I agree with Sjors,that is one beautiful planking job B)  B)  B)  B) Excellent work Nick,well worth all the time.Planking in this style is not a quick job for anyone,don't worry how long it is taking.
Kind Regards
Nigel
Currently working on Royal Caroline
Hi Nigel and Sjors
Thanks for the comments. I'm really pleased with how it's going so far. Bit of trepidation about how to do the garboard plank but not there yet! Not much progress since the last set of pictures. Work and life are getting in the way...
Nick
Hi Nick,don't worry the garboard shape will reveal itself when you get close to the keel.The one piece of advise I would offer is don't make it the last one to fit.It will be a pain to shape and fit keeping the gaps minimal.If you leave the adjoining plank as the last one,then you can simply trace the shape with a piece of paper and rubbing against the edges with the side of a pencil.
Kind Regards
Nigel
Evening everyone
Update time. Another planking section finished. Woohoo! Two more to go before second planking end milestone! :)
Here are few photos.
and finally...
I do have one question. Although I have no reason (well... :P ) to doubt Nigel's assertion that the garboard plank shape will reveal itself how can I split the last section into strips as the garboard is supposed to be slightly bigger? (Just to be clear I'm using the fanout template to work out plank widths and this assumes all planks are equally wide) Surely I need to put the garboard in first and then split the remaining part of the section?
Any pointers gratefully received.
Thanks for looking in.
Nick
Hi Nick
She is looking good B) It is awfully hard to explain in words how to go about the garboard.I would divide the remaining section at the sternpost to give you the garboard width there.Then divide up the section up where the bearding line starts(about just over a third of the hull overall length in the last pic,working from the sternpost.This would give you a straight sided taper for that section.Run the garboard parallel along the keel rabbet until where you last plank starts to swing upward when viewed from the side as it goes to the bow(looks about 5 or 6 inches back from the front scarph joint)The garboard's outboard edge then wants to mimmick the upward sweep of the above planks.This is less about hard and fast rules and more about asthetics when planking in a contemporary style.Your best bet is to start with masking tape or a card template and keep playing with the shape until it follows this line.It is just this bow section that will be hard,the stern area is straight forward to draw out on tape placed in position.You will find the developed shape of this plank to look weird quite frankly,but that is how it should be.The true developed shape shouldn't look anything like a straight plank.The garboard is usually wider amidships than other planks to allow for the material fitted into the keel rabbet,when fitted it should look the same.I hope this helps rather than adds to the confusion,as I said it is hard to explain.If in doubt,you can always place a length of tape in position and draw the edge of the garboard on it,then post a pic so we can see if you are heading in the right direction ;)
Kind Regards
Nigel
Ahoy Nick :D
Beautiful work
I really like your approach to this kit
I have the Corel Vic as a back burner project and am currently trying to formulate a plan to plank this beast. The instruction have you completing both layers of planking and then go back and cut out the ports. I don't think my skills are up to that.
I saw you used a plank on the first layer as the line for the sills.  Was this in the instructions or just your genius. Also on your second layer are you tinting that wood or is that just the natural color.
Many thanks for posting. :)
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Hi all
Thanks a lot for the comments and likes.
Nigel:
Dont worry I am no more confused than I already was :D:P . Just kidding I think I see what you mean. Once I sit down in front of Le Mirage and go over your message I'm sure it will become crystal clear. Some tape and posting a picture sounds like an excellent idea! Thanks in advance for your help ;) .
Sjors:
Thanks for your kind comment.
Almost done......
Maybe but given my progress rate..... You'll have finished both your current builds (which are looking excellent I must say!) before my second planking is done :D
I'm planning to use Danish oil on this build. I just love the warm dull (not shiny) sheen is gives. When I'll put it on is a completely different matter as oil and glue dont mix so I guess I want to put it on as late as possible but not before there's too much stuff in the way. Guess I'll cross that bridge once I've crossed the 223 others before it :D
JPett:
Thank you for your comment.
Genius??!?!?!? :huh:  I'm sorry I think you have me confused with someone else... :)
No I just followed the instructions. I'm surprised the Victory does not use a similar method. To answer your last question I am not tinting the wood but I am planning to use danish oil as a finish.
Nick
Hi All
Right here are a few pictures of a garboard plank run. The edge of the plank is the top edge (when the ship is the right way up!) of the making tape.
So as I have absolutely no idea :blush:  can anyone tell me if this look even remotely right? (where's that "HELP!" emoticon when you need it! :D )
Cheers
Nick
That looks pretty good to me Nick,you have the little curl at the end just right B) If you were to run it to a point,then you induce plank creep up the stem,which is to be avoided with this style of planking.I would fit the garboard and then work upwards to complete the hull.The planks will look a little like a hockey stick as you work away from the garboard then start to straighten out a little as you meet up with your last plank.You are best to adopt the tape approach for the next couple,just so you can give it a good 'eyeball' before cutting the planks.They want to adopt the slight upward sweep you have on your last plank laid at the bow.
Kind Regards
Nigel
Nick,
Very nice start. Your hull planing is very very nice.
MIchael
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Hi Michael
Thank you for your nice comment. At first I was a bit nervous about doing the second planking this way but I have to admit (Modest? Moi? :D :D ) I'm pretty pleased at the way it's turning out!
