HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
thank u challenger86   there is no need to rush slow is the best way take your time jpett has a really nice build going on with hes vic as well look at the diff log on the same ship if u can find some books on it that will help as well
hello all in this pic u will see i have done some more planking at the mid point i know its a diff kind of wood but it is the same size wood as the walnut.  i was short the walnut in the kit so iam strips of wood from  constructo thats all my hobby shop can get .so far all is going well i will ad the wales after iam done with the planking stage. is u see something wrong ples let me know thank u all
post-2052-0-65000200-1418203484_thumb.jpgpost-2052-0-58798400-1418203489_thumb.jpgpost-2052-0-92911200-1418203494_thumb.jpg
Hey dragzz. It's looking great. I'm sure that different colored wood won't make any difference below the water line as that will eventually be painted over I assume.
Regards, Scott
Completed builds:
Awaiting construction:
looking very nice Dragzz.......you can always stain to match the upper wood,  what isn't going to be painted or coppered.
if you can though,  try to get away from those 10 mm brads........see if you can get some push pins,  the long slim type if you can.   your going to end up having to do a lot of repair work when your finished.
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Dragzz, changing the subject from planking, I want to through something at you to be thinking about. I have not figured out my approach. Maybe you might have an idea.Between column line 5 and 7 there are gun ports on the lower level. The area under the deck on the bulkhead is going to be hard to finish.
Dragzz, I'll be following your fine work;  I have a scratch built Vic along with my Cutty Sark... We may have to compare notes...
Bob
here is some more pic to wear iam at now hop u all like . this the last of the planking 15 more strips thats will be it for the planking thank god
post-2052-0-42100300-1422351488_thumb.jpgpost-2052-0-38744800-1422351493_thumb.jpgpost-2052-0-63069400-1422351498_thumb.jpgpost-2052-0-43227900-1422351507_thumb.jpgpost-2052-0-17598100-1422351514_thumb.jpg
just thot id let u know iam still here lol
Edited by dragzz
very nice progress.......gonna look great with a copper bottom  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thanks popeye yes iam going copper plate the bottom it should look real good when its all done just have to wait till  it come in .but there more to do till then. more pic soon
planking so close to be done iam 4 planks a ways from it wow thats take a long time to get done but iam all most there now i can see the light at the and of the planking stage lol  i will post some pic real soon
here in this pic iam putting on some of the raised wales  so far its gone well looking good so far there will more done tommorw and the planking is now all done what a job that part is wow here some pic
post-2052-0-01154800-1422681301_thumb.jpgpost-2052-0-50976200-1422681306_thumb.jpgpost-2052-0-83224500-1422681318_thumb.jpg
  • 3 months later...
hello all i will be posting pic  of the victory real soon as i get more done to it . still working on the gun ports its slow going on the part
here are some pic of the back that i have been working ok used a little filler just to smoth some ruff spots out still have so more sanding so afr it looking good
post-2052-0-72442100-1431744708_thumb.jpgpost-2052-0-32468900-1431744717_thumb.jpgpost-2052-0-82440200-1431744721_thumb.jpgpost-2052-0-76340600-1431744728_thumb.jpg
Hi Dragzz
Just been looking at your build so far, doing a great job keep up the good work.
There is one thing that I feel I should ask about and that is the sweep of the deck at the forecastle in the pictures it looks like it has too much making the deck to high.
Not sure if the part numbers are the same as I have much older plans but does the part number 66 pressed wood fit at the breakhead bulkhead.
Sorry if I am wrong.
Harvey
Current Build: HMS Victory
hello harvey iam not to sure about that i will look that up tommorw and i will get back to u on that ok
