usedtosail
Everything posted by usedtosail
  1. Thanks Bob. I really like the clean look that the white styrene gives to the trim details, so when I get to this model I am really leaning toward using it.
  2. The copper is looking great, Max. I like you use of the tape to line up the plates. Mine were a bit wavy as I tried to go free hand.
  3. Bob, that saw and the gunports look great. My question above was about what glue you used to glue the styrene strips to the hull, not the copper plates.Thanks.
  4. Is it hard to get the paper backing off those tiny plates? I found that using the half width strip and cutting each plate so that only the copper was cut (not the paper) made it easier to separate the plates from the paper backing.
  5. And the new transom is finished. All the plank ends are now flush with the transom. I scribed some plank lines into the outside of it. The stain bled through a bit, but the outside of the hull still needs to be sanded, primed and painted. Here is the inside after staining. I ended up staining the whole inside to get everything to match, sort of. On to the sheer clamp.
  6. Nice work so far Henry. You are doing great detail at such a small scale.
  7. Bob, this is a really nice build of the Constitution. Thank you for reposting it. I will use this build log when I get to starting mine. I do have one question - what adhesive did you use when gluing the styrene strips to the wood? I saw a bottle of Titebond in a couple of pictures. I really like the nice lines you obtained with the styrene. Thanks.
  8. Thanks Cap'n. Your build log is what inspired me to build the launch. I especially like all the details you added. Brad, your Launch is great.That is pretty much the way I'd like mine to come out. Thanks for the pictures. No pictures today. Glued more of the planking to the new transom and clamped to dry. I have glued it back in roughly thirds, so I still have the top planks to glue on.
  9. Beautiful boat so far, Bob. I look forward to following this build.
  10. Thanks Bob and Keith. Bob, your Malabar is beautiful and Keith I just love the Dark Side version of the Swift.
  11. I will be enjoying this build as well. Looks like an interesting project.
  12. BTW Brad, the Bounty Launch in your avatar looks really nice. Do you have any other pictures of it?
  13. Thanks Brad. If it wasn't for the plank ends I probably could have lived with the transom as is, but it was bothering me too much, so I decided to bite the bullet and replace it. I used alcohol to loosen the white glue and acetone to loosen the superglue in the few spots that I used it. I was able to gently pry the top planks off the transom, then used an X-Acto knife to get under the remaining planks. For the stern piece, I used an X-Acto chisel to pry the transom loose after loosening the glue with alcohol. The transom then popped out with no damage to the planks. Here is the old transom with the wording showing through: Here is the outside of the old transom as the alcohol was doing its work: Some pictures during the removal process: Success: I scraped and sanded the insides of the plank ends to remove the old glue, then used the old transom as a pattern on some basswood sheet. I used a thicker piece of wood for the new transom so that I could get all the plank ends close to the edge. After I glue them down, I will sand the whole transom thinner to the correct thickness, which will also sand the ends of the planks to be flush with the outside of the transom. After sanding the transom to fit, I glued it to the stern piece and the bottom two planks on each side, forcing the plank up to the transom with clamps and scrape wood pieces. I adjusted the angle of the transom to be more perpendicular to the keel, so the plank ends fit better on both sides. I will let this dry overnight, then I will glue the rest of the plank ends to the new transom. I am quite pleased that I was able to perform this exchange without much trouble and I feel much better now.
  14. As promised, here are the results of the finish test. I used a pre-stain and then a cherry stain on the test piece, and it had just the look I wanted: I then stained the inside of the hull, a third at a time so the pre-stain did not dry too much before the stain. I am really pleased with the results, as it has that old work boat look that I wanted. I was really concerned that the basswood strips would not be dark enough, but I think they are just dark enough without looking muddy. The whole time I was staining I was thinking about the transom, which I am not happy with. I already showed one of the problems, where the planks are too short on one side. But, there is another problem that got worse with the staining. There are laser etched letters on the outside of the transom to mark it as the Transom, I guess to not confuse it with the building jig molds. I can deal with covering the letters on the outside as this area will be painted. The problem is that the lettering goes all the way through to the inside of the transom, so when stained it is very prominent. I can't sand it off because it goes all the way through the wood, and I don't know how to cover it up on the inside of the hull without looking bad. So because there are now two problems with the transom, I think I will replace it. Hopefully I can do it without messing up the planking.
  15. Some more progress to show. I glued all of the pre-bent between frames into the hull. I was able to find frames that fit pretty well in all the spaces between the existing frames. For the cant frames, I used the building jig to pre-bend three frames for each side using the three molds at the front of the jig. These did not have any frames bent to them when the hull was planked, but I found they are close to the bend needed for the cant frames. I let them dry for 24 hours, then fit them to the hull. The two outer frames fit very nicely, but the middle frames were high in the middle, so I re-soaked those two, bent them with my plank bender, and clamped them into the hull to dry. When they were dry, I glued them into the hull. Here is the finished framing: I am still cleaning up the insides a bit and scraping the outside of the hull. I think I am going to stain the inside of the hull next so I can get between all the frames before adding the interior details.I haven't decided on the finish for the inside yet, so I made up a little test strip with cherry strips on a basswood plank to test different finishes. I should have results here sometime next week.
  16. That is a very nice planking job. It looks so much better than the supplied scored sheet. My Phantom is also in a sad state but it servers me as a reminder to do better next time.
  17. Adding the between frames to the inside of the hull. I had bent all of these previously on the jig before I started planking the hull and they fit pretty well between the other frames. I think this was easier than trying to bend new frames into the hull after it was built, as I did not find a good way to clamp the frames near the keel inside the hull. I glued the bottom half of the between frames first, let them dry overnight, then positioned the top halves and glued them in place. I did use a small drop of superglue on a couple of frames to hold them in place at the turn of the bilge, but I didn't want to use it on all the frames as I would like to keep the interior finish unpainted and didn't want a lot of glue spots to deal with. You can see the pre-bent frames for the port side in the tray on the right in the first photo.