Since I'm here might was well give a small update (sorry no photos). Spent 40 minutes last night getting the shape right for the first plank of the garboard strake. Think it looks ok. Hopefully the others will be quicker!
Nick
Evening all
Time for a small long overdue update... I've finished the garboard plank and the next line of planking after that. Looks ok to my untrained eye. As always feedback welcome. Here's the photos:
Can be useful to take photos. Wouldnt have noticed the gap below otherwise! :blush: :blush:
I'll work my way down now (from the ship's point of view) from bow to stern. That way the last plank to be glued which I wont be able to pin will be flat.
Thanks for looking
Nick
Great job with the garboard Nick B) You have got a nice even band left to fill in which should make life a little easier(as easy as it can be cutting all the planks out of sheet).
Kind Regards
Nigel
Wow Daddy Nick !
I have to wait for a long time for an update but then I've got something !!!!!!
Amazing job with the planking !!!!!
Sjors
Hi all
Thanks for the likes!
Nigel: Thanks for the feedback. Good to know I'm on the right track. Cutting planks from sheet isn't that bad especially since I've taken a leaf out of your book (or your build log more specifically :D ) and have started using a scalpel. Much sharper and much easier than the X-Acto knife.
Sjors: Thanks for your comment. Too kind. Yes updates are slow. Too much to do during the day... I dont know who invented work but I think I need to have words... :)
Nick
Evening all
Small update. Think I've not got the garboard quite correct :( . You can see on the picture below what I mean. The distance between the planks narrows and then expands again just before arrive at the bow. For me it just doesnt look right...
Here's a close up. The arrow shows a bulge in the end plank on the second row that shouldnt be there and is part of the problem. However I also think the garboard plank needs to extend a little bit and also not curve that much. That is what I am trying to show with the line. (not that clear but drawing with the mouse is not one of my strong points! :) ). I know you have to be careful with the garboard in not letting it rise too much otherwise that causes a bunching up of the planks above but I think I have gone too far the other wayat the moment!
I'm hoping to only remove the three end planks....
Nick
Hi Daddy Nick,
Maybe you can put a little water on it or are you using waterproof glue ?
It should be not a big fix.
Good luck with it !
Sjors
Hi Nick
I have been pondering on this one.I feel that if you carry on as you are then the planking will look correct when the ship is the correct way up.The wider ends that meet the stem,will not appear wider due to the angle the stem slopes away.This is hard to explain,but from memory,a similar thing happened on Caroline,the plank ends did fan out so they appear a more uniform depth when viewed from ahead ( with the model the right way up).I suggest you draw the remaining planks in,in pencil,then you should see what I mean.
Kind Regards
Nigel
Hey Sjors and Nigel!
Thanks for the feedback guys.
You're absolutely right Sjors. In fact it's going to be non-existent!! Think Nigel may be onto something here... A couple of photos to explain...
So here I've drawn the planks as Nigel suggested. They are a lot wider especially compared to the planks above (as in if the ship was the right way up)
however, turn the ship the right way up... and voila! :)
Actually doesn't look bad at all (well apart from my uneven unsanded second planking :D ).
I think I may even try to do those drawn planks first just to make sure it does look ok before carrying with the rest of the planking.
Thanks a lot again guys (Don't you just LOVE MSW!! :) :) )
Nick
Allowing for the fact that the lines are actually on the inside of the planking,I think they will look pretty much spot on Nick ;)
Kind Regards
Nigel
  • 8 months later...
Hi all
so 8 and a half months later... ho hum  :blush: here's an update...
To be fair to myself... we have moved house. Well that's my excuse and I'm sticking to it!  :)
One big plus side to the house (apart from being bigger and detached and closer to preschools, schools, etc, yes I know very minor items  :D ) is that is has a garage, And part of that has been converted into a dockyard!! Woohoo! It's so good to have a dedicated area for model building. I also had the fun of building my own work bench (just in case you can't tell from the photos...) using slats of a bed we didnt need anymore and an kitchen worktop.
Anyhoo enough talking from me. Here's a few photos. Yes not much of an update (only an extra line of planks) but I don't care it's an update!!
 It's good to be building again  :36:
Thanks for looking in. Hopefully the next update won't take another 8 months!  ;)  :P
Nick
Good to see you back at your build Nick :) I can't believe it has been twelve months since the garboard discussion :o Scary how time flies :huh:
Kind Regards
Nigel
Hi Nick
Two sales fallen through,so house is going to auction 1st October.We desperately need to move so we just want an end to it all :rolleyes:
Kind Regards
Nigel
Well good luck with that Nigel.
Evening all
Update time! I know less than a week since the last one! :)
I've completed the second planking on the starboard side. Nearly there.... However I have decided to redo the keel and the bow of the ship. The reason as you can see from the photos is that although the wood is also walnut the colour is too different from the walnut I used for the second planking. It just doesn't look right. :( I don't mind different shades but that's taking it a bit too far!! :)  I'd rather not have to do that but hopefully the results will make it worthwhile. So that's what I'll be tackling next instead of the last strip of second planking.
Anyhoo enough ramblings here are some photos.
Just to show what I mean by the different colours, especially the plank furthest left that seems to have discoloured completely... :huh:
Thanks for looking
Nick
