Thanks Michael...once the hull got painted it looks more together.   I have lots of mahogany sky lights to make and access hatches.
So I'll begin to make the 6 capstans and the fife rails.  This ship carried 6 boats....but I think I'll only place 3 to keep the clutter down.
Thanks for viewing.
Rob
Current build:
Finished build:
Current build(On hold):
I test fit the hull back into the water......I'm thinking it's looking pretty good.
Current build:
Finished build:
Thanks kindly good sirs..
In my experience I either do OK or down right nasty.  Water must be felt and almost emotionalized IMHO.
Current build:
Finished build:
Well played Sir! Well played indeed ;)
Bill
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
Thanks kind sirs....
Current build:
Finished build:
Well today was, *Make the figurehead day*...so I got the picture I needed...a block of basswood...surgical knife, high speed handpiece, sand paper, paint and.......Here is the picture first.
Current build:
Finished build:
Then my 3/4" tall creation.....After looking up close...my painting is awful. My eyes are going I guess. Best these old eyes and hands can create.
I'm not a very good people carver....never have been.
Rob
Edited by rwiederrich
Current build:
Finished build:
And I mounted it...still need to clean things up a bit.
Current build:
Finished build:
Hey Rob, what do you mean "your painting looks awful."  These figure heads were not made by Michael Angelo you know  :)
I think it looks terrific and watch out for that "old" word, not a good word to use when other "old" people are around - - - me  ;)
In any case, I like it and like your build.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Thanks Piet,,,,,,I'm just saying I'm doing the best I can,,,with eroding abilities.  Dang you aging..dang you all to heck. :cheers:
I touched up the figurehead and some black paint....and painted the yellow medal bottom.
Onto the deck furniture.
Again..thanks.
Rob
Current build:
Finished build:
Another mounted view......
Current build:
Finished build:
It seams the smaller the easier for me....I tried larger carving and they always end up in the trash. More detail, requires more skill at the human figure.....
Onto the deck furniture, railings and such.
Rob
Current build:
Finished build:
I'll post a few more images thus far.......here are some from the other side of the diorama.
Plowing out of the wave.
Current build:
Finished build:
Another open ocean
Current build:
Finished build:
And climbing out of a trough at the crest. the impression is that the ship is cresting a huge wave and the trough is just ahead as smaller waves break along her sides......
The Holidays are slowing me down a bit so postings will be sparse. Have a Merry Christmas everyone.
Rob
Current build:
Finished build:
The lower masts will be made, then strapped..this takes a bit of time.  I will use raw dummy masts so I can properly locate the fife rails.  The McKay didn't carry stun sails so those can be omitted.  I have lots of railing to add and unlike the Lightning the McKay had turned wood stanchions instead of iron ones...so I have that to work on as well.
I think the effect will be convincing and dramatic...you have the model...then you have her in her element......in a big way.
Thanks for looking in.
Rob
Current build:
Finished build:
Stalkers are good.....
Especially if they love clippers too.......
Rob
Current build:
Finished build:
Today I worked on the lower masts. The mast for the Glory of the Seas were made on the mill and were quite laborious....I didn't want to go that route this time...So I tried gluing the 5 pieces to together adding the blocking of the straps.....I turned on the lathe. Not so good....the extreme edges kept getting knocked off and ruining the mast as I began to apply the cutting tool....I then opted to sand on the lathe instead....same result.
So I opted to build a table saw for the job....Using some ingenuity, I adapted the table saw to one end of a dental Baldor bench lathe. This meant I needed to mill the housing and attachment bracket.....get some good blades...make the keepers and secure stock and table.
Walla! done. It works beautifully and made the cuts in the masts exactly as needed.
So first is an image of the defunct lathe attempt mast. Strapping had not been done...just the tuned mast.
It's the dark brown one.
Rob
Current build:
Finished build:
Today I added the band wedging to fill in the slot created by made masts and the copper bands.
I'll sand and stain them and varnish.
Current build:
Finished build:
Worked on the mizzen mast and I finished the lower built up mast with weathering and paint/varnish.
Current build:
Finished build:
So for one lower mast...I had to:
Cut 4 lengthwise grooves to represent the outer 4 beams.
Build and apply the 36 ring wedges under each ring and in each groove.
Cut and apply copper banding and glue secure.
Paint banding black.
Add chain lift.
Stain/varnish/weather.
Build, apply cheek supports and tops and paint white/weather.
Lots of work...then required for simple dowel or straight stick masts.
But the effect is much more attractive and accurate.
Rob
Current build:
Finished build:
Your mast looks great Rob, well worth the extra effort.
Merry Xmas to you and yours.
That's right Grant. Over riding the desire to go the least path of resistance.....means I had to invent and build a table saw explicitly for the job of cutting in the mast grooves.....and go through the extreme lengths of making the numerous *wedges* to support the rings in the grooved area. Similar to the masts on the Glory of the Seas....cept I milled those...and it was very arduous. This method worked out faster and a bit easier(Once I built the table saw).
Plus these masts are varnished wood...NOT painted as in the other masts I built. Can't cover up that multitude of sins with paint...... :)
Merry Christmas to you and yours as well.
Rob
Current build:
Finished build:
Captain...thank you very much...Montague Dawson is one of my favorite ship painters. He captures the essence perfectly.
I wanted to attempt to do the same in a 3D diorama. I think I came close......anyway.
Again...thanks for the ample likes and fine comments
Merry Christmas.
Rob
Current build:
Finished build:
