This is my beginning of my build log of Marina II. I like working on working boats like this one. just completed my build of the mare nostrum another working boat by artesania latina. Looking forward to this build because the scale makes this boat bigger and have more details built on it.Thanks for stopping by my build log.post-1262-0-08875500-1419808979_thumb.jpgpost-1262-0-15095600-1419808990_thumb.jpgpost-1262-0-42883000-1419809003_thumb.jpgpost-1262-0-15148200-1419809017_thumb.jpg
Finished Build:
     Andrea Gail - Billings Boat 608 - scale 1:60
     St. Elme - Soclaine - scale 1:20
     Marina II - Artesania Latina - Scale 1:50
       Lobster Boat - Midwest
       Mare Nostrum - Artesania Latina - Scale 1:35
Today got to work on my build. I cut out the false keel, the frames and the stiffeners out of the laser cut sheets. The wood in the kit is great and the laser cuts seem to be right on so far. Began glueing the frames to the keel
Finished Build:
  • 3 months later...
Finally got back to the workbench. Look at the pics ....I am greatful for clamps...Starting on the planking part of the build now..Thanks for stopping by, hopefully become a follower...
Finished Build:
Great start!! Fun kit. Am "kitbashing" mine to stand-off scale Northeastern (Deadliest Catch fame). By modifying wheelhouse and moving it forward and modifying stern (added some inches while sqaring it off) its coming out as a "reasonable facsimile".
Would love to see some pics of your kit bashed into the northwestern. I have thought about doing the same thing. Jerryb if you start a build log , I would definitely be a follower
Finished Build:
  • 2 years later...
Back at the work bench finally. Got planking finished with one coat of primer applied. Decking also completed with pencil rubbed on edge of every deck plank. Feels great to get back working on my Marina II.  Thanks for looking.
DSC00505.thumb.JPG.b8f22b1361c8dd2849ee47123ecd84f8.JPGDSC00503.thumb.JPG.b22ff1a680481db832720c7b961d731d.JPGDSC00502.thumb.JPG.60dd383936ca2dd09bc61dd5d10b6ba9.JPG
Finished Build:
very nice start!   looks very well done.   how was the bow shaping......pain to do?   I recently bought this kit.......nice to know there will be a build to follow  :)
   the deck looks great too!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Here is the latest pics of my progress. Work on the hull still in process with railing to be attached next. Also began some painting, I am following the paint colors on the box. Thanks for stopping by to look at my build log.
5a4563266bb8d_DSC00507-Edited.jpg.c18a8def76bd635ba46add30f91d52a0.jpg5a4563526f5fe_DSC00509-Edited.jpg.50a8e5056868410be6fe8eab5ffc4bdb.jpg5a4562389eb6e_DSC00506-Edited.jpg.29518b6a662455982b731cfae3c2b8b8.jpg
Finished Build:
looks very well done  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Just finished the final shaping of the hull. Applying primer coats today. Have pics showing my progress after primer has dried.
Thanks
Finished Build:
Hull is finally ready for paint
This kit does not supply a display stand. Before I begin the painting of the hull..it needs a place to set and not directly on the workbench. I began work on a display stand I saw somewhere on the web. I enjoy challenging myself to building all my display stands and not using standard stands.
Some more sanding than either brown wash or stain to the stand.
Finished Build:
Finished the stand. I enjoy the way it came out.
Finished Build:
Today all focus was getting the hull painted. Alot of time was spent taping off areas and painting all the colors. I did remember to take some pics thru the process.
Finished Build:
that's a neat looking stand ;)    very nice paint work.......looking super!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Boat is in the stand and began working on all the deck fixtures. Enjoyed time on the hull but glad to be done. I been thinking about the idea of lighting my model.
Never done lighting but need to start planning for it now. Thanks for following...
