This will be my first scratch build  :D
So after getting some books from ANCRE my choice fell on La Belle and the configuration it had under Cavellier de la Salle’s 1684 expedition.
It is mentioned in Frölich's book as one of the easier ships for a beginner to scrach building. (We'll see about that...)
Just order some pearwood from Arkowood, this will be the main building blocks for this model.
I have some boxwood I'll use for carvings and decorations, later I'll order some ebony for wales, railings and blocks.
In a couple of weeks (when my salary comes in) some Proxxon powertools are coming my way from germany.
One of the big reasons for this picking this build is it's relativly nice size.
Size of the model
                         Length  Width  Height
Hull                     54        15        18
Model rigged      62         24        52
Links of interest:
http://olivier.gatine.free.fr/modeles.html
http://nautarch.tamu.edu/model/report1/
http://ancre.fr/en/monographies-en/30-monographie-de-la-belle-barque-1680.html
-Hans Christian
Current build
      -La Belle 1684 (Scracth build)
      -Oseberg (Billing Boats) (On hold)
      -Falmouth (Euromodel) (On hold)
Good luck with this build Hans. You may wish to also check out the model build of Glen Greico, a Texas A&M University professional model builder.
http://nautarch.tamu.edu/model/report1/belleinprogress.htm
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Just got confirmation that my pearwood has been sent from Germany.
Internatioal money transfers are so painfully sloooowww.... :(
Next week I´ll be ordering my Proxxon DS 230/e Scroll Saw.
So in two weeks time the first cuts will be made  :cheers:
-Hans Christian
Current build
Got my proxxon scroll saw today  :)
It sure is smaller than i´d thought
Edited by Nenseth
-Hans Christian
Current build
Look what I got in the mail today  :D
Starting work on my keel and maybe the midship frame next week  :cheers:
Edited by Nenseth
-Hans Christian
Current build
Ready for my first cut.
Edited by Nenseth
-Hans Christian
Current build
Mike, thanks for the comment.
It´s called birnbaum in german, and I love the texture and look of it  :)
-Hans Christian
Current build
Everything ready
Keel, stem and stern (in the ruff)
Edited by Nenseth
-Hans Christian
Current build
Getting the midship frame right is taking some time, but its fun work
Edited by Nenseth
-Hans Christian
Current build
Midship frame under way. :)
Time to find a way to sand everything down to the right size, got a dremel but not sure it´ll get everything nice and even
Edited by Nenseth
-Hans Christian
Current build
Wish I had more time to work on my ship...
Still needing more fine tuning
Edited by Nenseth
-Hans Christian
Current build
When you first start it´s hard to stop  :D
Edited by Nenseth
-Hans Christian
Current build
Working my way forward.
These are the midship frame and 1F, 2F forward frames cut out  B)
A glue realated question...
Any sugestions how to remove the glue stains?
-Hans Christian
Current build
You will sand it anyway, which will also remove the glue stains. Also, try applyin less glue, and remove excess with some stick as fast as possible.
What glue are you using? Realy recommend to try an orange Cascol for indoor use, it should be available in all Nordics.
Bonds pretty fast, very strong. Do not leave colored stains, could be easily dissolved with water if needed. It is just perfect ;)
The glue I´m using is Titebond III
It´s realy good, but as you say Mike, I should use less of it...
I´ll try some light sanding and see if that helps with the stains
-Hans Christian
Current build
  • 3 months later...
Hi Nenseth!
Good choice for the scale!
I applaud that because it's the same scale that I have chosen :-)
So far I've been doing research.
Tonight I will be laser cutting the keel parts, to 1:36, according to the actual archeological remains, which are different from Boudriot's
BTW, I"m curious, why 1:36? Boudriot offers 1:24 and 1:48, I guess you made your own conversion.
you might find this useful
https://plus.google.com/photos/107485130181739375537
over 300 pictures of the real thing.
some forums do not permit posting links to other forums, just in case, simply search for La Belle 1684 ATXinventor for more
My monograph is at 1:36, I think an older version was at a different scale.
You should start a build log so we can get some inspiration of each other
-Hans Christian
Current build
  • 4 months later...
Sometimes life gets in the way of the fun stuff...  ;)
But summer is soon over and the nights are getting longer.
-Hans Christian
Current build
