HMS Indefatigable - 1:64 scale – The Art of Age of Sail I just randomly came across this, another 1:64 scale kit out of MarisStella To early to say how it will compare with Vanguard's kit, but there are some photos on the link above. B.E.
Thank you, James, I’m aware of ‘Klear’, or ‘Future’ as it was called last time I used it, beloved of model aircraft builders for canopy fixing and finishing. I’ll certainly give it a go with odourless ca as a back-up. Regards, B.E.
- 648 replies
- Indefatigable
- Vanguard Models
Thank you Nils.👍 Post One Hundred and Nineteen. Back to the blunt end Time to attend to the unfinished stern. I had figured out on the bow area how to finish the Pearwood mouldings and pilasters to be used on the stern. 3088 Vallejo Ochre Brown over the Pear followed by a coating of the water-based wood stain I used on the Boxwood hull timbers. This gives a fair match to the varnish hull finish. 3086 The stern is otherwise painted in Vallejo Black/grey. 3085 3084 3091 3093 3094 When it comes to the frames for the lights I have seen examples of white frames which look quite attractive. However, they would be the only white elements on the model so I am sticking with Ochre Brown. 3080 The frames are prepared on the fret, priming with Metal prep 4K, followed by two coats of Ochre brown. The trickiest part of this exercise will be fitting the frames without marring the ‘glass’ with glue smears. Tomorrow’s interesting little exercise. 🫤 B.E. 18/12/2023
- 648 replies
- Indefatigable
- Vanguard Models
That looks an excellent build of these tricky little boat hulls. 👍 B.E.
- 22 replies
- 24 ft Launch
- Vanguard Models
Cheers Guys, and thanks for the support with the 'likes'. The figure is now back in the box for safety. B.E.
- 648 replies
- Indefatigable
- Vanguard Models
Post One hundred and eighteen Thoughts about the Figure This seems a good time to check out the Figure. The resin warrior version provided by Chris is a mini work of art, beautifully detailed and styled. 2998 We don’t know what Figure ‘Indy’ actually had, but the choice of a Bronze age Greek Warrior fits perfectly. During the late 18thc it was practice to paint Figures in natural colours, rather garish looking in some cases. I have been pondering how to finish the figure, and I’ve concerns that too bright a finish may clash with the more muted tones of my build. I have several books on the subject, but contemporary ship models of this period with ‘painted’ figures are hard to find. A lot of Navy board models are without figures, and for those that have them they are usually either gilded or varnished. For ‘Indy’ I want to use more muted tones with reduced contrast between the shades. How that will turn out I’ve no idea at this point, but I first need to wash and prime the figure. 3002 3006 I use Vallejo Surface primer which shows up the detail beautifully. Before I start painting, I create a colour chart of the likely shades I will use. 3032 These are painted over the primer coat so I can determine the coverage required. 3038 Incidentally, these little lidded 3.5ml pots obtained from Amazon are ideal for paint mixing small quantities and keep it fresh for a long time. I painted the model in life colours but aimed for a soft tone. Vallejo paints were used throughout. This is the result. 3068 3071 3073 3074 3078 I think the colours tone in very well, and the figure sets off the model beautifully. I am particularly pleased with the Bronze used on the metal work, and the Red for the cloak which has a dark wine colour. The reinforced linen of the Pteruges (skirt) were painted with Dark sand, and the tassels in Ivory. For skin tones I opted for Ochre brown with a spot of Burnt Umber added. The shield is Hull Red with the embossed hub and rim in Bronze. I had intended to apply washes and varnishes, but I’m now thinking I should quit while I’m ahead. It is after all a figurehead on a ship not a real-life depiction as may be created for a specific model figure. A pleasant diversion from recent activity, but back to the build now. B.E. 15/12/2023
- 648 replies
- Indefatigable
- Vanguard Models
