Hi Pete
You are correct in putting a nail in the dummy blocks before gluing to the deck.
We all put nails in the deck furniture ie bitts etc before gluing don't we.
I should have realised I should have done the same thing with the dummy cannon blocks.
I will put nails in the remanding blocks I have to fit.
Thank you Pete for your advice I do appreciate it.
I know what went wrong, when I put the CA glue on the bottom of the blocks they moved so I had to move them back by this time the CA was just about dry, this became the weak point.
If I had a nail in the block they would not have moved.
Again thank you Pete.
Denis
Hi Greg
It is Ok we all have to redo things it is part of model building :) :) .
Denis.
You are sooooooo right! Be there, done that on numerous occasions. I've told myself "this is the last time." It's a bummer when I don't listen to myself.
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
This is one of the primary reasons why I follow build logs...as a first time builder I've been sweating bullets about how to avoid this issue as some of the items I'm gluing down now would be the devil to reach and reattach.
First I was thinking Epoxy, but now I'll use pins to secure them as well....thanks much :)
Edited by thomaslambo
Boyd
Current Build - HMS Bounty - Artesania Latina - Scale1:48
Hi all
As I did not make the stove I only did the chimney that comes out of the forecastle deck.
I did add a lip to the top of the chimney.
I thought that I would also add some rivets to the sides.
I got some PVA glue and mixed it with some flour to give the PVA some body (thicken the PVA up).
I know the photo looks bad but it looks Ok in real life if you know what I mean ha-ha.
Well it is only about 16-17mm high.
Denis.
Hi Denis,
nothing wrong with this photo - and even less wrong with the chimney top. :)
Perfect work on such a small detail... Seems you are some kind of artist :)
I am getting mad with all the rings and clamps to fasten the rigging later with my Endeavour. The plans dont help in a way I would expect... So its difficult to find the right place to fix the clamps.
Cheerio
Max
Next: Friedrich Wilhelm zu Pferde by Euro Model 1:47
Finished: Half Moon Corel;  HMY Royal Caroline Panart; HMB Endeavour Occre 1:54; Fregatte Berlin, Corel, 1:40
A life without dogs is possible... but worth to live?
it looks great Den!  never thought of the flour............. :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi all
Just made the bitts and fife rail.
Just dry fitted, now will take it apart and clean it up.
The belaying pins are 12mm but may change them to 10mm ones.
Denis.
Hi Brian
The plans don't call for the main mast fife rail to have belaying pins.
But I am sure it must have had them.
The kit supplies 14mm ones.
I think I will go with the 10mm ones.
But if any one can help please advise me.
Denis.
G'day Denis
When I was on the Endeavour replica, I measured the belay pins and they were 24 inches-600mm. That correspond to 6.5mm at 1:72 scale. I hope this helps. I know it's different ships and not exactly the same time.
Havagooday anyway
Greg
G'day Denis
I did and is amazing detail in the fur and I love that dog. Sorry for not getting back to you, my father is in hospital and our time is limited. Hope you understand.
Greg
G'day Denis
Greg
Hi All
Just in case anyone is wondering what Greg was saying re the fur on the dog.
I did water colour paintings before I started ship building.
Greg is also a very accomplished painter in acrylics and oils.
Denis.
Hi All
Cannon ports are cut out.
Dummy cannon blocks glued ( this time with pins in them ).
Now just dry fitted the quarterdeck windows.
Have to clean them up and paint them.
Denis.
You're a very talented guy Denis......... beautiful painting and excellent work on your build!!!
frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
frank
Can't agree more! Are you going to do the same treatment as before? Flawless piece of artmanship, if I can tell you that my friend.
Greg
Hi All
First sorry about the photos I have a crap camera.
Painted the windows to the quarterdeck.
Next is put the liquid glass on the back, then see if it all fits on the deck.
Denis.
