  • 2 months later...
  • 8 months later...
  • 4 months later...
  • 7 months later...
Hi, does instruction manual suggest that type of lower hull planking? Santa Ana is a very beautiful galleon. In my opinion, if you tapered planks at the bow and made all planks parallel to water line she would look much nicer. I am sorry for criticism. (i assume this model has one layer of planking)
Mustafa
Mustafa
Yes and no.
I explain, yes the instruction manuel suggested that kind of planking but the Sapelly wood is very hard to cut or bend so i decided
to go with the natural curve of the hull.
For your second question, yes only one layer of plank.
On 3/31/2017 at 0:38 PM, le débutant said:
Yes and no.
I love the way your planking job turned out, it looks fantastic.
5 hours ago, mtdoramike said:
WOW, what a real beauty she is I'm impressed with your progress aand fantastis job you are doing on her.
Thanks.
All the wood used for the defense are painted and i hope they will be install this week.(black)
  • 7 months later...
sorry for the mix of picture,
i had to relocate all picture to another site.
I made an up-date of the work done and i hope to correct the old picture missing.
second floor finish
and ready to installed
I just finish to build the canon on third floor,intalling the grading, ladders,and parts of the wall.
Next picture is to figure out how to attach each canon.
Edited by le débutant
The story continues.
First;
the defense as to be removed because the were to high.
Second the opening to get access to the ships is not according to
the plan but reflect the picture on the following page.
Now i started to build the second wall for the fourth deck.
Today i will give my first advise for this kit.
Just build all canon before installing them because some of them will
cause some difficulties,the mounts have no hole on, and it is impossible
to drill them bad qualities of wood.
The hole are for the wheel.