All the parts to make one storage bin....need to make 6 in total
All 6 bins built and painting them begun
Finished Build:
Been awhile but got updated pics for my build. Alot of time been spent with sanding and painting. Enjoying this build and isn't that the reason we do this hobby. I believe the most important part of this hobby is having a comfortable chair...you will be spending alot of time in it. Thanks you checking in on my build.5a8caa879fbbe_DSC00540-Edited.jpg.32486177f32222f0fbaf8cf8f46a6cc1.jpg5a8caa9ce6da1_DSC00545-Edited.jpg.cdb12cf2d7d80108dd84cce7418e8133.jpg5a8caaa9e529e_DSC00547-Edited.jpg.cf365b533c84a0534f9e64847977a2b6.jpg5a8caabeb652f_DSC00548-Edited.jpg.bbed202fc21b63470a08f4d16e639aa6.jpg5a8caacbbf465_DSC00549-Edited.jpg.0e1769dfb8aad90085b3a8c29d0a0a63.jpg
Finished Build:
more pics to look thru.....
5a8cab291632e_DSC00556-Edited.jpg.85e5a5224b0375d3383dd2494407a5e9.jpg5a8cab383c47a_DSC00557-Edited.jpg.fe71f0a3bb1d9024c48366a9fe456ed8.jpg5a8cab44e3a22_DSC00558-Edited.jpg.8cb45db02b1fd0591c32e5675e3fdac5.jpg5a8cab50ad193_DSC00560-Edited.jpg.661f25271b9a282c9b5134b04b6b1977.jpg.5a8cab14294cb_DSC00555-Edited.jpg.68ae350dce40b42774211a6877578046.jpg
Finished Build:
Nice work!!
I have this Model in the Closet, thinking about a Radio conversion....
Any ideas/links?
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
I am a static model builder. This model can be radio controlled, there is room inside the hull for everything you need. This kit is made so the main cabin can be removed to access the inside of the hull. Hope this helps you... hof00. If you like pics of the space inside the hull, i will post.
Finished Build:
look'in really good........nice  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 8 months later...
With close inspection of the finished hull, I noticed two areas that planks opened up slightly. They were not really easy to see but they bothered me and I would not be happy with the finished model if I left it. The old saying you are your own worst judge on your models. 1910951383_DSC00561-Edited.jpg.25cdd0ac9de90a9cc1c7aaa93af9934a.jpg725882193_DSC00562-Edited.jpg.86841f6642718935a864228cb122ab63.jpg
sanding down then primed the hull again ....ready for paint
1024923361_DSC00574-Edited.jpg.073d78b9b177ad74b39abac2ba3e0d79.jpg1568430591_DSC00578-Edited.jpg.5733954ebefc536857eb1c6b3250a919.jpg
Finished Build:
Started to build radar and other deck equipment.
1299113939_DSC00563-Edited.jpg.cc00d59b9b651994b9627b5de525da41.jpg1441545279_DSC00567-Edited.jpg.11681673876e8626249eed41a63c834b.jpg
This is a fishing ship. So there is fishing hooks and nets to build.
Finished Build:
Finishing the all the deck fixtures....
1457638201_DSC00582-Edited.jpg.63cc2ce1010f22340e2a0ad3c3c26d26.jpg1150737635_DSC00581-Edited.jpg.0b173f9ea361e74b4cfc2f5b98358b6e.jpg737311009_DSC00584-Edited.jpg.9b09c9f1b3a13d2564896706bec58703.jpg
Thanks for stopping by my build log....
Finished Build:
I have just started to begin the build of the two masts. Here are some pics of the main cabin set in place not glued in yet....
The end looks near but I am probably turning the half way point. Enjoying the build and hope you enjoy following.
Finished Build:
she looks really nice...very clean and vivid colors :)    my first build was like that......I found that not cementing between the planks allowed the gaps to show up in a big way.   I have this model in my stash.......your log will make for great reference.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Yup, awesome clean build Chap!!
Hopefully I'll get a good as a result as yours!!
Same with "Popeye," I too have this kit languishing in my closet….
(I don't know quite how Popeye has the wherewithal to build so much at the same time, it's way beyond me.... 🙂)
Casting no aspersions….
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi, not really my type of subject but seeing your work has really opened my eyes. Kit looks really well presented and they really knew how to pack all the parts onto that ply sheet didn't they.
Really in awe of your work and your stand is very impressive. Would also be nice in a diorama for when you are not sailing her.
Current Build(s):
Completed Builds:
