Does anyone have a suggestion for how to cut and get a nice curved shape for the planks near the bow? I'm using an x-acto knife and sandpaper right now but I'm scared to splinter and fray the planks.
The finer grit sandpaper you use the less the risk of splintering.  Just be patient and you'll be fine.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Make sure the ends are perfectly glued and try to use only downward movement with the sand paper, preferably mounted on a wooden block for support.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Hi.
Use a very sharp knife and cut a small piece at a time or cut close to the base with downward slices.
Then use fine sandpaper with downward strokes onto the base only.
You can use a file if it's sharp with downward strokes onto the base.
LOL reading my own text I like my downward strokes :)
Take your time.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
I use jewellers wire snips.  It's also a good idea to dab some lacquer (the same kind you will varnish the deck with) on the ends of the planks.  That will prevent them from splitting.
If as can inevitably happen, you do get some splits, don't panic.  If the chip is big enough and you can recover it, just glue it back in.  If there are little gaps, take some of the sawdust from your sanding and some white glue and make a paste.  Putty it over any gaps and immediately sand it before the glue dries.  You won't be able to tell there was a problem.
Lastly, if it's really egregious and you can get away with it, a stringer will hide a multitude of sins!
Good luck!
Tom
Tom
Current: Sergal Sovereign of the Seas
Previous builds:  AL Swift, AL King of the Mississippi, Mamoli Roter Lowe, Amati Chinese Junk, Caesar, Mamoli USS Constitution, Mantua HMS Victory, Panart San Felipe, Mantua Sergal Soleil Royal
Part of the answer here (apart from the good advice already given) is the kind of wood you are using. Most wood supplied with kits is far too coarse-grained for the purpose. If you look at Mr. Jacquith's photos, you can barely see any grain structure in the wood he uses. There are several species that are suitable and really nice to use for model making, including holly, pear and Castello. Suppliers like The Hobbymill (see 'sponsors' on the home page of this site) stock these and will cut them to your specs.
Looks good!  The nail cutters are an inspired idea!  They would work a lot like the jewellers snips.
Tom
