NICE!!!   love how you've done that!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks, Popeye!
Next two pictures show completely the reason of my building choices. In this way, the gunports' frames are thin and totally included in the planking. Besides, they protrude a bit adding realism to the whole structure. The following pictures show three red stripes, but the highest will be removed and changed with a white one.
Cheers
Alex
If any of you cry at my funeral, I'll never speak to you again! (Stan Laurel)
You can certainly see where they protrude.  It adds a whole new texture there.  The red surprised me!!!!
Ate in your town at a few great restaurants about 30 years ago.  Maybe they're still there.  Might be worth a trip over to get some Pasta Carciofi and stop by your place :rolleyes:
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
...eh ...eh ...eh ...!!!
Red is for the lower part of the forecastle. There's a white colored middle part and a semi-natural wooden part on the top. Semi-natural because (as shown in the pictures) it's a bit stained with dark linseed oil. You can see the difference: the hull under the forecastle is still natural, meanwhile the forecastle is stained.
Cheers
Alex
p.s. this picture is a prewiev.... In fact you can see also the wales (red)
Pasta ai carciofi is a typical recipe of my town. But you can find lots of varieties of pasta all'uovo (pasta made with flour an eggs). If you decide to come here, tell me something ....!!!!
Edited by Foremast
I'm sure we'll see that on the ship {flag}......or perhaps even on the main sail..........superb bit of progress......must have been qwuite tedious to paint around the gun ports......;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Those windows are so gorgeous. They are so precise they almost look like they had to be laser cut (if I hadn't seen your step by steps I wouldn't have believed you made them) keep it up!
-Sarah
Krabbenkutter CUX-87
Harriet Lane
Fishcutter GO-38
In the Wings:
Corel Victory Cross section
Completed Build:
USS Missouri minimissouri.jpgHMS Bounty's Jolly Boat thumbnail.jpg Peterboro Canoe tiny.jpg
Thanks Popeye and thanks Sarah!
I'd like to put Lubeck's coat-of-arms on the sail, but I don't know how can do it without getting mad. :huh:
It wasn't at all tedious to paint around gunports: first I carved and shaped every strip to surround every gunport's frame, then I painted them, in the end I pasted each one. That particular reddish color was obtained blackening every strip (and wales), then painting between the fingers: I put a drop of (acrylic) color on the forefinger, then I slided the strip between forefinger and thumb. In this way, the color is perfectly stretched on the strip and the wood's (blackened) grain glimpses out of the varnish, giving an idea of ancient timber.
Cheers
Alex
you could try.......
if you have a photo shop in your computer.......create the image or import it.......sail cloth will go through the printer with no problem,  just be ready to guide it.    I use decal bonder to seal the cloth,  so the color doesn't run.......do light coats......two or three should do the trick.
superb job on the ship Alex.........that crest would look great on a sail.   you can even do flags in the same manner.  it can even be wrinkled nicely when dry.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Your idea is very interesting .... !!!! When the moment for sails arrives, I'll surely try to do that. That eagle in the main sail, can be really impressive. About flags, in every paint they're thin and only red and white.
Thanks a lot
Alex
Edited by Foremast
I did the flag for the Susan A in this method............tried diluted white glue,  but the image on the flag didn't like that  LOL!   light coat,  let it dry a bit,  then do another.........if you want a third coat......do the same as the first.   it might even be a good idea to let the sail set for a short time as well,  to give the ink a chance to dry before you do it.   I hope it goes well for you..........love to see it!   ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
That would be spectacular Alex.  I see Popeye has given you not only encouragement but a method as well.  Although I wouldn't have the guts to try it myself, I'll be watching :)
Augie
Previous Builds :
now  THAT is awesome!   I like it!!!   could have hit the like button........but this is beauty overload!  I was looking in my decal folder,  and I have a couple of flags that I made for the Susan A.     that crest you showed would look nice on a sail  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Augie and Popeye, you're really great fans of this ship. We (me and Hansy, the ship) thank you a lot!
When it will be the moment, I'll try all what you wrote to copy that crest on a sail. Hoping to succeed in doing it (my original idea was to make a vertical-strips sail, and this complicates a bit this matter) ... It won't be easy, but I'm stubborn and something will come out.
Thanks again
Alex
Hi all,
here is the internal view of the fore area. The wood is stained. In the last photo, a full view of the ship's right side ... aft frames, on the poopdeck, were temporary removed because of a placing mistake: I hadn't considered the correct thickness of planking :angry:
Cheers
Alex
shows just how much thought your putting into her.......looking great!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Alex, no matter if it is a cog or a hulk, you are building a beatiful model.
I see you have a nice view of 17th century Gdansk port, and a link to "Lisa von Lubeck" site. Here we are with some pictures of "Lisa" at Gdansk port ;) (jimmy_bee at the mast)
post-3205-0-20784800-1366100522_thumb.jpgpost-3205-0-02055900-1366100538_thumb.jpgpost-3205-0-01030000-1366100546_thumb.jpgpost-3205-0-66121700-1366100560_thumb.jpgpost-3205-0-36567500-1366100664_thumb.jpgpost-3205-0-44172600-1366100598_thumb.jpgpost-3205-0-22941800-1366100607_thumb.jpgpost-3205-0-22941800-1366100607_thumb.jpg
Thanks BE, Popeye, Jaro and Augie!
The final colour of the hull will look like to Lisa von Lubeck's. For the wales, I had to choose between dark cream and red; I'm glad you think red is good. I preferred not to add another colour: wood, red and white seemed me enough.
Jaro, thanks for your pictures: they solve a problem of mine. I had thought to put cleats on the mainmast, but I wasn't sure it was correct. Now I see it's right!!!! Thanks also to commander Jimmy, I'm sure he's a great sailor!!!
Cheers
Alex
Hi mates,
a little step: foredeck. This is a test, the lower part - the fore area of the main deck - still lacks of its supporting elements. I thought that making the deck first, then beams, could help me to collocate upper elements (foremast, bitts) but it hasn't been a good idea. Difficulties have been, instead, more: the easier drilling of deck's holes is nothing in comparision with the difficulty to bend properly the deck.
Chees
Alex
looking good Alex  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi, Popeye!
There's a false deck under the visible deck, made with a 0,6 mm thick birch plywood. In this way, it had been possible to have - at the same time - a strong deck and thin covering strips that simulate, in scale, the planking. They protrude a bit out of the first beam, so they seem the only planking.
Cheers
Alex
Hi Augie!
When I'll try to make rigging ... the ship will cease to seem real. I think, it will cease to seem a ship.
Cheers
Alex
Alex I am sure that when you start the rigging you will do an excellent job.
Michael
well.....it looks great....however you made it!  I even went back and looked at the pictures again........very nice indeed ;)    all you need now are the supports  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
