Muscongus Bay Sloop by pete48 - FINISHED - SMALL
Pete:
You are making good progress. Once it is all trimmed up, I think it will look fine.
Russ
Link to comment
Share on other sites
Thank you Russ, I belive youre right,
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
On Keel 3 I took some strips that I had stained a few days ago, I soaked them in rubbing alcohol (about 30 minutes) and bent in Ribs between the frames. They have not been glued yet. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Wow didn't realize your moved over to scratch build with keel 3 and 4. Beautiful work, and some nice engineering on the center board and rudder. I'm with Russ on that sheer line. This boat has so much character. Have you considered changing scale and building a monster 1:12. That would be a really nice display and would help in detailing.
Whatever you do, its good to see your having fun and I cant wait to see what next.
Link to comment
Thanks Keith, Originally I was thinking of a bigger scale , I then decided to build the boat I've always wanted (The Herreshoff Buzzards Bay) and build it in a  3/4" = 1'- 0" Scale so that if I choose I could take it for a sail. ( I will be building a display version with all bent frames)
HI Harv, The frames are not to scale (about a 1/16" to large) the spacing in the cockpit is correct(Chapelle Drawing) (I still have to glue them in so at least the rib spacing will be accurate)
Edited by pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
This Morning has been exciting so far, as I am setting up the Frames on Keel 4 , I thought I would show some pics before I glue it together . I always set my base level to the waterline, That way all the frames are plumb to the waterline. (just remember square is square and Level is Level) Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
On Keel 4, I got all the frames and the transom attached ,and stained the bow side of frame 1 (i did not like the way it looked in the photos from this morning) next, I will bevel the rabbet line (bow) install the ribbands and keel strip. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Pete, your work on the keel # 4 looks great.
Michael
Link to comment
Thank you Michael, This Boat is going together very smoothly. and right on the money, I am very pleased
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
On Keel 4 today, I installed the ribbands and keel strips , then a quick check of the centerboard, To make sure the keel strips were not installed to tight around the centerboard box. And the Centerboard still works properly. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
So far it all looks good. Nice job fairing the hull.
Russ
Link to comment
Thank you Russ, I am enjoying building this one, and it was a challange to keep the open frames square and plumb, (1and 2) while installing the ribbands, It worked out well
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Pete this is very interesting I am following with great anticipation.
Michael
Link to comment
Thank you Micheal, Now that I have finished the kit and 1st scratch (Keel #1 ) I can focus on these 2 boat's more (and my Herreshoff)
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
My Internet was down last night, so here is the progress that was made on Keel 4 , all the frames have been Faired and is now ready for planking, On this one I am going to use 1/8" strips for planking ( I used 1/4 " on the previous builds) I am happy with the results thus far on Keel 4. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
As the Holidays  approach , the build time becomes less time. On Keel  # 3  I installed the deck and trimmed the excess wood off the transom ,I then Installed my make shift rudder and tiller to make sure all is functioning properly, ( It does) and that tiller and rudder can be easily installed and removed from the boat  . (also works well)I also cut out for the companion way hatch so you can now see the figured Birch on frame 1. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Very good progress. The hull is coming along nicely.
Russ
Link to comment
Thank you Russ, Now that the deck is on, I can finish fairing the Hull and she will really take shape
Best Regards,
Pete
Edited by pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Today, I actually got to get some work in on keels 3 and 4. On Keel #3 I finished fairing the hull and installed the Cutwater. I also got the first coat of varnish on the hull. On Keel #4, I started planking the Hull, I went ahead with 1/4" for the first or top plank and I am using 1/8" the rest of the way Here are the results
Edited by pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thank you Chief Mac,  once you get bitten by the bug your shipyard will change
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
On Keel  #4 Today, I  got more of the planking installed ,  I am very pleased with how well this boat is going together, Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Watching the progression of these boats is fun.  Hope it’s fun for you as well.
Bob
Current build:  SS_ Mariefred
Link to comment
Thank you Bob,  Its the most fun that I have had in years, I am glad that everyone is enjoying the builds
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thank you Jakob, This Build Keel # 4 is going together so well, so I went with narrower planks 1/8"
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
The base Varnishing (3 coats) on Keel # 3 is complete. I am happy with the way the transom turned out Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thank you Russ , Minwax makes a great product that is easy to work with
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
