Everything posted by popeye2sea
"Drench", nice. I will have to remember that one.
- 385 replies
- soleil royal
- Heller
How low do these tables adjust to? It would be nice to have a table that lowers so that working on upper rigging is not such a reach. Regards, Henry
That will work for the fore braces, but the main brace standing end starts right aft on an eyebolt on the exterior bulkhead aft of the mizzen channels. The plan has the working end made fast to the flagstaff. Obviously that is incorrect, but I have not yet worked out where to belay it. Perhaps to one of the kevels in front of the half poop deck. Regards,
- 2,695 replies
- heller
- soleil royal
(and 9 more)
2.5mm thimble sleeves/blocks
popeye2sea replied to bigcreekdad's topic in Masting, rigging and sails
I don't agree at all. Syren makes some of the most accurate and well formed blocks on the market! Possibly the only thing better would be an actual working block. Which would be next to impossible for a 2mm block. Regards, Henry -
That is correct. Although there may have been more than one linstock per barrel. Perhaps one tub per two guns would have worked? Or maybe one tub per division of guns? I have also read of something called a halliard tub that would be placed to corral the length of the halliard after raising the yard. But, I do not know why, or how they might have been employed. Wouldn't you just coil the halliard on the belay point just like any other line? Regards, Henry
- 2,695 replies
- heller
- soleil royal
(and 9 more)
Like all of the cannon implements, the linstocks were normally kept stowed away when not in action. The tub is there to hold the lighted slow match, held in the linstock, from falling over and igniting anything inadvertently. The slow match is lit and remains smoldering throughout the battle. That is why you so often read about the gunner blowing on the slow match to cause the match to flare prior to applying it to the touch hole. So, no, the linstock is not stored in the tub upside-down. There is a separate tub provided for the sponge water. Regards, Henry
- 2,695 replies
- heller
- soleil royal
(and 9 more)
The instructions call those slow match tubs. The other tubs (part no. 160, two halves) are supposed to be a sponge tub. In my opinion the slow match holder (linstock) is a very poor representation. There should be sort of a, curved, tee-shaped, iron bracket at the top to hold the slow match. What they have there looks like it comes straight out of Disney's "sorcerers apprentice." Regards, Henry
- 2,695 replies
- heller
- soleil royal
(and 9 more)
Another way that the lanyard was finished was to seize the parts of the rope together at several points within the turns and the end hitched once or twice around the stay, similar to rigging shroud deadeyes. Or the hitches can be omitted and the end just seized to the part next to itself between the deadeyes or hearts, which will provide a much neater look. Regards, Henry
Beckets on bluejacket double block
popeye2sea replied to Barbara's topic in Masting, rigging and sails
A becket is the loop (eye) of rope on one end of the block. It typically takes the standing end of the tackle fall. The fall is the rope that reeves through the sheaves of the blocks. The standing end is the end of the rope that is fixed (does not move), with the other end of the rope being known as the running or hauling part. Sometimes the becket is part of the block strop. In other applications the becket is a separate loop of rope attached to the strop. The standing end of the tackle fall is fastened to the becket using a becket bend (I know, creative naming). Regards, Henry -
Robin, I am assuming that the block in the last pic is the one you are using, and that the eye bolt is already installed on the gaff. Take that strop (the rope loop around the block) off of the block and remake another one so that there is a loop (eye) on both ends. One way to do that is to make a loop with rope that will be large enough to go around the block with extra on both sides to form the eyes. Then you finish making the eyes by wrapping a few turns of thread and tying off so that the wraps (seizing) are tight against the block, just above and just below the block. You should end up with a block that is stropped like the one in the plans. Now you can simply tie the lower eye to the ring bolt on the gaff, and the upper eye will take the rope which forms the tackle (the part that runs through and between two blocks). Regards, Henry
stagecoach by kgstakes - FINISHED - 1/8th scale
popeye2sea replied to kgstakes's topic in Non-ship/categorised builds