Post One hundred and seventeen Timberheads Not much to say about these, a little chamfering around the tops and ensuring that those flanking the gunports are vertical, and the others line-up. 3008 The much larger tops of the two knightheads or Bollards either side of the Bowsprit opening are the tricky ones. 3011 These need to be positioned accurately and appear vertical from all angles. 3009 The final addition are the snatch blocks for the Cat tackle. I added a sheave for these, cut from a slice of 3mm ø dowel. 3018 3027 3028 A little light sanding, a re-coat and they should be good to go. B.E. 13/12/2023
- 648 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Sixteen Completing the Headworks Gluing the Main rails in place is always a critical business. 2971 I fitted the Starboard side first which went on without issue, the pieces held using pva and sectioning clips. 2980 I took the precaution of marking the level above the capping rail on the Port side rail to assist fitting. 2978 2975 Always a relief once this part is completed. 2992 I am pleased to see that the level looks good athwartships. Not part of the kit is the Saddle. 2996 This is a section of timber triangular in shape, that spans the Main rails where they converge at the back of the head and effectively ties them together. 2982 For the convenience of the crew I have added two additional seats of ease positioned at the aft end of the gratings adjacent to the False Rail. In the Indy kit the False rail is an integral part of the Main Rail, and contains the Capsquare for the Boomkin. The Headwork construction battle is now over, but I still need to do some tidying up and redo’s on the paintwork, but that I can do at my leisure. B.E. 11/12/2023
- 648 replies
- Indefatigable
- Vanguard Models
Sometimes it is useful to dry test well in advance of actual fitting to avoid any issues that may arise later on. On my build I can see that the angle of the Capsquare will need to be adjusted, and possibly the seats of ease profile modified. B.E.
- 648 replies
- Indefatigable
- Vanguard Models
Thank you Glenn, have you tried the fit of of your Boomkins yet? B.E.
- 648 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Fifteen Main Rails These are the most prominent rail of the Headworks and require careful positioning. The laser cut parts are very nicely done and contain extra length. Accurate trimming is required for a good fit, I removed 11mm from the fore end. 2957 The Main rail should look elegant and I fined down the forward end where it meets the Hair bracket. I also tapered it on the inside as it runs towards the bow. A gentle heat bend was applied to the forward end, forward of the Capsquare, to provide a less stressed fit to the hair Bracket. 2959 A slightly risky business but the bend is very shallow, not much is required. To finish these Pearwood parts, Vallejo Ochre Brown is used for the first coats, followed by my wood dye mix which produces a close match to the Boxwood varnish finish. 2965 The panel detail is black ink. 2966 2968 Dry fitting the rails. As I played around with these rails I noticed that the Capsquare for the boomkins looked close by the seats of ease. This may cause issues with the Boomkin fitting. 2969 Plan sheet 9 shows the Capsquares sitting aft of the seats of ease which would allow a clear line of fitting. All the build photos I’ve seen seem to show the position adjacent to the seats of ease, but no one has reached the stage of fitting Boomkins yet. It will be interesting to see how the other members of the ‘Class of ’23 get on with this fitting. I hope to get the rails fixed in position today but I suspect it may take a while. B.E. 10/12/2023
- 648 replies
- Indefatigable
- Vanguard Models
It doesn’t feel much like fun for me at present but we go thro’ the full gambit of emotions with model building. The excitement of a new project, the boredom of doing repetitive routine elements, the frustration when things go wrong, the elation when things go right, the relief when a tricky element is successfully completed, and the pleasure of a project completed to satisfaction. For me model building is a deeply absorbing activity, the research, the interaction with fellow builders on MSW, the striving for improvement, I couldn’t be without it in my life. ☺️ @ Darius – Thank you, - at present I don’t think I’m doing her justice! but that will pass.🤞 Regards, B.E.
