This is my first attempt at scratch building, having kit-bashed a number of models. I work as a Museum Guide at Plimoth Plantation, which includes Mayflower II. During the off-season, I work in the Marine shop, doing routine yearly maintenance. As such, I have access to the Mayflower as well as her shallop. I will be using plans by William Baker, the original Naval Architect of the Mayflower II in 1955. The scale is 1/24.
The vessel was a 33 foot work boat that could be rowed or sailed and was common in the17th century. The Pilgrims cut the vessel into four pieces and stowed them on the orlop deck, where the passengers lived. Upon arrival in Provincetown, the shallop was re-assembled and used to explore the inner arm of Cape Cod, eventually landing in Plimoth.
The pics show the plans and a building board. In the background is the almost finished mast.
At this point I'm waiting on wood from HobbyMill, due at the end of the month, so, that's all for now!
Rick
I'll follow your log. I like those small boats.
Regards Christian
Interesting build and beginning. However, I'm curious as to how the rudder will turn: the pintles appear to be well out of line with each other.
Yes, welcome to the darkside.  With such fine drawings you should have fun building this lovely lapstreak boat.
Bob
Current build:  SS_ Mariefred
I saw two drawings with the pintles inline and one where they appear not to be. I suspect he'll have to reconcile some views to make things work properly. She'll make a nice little boat when done though.
Thanks all for the comments.
Druxey and Sailor, I noticed the discrepancy regarding the pintles, also. Must be an error on the plans; the prototype works fine.
Bob, the boat was built at Plymouth Marine in 1956. For some reason, the yard decided to build her carvel planked. I'll be building her " as built" so carvel planking it will be!
Rick
I just received the wood from Jeff at Hobby Mill. Jeff did a great job on the wood; accurate dimensions and well packaged and labeled. New posts to follow as I start making saw dust.
Regards,
Rick
Rick
While waiting for wood to arrive from Jeff, I worked on some small details:
Oars turned on my Proxxon:
Mast and Sprit:
Winch:
I'm working on the rudder and lee boards.
The wood has arrived! Next up, the keel, stem, and stern post.
Rick
Rick
E&T,
the plans don't show many of the details on the prototype. Fortunately, I have access to the 1957 build. On Tuesday, I "dressed" the shallop mast' arranging all the shrouds, stays, etc. for up rigging. For example, the plans show the boat as clinker built, but the original is not.
Regards,
Rick
Rick
I've made some progress while waiting for some help on lofting the frames. Does anyone know of a clear practicum that I could use?
The keel, stem and stern post are waiting for the frames
The rudder is complete
One of two lee boards
How do I post pics directly above the pics?
Regards,
Rick
Rick
i just type in the box (like here)
then pick "More Reply Options" below on the right
this opens buttons to add pics (attach files)
Alan
Alan O'Neill
Thanks, E&T. I've been delayed in the build because I've been spending much time on upriging and bending sails on the Mayflower II in prepration for a sail in two weeks for a documentary film.
More to come in a couple of weeks or so....
Rick
Rick
  • 6 years later...
Unfortunately, I developed some health issues that effectively ended my ship modeling hobby.  I now only enjoy visiting MSW and seeing the build logs and beautiful ships finished.  I still work on Mayflower; she recently returned to Plymouth after a 3 year restoration.
Rick
Not going to like that post, Rick.   I'm just glad you can still visit us and work on the Mayflower.
