Posts posted by Blue Ensign
Excellent result Robert, great looking carriages.
B.E.
Nicely formed Vitus, the pattern looks good but I would agree with Alistair the canted quarter badges only protruded a little way out from the hull.
David Antscherl makes the point in Vol 11 of tffm that the lower stool is shaped that it protrudes no further from the ships side than the Quarter pieces, (ie the stern piece on the model) and comments that many modern models show badges that project to far. A heavy sea could carry such a badge away.
B.E.
Always a pleasure to see an update Christian, she is looking splendid. Nice to see that the Top and Butt planking on the wale shows up well.
B.E.
Nicely done Jason, the squaring off of dowel was one of the things I found my Proxxon Mill very useful for, but as you clearly demonstrate the job can be done just as well by hand. Well done.
B.E.
This is one of those questions where opinions vary. Belaying pins seem such a simple device that it is hard not to imagine they were in use for virtually the whole period of sail.
However, based on contemporary models of British ships experts such as Lees came to the conclusion that they didn't appear thro' the bitts or on racks along the bulwarks until the end of the Eighteenth Century, although there are examples of pins on racks attached to the Mizen shrouds in earlier period ships.
As far as the Swan sloops kits Fly and Pegasus are concerned, I personally don't like the arrangement of pins on the rails adjacent to the Mizen mast, not least because I think they look overscale and ugly.
On my Pegasus build I intend to fit only Mizen shroud racks with pins, but the matter is one of personal choice, and there is no doubt that pins do make the issue of line belaying a little easier.
B.E.
I used enamels and artists oils to colour the etch after applying an etch primer.
Humbrol 81 (pale yellow) was used as a base colour, this along with the primer was applied before I removed the decoration from the fret.
Once in place on the model I applied the Artists oils using a fine pointed brush
For the highlights I used soft mixing white with a touch of Yellow ochre, and for the shading Raw Umber mixed with Indian Red and toned down with white.
Both mixes thinned with distilled turpentine to quite a thin consistency.
B.E.
The hull looks very nice Vitus
How you colour the topsides is down to personal choice, but the official colour in the British Navy was Black, although in practice there were variations, predominently shades of blue and red, particularly on contemporary models.
It really comes down to aesthetics and what looks best to your eye; personally I would stay away from white, perhaps a little too stark against the dark wood, and probably the least authentic of colour choices. You also need to consider how the brass etch decoration will look and how you intend to colour that.
Against the hull colour you have I would go for either Dark Blue or Black, but that's just my thought.
Cheers,
B.E.
Tht's a fine looking Granado Peter
B.E.
Hello IIhan,
I wasn't intending to suggest that there was anything wrong with your rigging arrangement, I'm not very familiar with 15th Century rigging, and it is a period where perhaps not unnaturally there is less detailed information than for the later periods I'm more familiar with.
However I was moved by curiosity to check in Anderson's The Rigging of Ships in the days of the Spritsail Topmast 1600 - 1720.
What you show on Matthew are called Martnets and they did run up both sides of the sail, and performed the same function as the more simple form of Leechlines which superceded them around the middle of the Seventeenth Century, although there was the inevitable transition period where the information gets a little hazy.
As far as Buntlines go Anderson does suggest that they were in use certainly around 1600, and it would seem odd to devise such elaborate rigging to haul in the Leech of the sail and not fit ropes to help lift the foot of a sail.
B.E.
Beautiful rigging work IIhan, and finely made sails. Interesting at that period that there are Leech lines on both sides of the Main sail yet no Bunt lines.
B.E.
Love the cleanness of your finishing Jason, in all areas, something for me to aspire to.
B.E.
Hi Jason,
The Gammoning for Pegasus is 4½" circ which scales to 0.56mm diameter. I used Morope 0.6mm diameter line which just happened to be spot on for scale.
Whichever you go for remember to allow a fair length to complete the gammoning including the frapping, I allowed 40" just to be sure.
Cheers,
B.E.
Beautiful fine work on those rails Thomas, a pleasure to see.
B.E.
Hi Jason, I installed my Bowsprit at a fairly early stage mainly because I wanted to fit the gammoning before I finished off the headworks otherwise it can prove tricky to work the line.
I don't think there are any other issues in the timing of fitting the bowsprit; knocking it whilst working isn't really an issue, although I leave the Jib attachment until the last possible moment, as this is a high risk fitting.
Cheers,
B.E.
Bob, the salt lemon juice mix is good for copper cleaning but may not remove stubborn traces of c.a. which will show up and marr the finish.
For this I have found Acetone removes the marks, applied by fine wire wool if necessary, although your plating looks remarkably clean in the photos.
B.E.
Smart as paint she looks Richard, you must have a nice warm glow of satisfaction having completed her.
Well Done
B.E.
HMC Sherbourne 1763 by tkay11 - FINISHED – Caldercraft – Scale 1:64 - A Novice’s Build
Love the innovation you bring to your modelling Tony, great 'how to' on the swivel mounts.
I recall reading somewhere that there were more swivel mount posts than swivel guns allocated to a vessel, they were just moved around to suit.
It is a fashion even on contemporary models to show the rails festooned with swivel guns, as I have done with Pegasus, but half of them will be removed eventually.
B.E.