- 648 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Fourteen Headworks (Part Four) The next stage is fettling and dry fitting the gratings over the head timbers. This piece is delicate and needs careful handling, I took the precaution of making a template to get the profile before applying it to the actual part. 2875 2941 ….but I still managed to split it at the weak points during the necessary sanding to fit. 2945 With the aft grating fixed the forward section is added. 2947 The fourth timberhead (nearest the bow) is left as is in the kit scheme but there would be a cross timber atop or aft of this known as the cross-piece of the head, very simple to add. There is also an open space between the third and fourth timber heads which looks unfinished to my eye. A check around indicates that there should be carlings running between the two, which are added using some 0.8mmx1mm pear strip. These are also simply added. The kit contains the makings for the seats of easement for which the hole looked a tad large to my eye, but on checking such details out, Chris has it spot on. 2952 I considered that a ship the size of Indy would have had an extra set of seats fitted, which I intend to add. (I did the same on Sphinx) 2955 2956 I persuaded my Skipper from the Zulu Muirneag to try them our for size, it did cost me a dram.😉 Slàinte, B.E. 08/12/2023
- 648 replies
- Indefatigable
- Vanguard Models
Post One Hundred and thirteen Headworks (Part Three) One of the trickiest parts to get right is the Cathead supporter and I did struggle to get the necessary curve to fay into the Ekeing rail even with Chris’s unique, as far as I know, jig which goes a long way towards resolving the problem of the complex curves involved. Ideally the top of the supporter should be square and centred beneath the Cathead, and curve down to follow exactly the curve of the Ekeing rail. My initial attempts resulted in a mismatch between the two. The problem could be addressed to some extent by bevelling the top of the supporter but there was still an obvious misalignment. I scrapped my first attempts and I re-made the supports using a lamination of three pieces of 1mm stuff. Even so it took a couple of re- shapings in the jig to get a result that just about passed muster. 2890 The Cathead supporter/ekeing rail arrangement on the kit is a simplification. The Supporter in reality, was a separate piece to the ekeing rail and should be fastened close to the hull, with the ekeing fayed into its lower end. 2897 Once fitted, even tho’ superficially it may look ok, blind man on a galloping horse comes to mind, I was not happy with the result. The main issue is that the supporter knee is glued to the Ekeing rather than the hull, resulting in a gap between hull and rail where the Ekeing passes over the upper wale and waist rails, which throw it away from the hull. The manual only indicates removing a small section of rail directly beneath the cathead, and the result is that the supporter is then obviously attached to the rail rather than the hull and not attached to the hull at all at the lower extreme. This made little sense and irritated my eye each time I looked at it. 2900 I needed a re-think, so all my work of the past few days was undone. 2902 Fortunately, the supporter and rail came away without breakage. A contributing factor is that the Ekeing runs atop and almost parallel with the Waist rail rather than cutting it at a more acute angle to run below it as indicated on the plans (both kit and official) My aim is to get the supporter to look as if it is fastened directly to the hull, and to achieve this it is necessary to fine down the waist rail to allow the supporter to sit flush with the hull. The aft side of the supporter is also built up to compensate for the gap between Upper rails and Waist rails. 1584a This modification is still a bit of a fudge but I can now live with it. 2914 1588b 2918 There’s a lot of work left to do on the finish, and getting clean lines on the mouldings is also proving a challenge. I need to wait for better light for detail painting, the light levels in the UK are very poor at present. The Bow saga goes on….. B.E. 07/12/2023
- 648 replies
- Indefatigable
- Vanguard Models
Thanks Dave, I’m not sure having fun is the right term – grim determination more likely.😬 @ Allan - The approach is probably different on a scratch build, you need all the rails etc in order to determine the head timbers. With Indy this has already been determined, but even so it is a good idea not to commit to glue too soon in the process. 🤔 Cheers, B.E.