That's a beauty. Have you seen the YouTube channel by Engels Coach Shop. He builds real coaches for a living. Yours looks identical. Regards, Henry -
Glen, Great fix on the trysail mast, and an overall superb job on the re-rig for your client. Ah, yes, mai-tai's and scorpion bowls; de rigueur cocktails at Chinese restaurants everywhere. I remember putting together several straws to make one very long one and stealing from others scorpion bowls in my youth. Regards, Henry
- 301 replies
- Constitution
- Bluejacket Shipcrafters
Question re: Rigging Multiple Blocks at One Location
popeye2sea replied to GGibson's topic in Masting, rigging and sails
Each pendant or block should have an eye spliced in and fitted over the end of the yard arm. The inside one butts up against the yard arm cleat and the rest snug up close to the preceding one. The fittings usually went over the yardarm in a specific order, usually with the footrope being first over (most inboard) and then proceeding outward with the yard tackle pendant, brace pendant, topsail sheet block, and the lift block being the last (furthest outboard). Regards, Henry -
Hi Glen, I know it's too late for this build, but you appear to be installing your blocks backwards. The hole for the tackle line should be closer to the top or strop eye end of the block. The hole represents where the line enters to go around a sheave that has its pin or axle in the middle of the block. The line should appear to pass on both sides almost the length of the block and around that imaginary sheave. Info for the next build. Regards, Henry
- 301 replies
- Constitution
If you are feeling ambitious, The Ashley Book of Knots describes several ways to make up baggywrinkle. Picked apart rope yarns (thrums) are knotted around or through a line and packed together tightly. Winding the line around the article to to be protected completes the baggywrinkle. Regards, Henry
- 15 replies
- baggy winkle
- service
Furled , unfurled or no sails -Preference
popeye2sea replied to Canada Steve's topic in Masting, rigging and sails
Congrats, That photo looks like it's of a real ship. Regards, Henry -
Glen, The large yard in the first photo is a topmast yard. The lower yards are considerably larger in circumference and length. The gundeck section was built as a display and the crew sometimes conducts gun drills for the public. It stays out in the yard year round. Henry
- 301 replies
- Constitution
Glen, The drawing above is not wrong. The question is what to do with the tackles? Which way do they go? Straight down to the deck or to another block under the top. Constitution has hers rigged with a block under the top so that the tackles lead upwards from the yard. Then the single hauling part of each tackle comes down to the deck to be belayed at the foot of the mast or the fife rail. Regards, Henry
- 301 replies
- Constitution
For the jib sails, use a pendant with two legs seized to the clew of the sail. Each leg of the pendant takes a sheet. Another way to attach the pendant to the clew; middle the pendant and then pass the bight through the clew and then over the legs of the pendant. Cinch the bight up tight to the clew. The legs were often seized to the bight to prevent loosening. Regards, Henry
Glen, There are no rings used in the sling. There are simple eye splices that are seized or lashed together, end to end. Also, on Constitution the truss tackle pendants have a double block seized in and the tackle runs up to another double block seized to an eyebolt under the top before leading down to the deck. Regards, Henry
- 301 replies
- Constitution
Sheet Bend. Regards, Henry
It should not be any great problem to pass the eye of the shrouds up through the lubber hole in the tops and then over the mast head before settling them down in the proper sequence over the bolsters. Regards, Henry
USS Constitution Breast (shifting) Backstay Rigging
popeye2sea replied to Glen McGuire's topic in Masting, rigging and sails
With the double block on top and the triple below there is really only one way to reeve the fall. The standing end of the fall is bent to a becket on the bottom of the double block. Reeve the fall through the blocks passing the line from outboard in on the triple block. The hauling part will pass through the third sheeve of the triple from outboard in and then finish by bringing the end of the fall up and hitch the end of the fall around the backstay, similar to a deadeye, expending however much hauling part you wish around the backstay and seizing in place. Regards, Henry
