Hello Rich..I just had a chance to review your log and can tell immediately you will build a very fine ship.  I am happy to see another builder of the HMS Victory and will enjoy my deja vu.  Keep up the great work..
Jerry
Hello rich
Good that you have got your quarter galleries sorted. You can if you want leave them without the skins on until well on into your build if you want. Have a look at Gil middletons log page 2. It saves the chance of any damage during the next few years. Keep enjoying yourself. DAVID
Just a small update,  I have been reading the manuals, and looking at other build logs to get a idea of whats next on the to do list..
The Lower deck planking between 4 & 12 bulk head, I wanted to make sure that every plank will be the same, (although i'm guessing this part will not really be seen) so I'm going to use this time and space to try out a few/new ideas,  I,m going to try tree nails
I made a little jig to cut the 80 mm deck lengths (if this is wrong size please let me know) also made an extra bit if I have the need for 40 mm (half) and then after we had been shopping, a nap and lunch, Lol, I thought of a jig for the tree nails,
I'm happy how this has turned out, and how the few planks I have glued in look, (Will edit picture of this in a few days)
Rich.
Builds in Progress:   HMS Victory
Completed Builds:   Constucto Enterprise
Future Builds 2021/2022 USS Constitution
Thanks to everyone that stops by.just a small update, I have finished planking this lower gun deck, I think it looks ok, im not over happy but as your not going to see most of it, im going to rub it down over the next few days as i have noticed a few wood shards,
Rich.
Hi All thanks for the likes, :)
Hi David, Page 10? (had a late call out, with a a 3hr round trip, and now back to work) is it worth a redo ? considering in not seen?
Hi Sam, I thought it worked out Ok, Although, I think I know what David is speaking of, if so not sure if this will be completed on the upper decks wait and see.
Rich.
Not much of an update, as haven't done anything this week been to busy at work, I'm not sure to start the 2nd planking or gun ports, oh the choices :
:huh:
David, I found out what you meant by pg 10,
""If you wish to accurately represent the plank length and four butt shift system used on Victory, each plank should be either cut to length of 85mm (approximately 20ft or the planks can be laid full length and scored with a craft knife every 85mm, this latter method often looks the most convincing at this scale. The four butt shift system simply implies that the end of each neighboring plank is offset by 1/5 of twice the length of the planks (34mm) such that the end of every fifth plank athwarships only is aligned (ie separated by four plank shift)""
Once i figure this out ill do this on the upper decks..
Rich.
Thanks Everyone for Likes
David, Yes coming alone nice and slow, reading searching before i do anything,
Mtdoramike,Thanks for stopping by,
                  It's made by UK company JoTika Ltd    Added the link for you, I searched other HMS Victory kits, and this, although the most expensive, it holds the most accurate and highly detailed out the one on the market, just depends on your level, and what you want out of the build.. this is my 3rd build, and i very happy, although some what nervous of what lies ahead.
Rich.
looks, promising, How what wil be the final size, 1:72 seems pretty big for her. You are so lucky to live near her, I always wanted to visit her, the story behind her is so amazing.
Hello Rich
although I am not so much a friend of the Victory (love more the German vessels like Friedrich Wilhlem zu Pferde, Berlin, Wappen von Hamburg) I have to say: Respect, congratulations so far. It is not only a enormous ship but also an impressing model. I will look by sometimes to see your progress.
Best wishes
Max
Next: Friedrich Wilhelm zu Pferde by Euro Model 1:47
Finished: Half Moon Corel;  HMY Royal Caroline Panart; HMB Endeavour Occre 1:54; Fregatte Berlin, Corel, 1:40
A life without dogs is possible... but worth to live?
thanks all for the comments and stopping my the ship yard,
schnu,,She will be a big one 1385mm long x 950mm High x 525wide,  :( Not really thought where she will end up,, Wife has a suggestion!!
Max, Come by any time,
Rich.
HI All, The following pictures are of my attempt of a 4 butt system for the decking, I will use this of the other deck, I'm not sure if i will use tree nails(unless someone has any ideas of the best way to do)).
I think I do this right!
Rich.
My Bank Holiday weekend work in the ship Yard while the wife and Daughter was at a Batton Twirling Comp,
I Have planked below the Lower Gun ports with the second planking layer. Filed out the gun ports. Just working on the other side, waiting for the glue and wood to dry then i can file out the gun ports.
Rich.
Wow, this will be a huge project then, much room for detail. Did you plan inner decoration/lightning? Even tho you already glued everything in place
Schnu, Thanks for the comment,  I did think about it I did have a few idea,s for the upper decks and quarters but I have quite few months, till i get there,
I brought from ebay, a Few LED random flickering lights to try
Rich.
Hello All,
Just a Small up date 2nd planking of the hull is coming alone, not to bad, TBH, not as good as it could have been,Done half of the starboard side and finished up on the port side.
week or two more and this bit should be done,
Rich.
Nice so far Rich. I hope I too can equal your successes....Keep it up..
"Woody"
HMS Victory 1804 Caldercraft scale 1.72  (not 1.75) Build start, May 1, 2014.
