lines, blocks, roping, spars and a gaff.
Nice one Marc,  you are wise in using Urecht.  I never trusted Mamloli's plans..  To bad I cannot see it up close.
David B
Just finished the rigging, turned around and my sleeve from my elbow caught on the flag staff on the jib.... sheered it right off.  Then turn around and do it again and this time I break the top of the mast................... AAAAAARRRRGGGHHH   :angry: :angry:
Calmed down, repaired the jib and looks like new.  The mast is a different story.  I did fix it but that took me an hour or so.  I have to be careful.  But then it is wood and can get fixed all the time.
So I finished all the sails and on the drawing of where the sails are printed on they are an exact match.  Stitch the main sail to the gaff and see if the gaff fits....... not at all.  I look at the sail plan with rigging drawing and the sails are a different dimension.  Compare both sheets of plans.... and boy... it is completely different.  Non of them are the same.  Main sail is off by 2cm in length.  What did the drawing man do?  Is he on meth?  So now I have to improvise.
Like I said before, MAMOLI's plans suck big time.  Nothing on CAD, it is all hand drawn.  Descriptions are a joke. So far this kit has been bashed for about 75% and it increases all the time.  The rigging, and sail plan look very much like the Utrecht.  This is Ok as this did not changed much with a century.
The Mary is from the mid 1600 and the Utrecht from the mid 1700.
I feel all better having discussed my booboo's and frustrations.
Thanks for reading.
Marc
Marc
very nicely built yacht, Looks great, would love to see the sails rigged
Well done !
Nils
Current builds
-Lightship Elbe 1
Completed
I am glad you were able to fix the booboos.  The last time I snapped a spar it took me a week to repair the damage.
David B
Marc
Well done !
Nils
That will happen as I always add sails. If there are no sails the boat looks rather naked.
Marc
David B
Mine just broke off. I put a sheave in the top of the mast to make it look real (like Doc did with his long boat in the club). There was too much wood eliminated so the strength was gone.
Where the sheave was I put a combo of wood putty and CA. Molded it quickly and then wrapped rope. Same idea that I did with the main mast to the flag staff. Drilled a hole in the mast for the topsail. No sheave.
I'll take pictures.
Marc
As I mentioned before, I broke the top of the mast because there wasn't enough wood as I had built a sheave in it.
The repaired mast. Got rid of the sheave, molded wood putty in the hole and wrapped it with roping. This roping is all along the mast so it doesn't look that awkward.
I read a long time ago that you can use clear nail polish on the ratlines and I have used it on every ship I've built that had ratlines. The clove hitch doesn't come apart and it is virtually invisible to the eye.
The rigged heart block.
Standing rigging is complete.
I finished the topsail with the clew lines and the lines (that I don't have a name for). They are tied as half moon shapes on each side of the top sail.
The directions only show one side on how it integrates with the rigging. I went to the Frisian maritime museum http://www.friesscheepvaartmuseum.nl/ and looked at there ship models as well as there paintings. Also I came upon a model where it clearly shows how it is rigged.
"This model is ALL mine".
Looking good Marc,  How are you going to prevent a repeat?  That area looks very fragile.
David B
Thanks, Dave. I am trying to be very careful. So if I need something on my table and it is behind the boat, I need to STOP, Think, Look around, move ship, get item, bring ship forward and work on it.
Marc
I am working on the running rigging and attaching the sails to the roping and masts. Adding more rope where needed as I go.
Just a close-up from the standing & running rigging.
I use toothpicks to keep the ropes taught and this is temporary. I tighten here and there so it is just a matter of removing the toothpick, pull the rope a bit and put the toothpick back. I will do this until everything is taught, even and looks good. Then the roping will become permanent.
For dgbot - First picture, lower right corner - I broke off the flagstaff. I'll just wait till I finish the rigging and start on the flags.
Marc
After seeing "egkb" serving jig, I decided to make one as well. For this idea to materialize I give ALL the credit to him. :)
All items except the LEGO gears I already had in my collection or scavenged from other items and all pictures give measurements and descriptions.
Purchased 2 sets of LEGO gears from eBay. I did 2 sets in case I made mistakes with enlarging the hole for pulling the rods through (and I did make mistakes). I used 4 - 40 tooth gears for connecting the rod and tubing together and 2 - 16 tooth gears to act as nuts on the brass tubing.
The brass tubing is from my R/C pile and the metal rod is from an old cloth hanger. Basswood is used for this jig.
Attached LEGO gears. Top gear has a brass tube for serving rope and the bottom gear holds the metal rod. Same setup on the opposite side of the jig.
I cut up 2 - 1/2" brass tubing to act as a sleeve for the metal rod. This was hammered into the 2 holes where the rod goes through for a tight fit. The metal rod turns smoothly.
For serving roping can be pulled through the brass tubing. This is essential if the rope is longer than 12" inches.
Optional alligator clip attached to a rod which fits into the brass sleeve for serving blocks, etc.
Picture says it all.
Edited by flying_dutchman2
This time I decided to omit the flags that come with the kits because, a. - they are one sided print and b. - they never fall correctly.
I am doing it from a handout from Gus Augustin - Equipment needed to make flags.
You make them from paper, fold them, wet them to take memory out, paint them with acrylic, fold them and you have a flag.
I make more than one so I can chose the best one and as the brochure says, it is cheap as you use paper and you get better at making them over time.
The brochure
Drawing the flags.
Using a light table jig to draw the other side of the flag.
Folding the flags
Soaking them in water.
Folding the flags after the water and drying.
Ready to paint.
Finished flag.
Nice flags Marc. I think you have got the hang of it.
David B
Thanks. It is difficult to get straight lines but then if I fold them correctly you may not see that. Kurt mentioned that if I keep practicing they will get better over time. That is why I made several this time.
Some people air brush the flags, I can't figure out how they do that.
Speaking of airbrushing, Kurt gave a workshop on that. Are you getting the pdf's on that? What ever you need, let me know.
Marc
A great build and a truly lovely model Marc B)  B) I don't know how comfortable I would feel though with one of my cats in close proximity to one of my models
Kind Regards
Nigel
Currently working on Royal Caroline
Kind Regards
Nigel
Thank you Nigel. I enjoyed building the model. The Mary is a practice yacht towards my next build, the Staten Jacht - Utrecht. My 1st scratch.
The cat (Boomer, 21 lbs, and thinks he is a small dog). Wants to be everywhere I am and in the hobby room he has a basket right next to the wood. When these pictures were taken he has to be there, and will always stare at me, because he knows that if he paws the rigging and I notice it, his ears go back, jumps on the floor and hides.
Marc
Marc,
This yacht you build is very nice!  I like this type of ship particularly because it was the first wooden model I made (being eleven years old).  My parents were a bit doubful at that time, and I broke a lot of saws on it - but I did it.
And the model still excists (though it neads some repair now - ca. 40 years later)..
Hans
Owner of Kolderstok Models - 17th century Dutch ships.
Please visit www.kolderstok.com for an overview of the model kits available