  18. Thanks for reposting your work here and your progress to date looks great. This kit is the next one on my list so I will be watching and learning from your build. I have already learned quite a bit.
  19. I gave the outside of the hull an initial sanding while it was still on the planking jig, then popped the glue joints between the frame ends and the jig, and the hull came right off. I sanded and scraped the outside of the hull more and added some wood filler in a few spots. I was really glad to read about using an X-Acto knife to scrape the hull instead of sanding in another build log, as this worked really well and the results look better than with sand paper. I then gave the inside a first sanding and removed some glue spots.I need to give it a finer sanding before adding the rest of the frames. The hull seems quite fragile at this point, but it is holding up to the sanding and scraping well.
  20. Thanks all for the comments. The basswood planks that came in the kit are all cut from three sheets, which I suspect all were one sheet at one time. They are all very even in color. The rough planking is just about finished, as the glue is now drying on the last plank. Some wood filler and first sanding is next. Here I have attached the next to last plank on the starboard side. I used a variety of alligator clips, hair clips, and small binder clips to hold it in place while it dried. The alligator clips held the plank tight to the previous plank, while the hair clips held the two planks flush with each other. I made a cardboard template for the new shutter plank using the old one as a guide, widen it where it needed to be bigger. When I was happy with the fit, I traced it onto some basswood sheet and cut it out, then soaked and bent it to the hull. I used clips along the keel with rubber bands to hold it in place while the wood dried to shape. The clothes pin under the rubber band at the stern put some extra pressure on the plank to fit tight to the transom. The next day I sanded the plank to fit the opening and glued it in place, using more rubber bands and pieces of wood to hold it in place while the glue dried. I have since used the same procedure on the port side.
  21. Another progress update. I have bent and glued a few more planks to each side. I have three more planks on each side to add. The bow area looks like it will be fine, with the three planks fitting the space left nicely: The problem is at the stern. The shutter plank provided in the kit is too narrow at the transom: This is not too big a deal, as I have some basswood sheet to cut new planks from. I will use the supplied planks as templates for the bow and middle areas and leave more width at the transom. The funny part is that one of the plan sheets provided has the plank profiles in actual size and the shutter plank on the plans look wide enough. It's just the laser cut planks that are too narrow. Here is another problem, which is probably my own fault: Some of the planks on the port side are too short. I didn't catch a slight offset in the transom between port and starboard, which is why the starboard planks look fine, but a little extra length on the laser cut planks would have helped. I am going to be painting the outside of the hull, so some sanding and wood filler will take care of these gaps.
  22. Thanks Cap'n, shipcarpenter, and Bob. I saw those modified binder clips on this forum (version 1.0) and made up a whole bunch of medium and small ones. They come in handy for planking, but only at the beginning as you run out of room for them. I do find them useful for other clamping tasks, though. The small ones are bit hard on the fingers to make, but I use them about as much as the medium size. As promised, here are some pictures of a couple of the supplied pre-spiled planks and what they look like after bending to the frames. These are the garboard plank and the next plank up from it: Here is the first plank down from the sheer strake (#9 on this model). Notice the nice curves to these: Here are these planks clamped and drying on the frames: And here are the after pictures of the garboard and #9 planks, ready for a final sanding and gluing to the frames and keel: Finally, here are the clamping arrangements I am using for gluing the #9 plank to the frames and edge of the sheer strake. I am using a binder clip on each frame and a clothes pin or hair clip between each frame to align the edges of the two planks so they are flush. This will be the repetition for a while - soaking, bending, clamping, drying, gluing, clamping, repeat. I am not sure how I am going to clamp the planks as the gap narrows. I would usually use those clamps that you screw into the bulkheads, but these frames are too narrow for them. It may come down to superglue and my fingers, but we'll see.
  23. The planking has started. On the supplied molds, every other one has marks on them for the edges of each plank. I projected these lines onto the frames, but just on the outsides which will be behind the planks. This way I won't have to sand the marks off the sides of the frames later. In this kit all of the planks are supplied pre-spiled, that is they are all laser cut from sheets of basswood and some are quite curved. All that is needed is to soak these in water and then bend to shape laterally. I started with the garboard and sheer planks and soaked them for about an hour, then bent the bow ends to wrap around the frames using the plank bender shown earlier. Since these planks are not plywood, they bend nicely and don't fall apart. I started with the garboard strake and pushed it into the rabbet along the keel, clamping it to every frame with modified binder clips. I did the same with the two sheer planks, but in their case I put the stem ends into the rabbet in the stem, then bent them around the bow and clamped them to every frame, pushing them up against the sheer alignment tabs on the molds. I let them dry overnight and when I removed them from the frames they held their shape perfectly. I had a little sanding to do along the keel edge of the garboard plank to fit it in the rabbet, and I sanded a bevel into the other edge to match up with the next plank. On the sheer planks, I sanded the bevel on the lower edge and had a little sanding to thin the plank to fit within the plank edge marks on the frames. The stern ends of these planks needed to be bent slightly downward so the to edge aligned with the edge of the transom. I used a straight pin to hold one in place while the glue dried as the clamp was not holding it well enough. I didn't take any pictures of these planks before and after bending, but I will for the next set of planks.
  24. Here are all the frames installed on the molds. They are just glued to the keel and spot glued above the sheer tabs. Overall I think they came out pretty well, given that the cherry is not the easiest wood to bend. I faired the frames and the transom and cleaned up the rabbet a bit around the frames. Next task will be to start the planking.