- 648 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Twelve Headworks (Part Two) With the Head timbers in place the Lower rail can be fitted. These are the ones that run along the slots in the Head timbers to join the Hair bracket at the fore end and the Ekeing rail aft. The kit blurb indicates fitting the decorative cover panels to the head timbers and slotting the rail through them before fitting to the hull. 2851 I prefer to fit the rails on the model and then add the covers. I temporarily fitted the first cover to help hold the rail during positioning. The provided slots do err on the generous side, presumably to allow trouble free access. Some remedial work will be required post fitting. Looking at the manual photos the rail terminates on the Waist rail that runs between the gunports up to the bow. The plans show the rail meeting the ekeing rail which runs just below the termination of the Waist rail. It is almost inevitable to get some variation in position due to the vagaries of individual builds, but with the head timbers in place (not glued) I can test the rail and see how it all pans out. 2866 Fitting the Lower rails is quite a tricky operation, these are delicate parts and I managed to break the tip off one, fortunately the repair held. Cathead completion This involves adding the caps and decorative motif and the cleat for the Cathead stopper. The decorative motif on the cap is a star design neatly laser cut. Ekeing rail This runs from beneath the Cathead to meet the Lower rail just below the previously fitted Waist rail, or in my particular case at the lower edge of the waist rail. 2872 2874 It is a composite of two parts; (inner214) and outer (212/213) I have confirmed with Chris that the inner (214) is a ‘spare’ but could be used to bulk out the Ekeing rail if desired. I believe it did taper in thickness as it runs towards the Lower rail, so I opted to use it, looks better to my eye. 2870 As an aside, David Steel The elements and practice of Naval Artchitecture 1812) is rather scathing about the Ekeing rail. The Ekeing rail at the low part of the supporter under the Cathead is only to continue the shape and fashion of that part, being of no other service. We make this remark because if the supporter was stopd short without an Ekeing, it would be better, as it causes the side timbers to rot, and it commonly appears fair to the eye in but one direction. Not many years later and by the time of the Leda class frigate Trincomalee the Ekeing seems to have been dispensed with. Onto the delights of the Cathead supporter. B.E. 05/12/2023
- 648 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Eleven Painting the Topsides The past couple of days amongst other stuff I have been applying some paint to the hull. I had been keen to get an idea of how my intended scheme was going to look. I am not following the designated scheme with the colour bands following the deck line rather than the sheer, and as a Navy board style depiction, I don’t need to. I have scraped the Boxwood section back to bare wood, the previously coloured w-o-p over English light Oak wood dye had suffered some deterioration over the past few months due to handling during construction. A coat of Vallejo Black/grey has been applied to the topsides. This is the result. 2839 2837 2838 2841 Getting there, but rub-downs and re-coats will be needed to get a finish I’m happy with. The Boxwood will be re-coated using the w-o-p/wood dye combo. B.E. 25/11/2023
- 648 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Ten Headworks (Part One) Along with the stern this is a critical area of a build, that can make or mar a model. Chris has designed some of the best head work set-ups but great care is needed in assembly. Assembly is covered over several separate sections in the blurb but I prefer to have all the parts to hand so I can check and dry fit before I commit to glue. The business starts with attaching the Head timbers to the Gammoning knee which will ultimately fit atop the knee proper. 2808 The Head timbers are made of mdf and look as if they will snap in half should you give them so much as a harsh look; perhaps that is why two sets are provided in the kit. An excellent idea; on my build the spaniel assistant had one part before it hit the ground, and another went floppy so I had to discard it. To allow the Gammoning knee to sit down on the knee proper I found careful sanding and filing was necessary to the knee and base of the head timbers. 2807 I tested each of the four head timbers individually, and then as a set to confirm the fit is good. The largest of the Head timbers (aft) gave me the most trouble as it was initially too close to the hull and decorative mouldings that round the bow. I had to indulge in a little light tweaking to resolve the issue. The Hair bracket comes next, a delicate shaped rail that runs from the Upper cheek to the head. 2813 Below this is the Trail board that contains the Gammoning slot. 2812 To assist location, it is useful to insert a piece of board thro’ the slot when fitting the hair bracket. Finally in this section the Upper and lower cheeks are applied to the bow. 2814 On my build they took a bit of shaping on the aft side to conform to the hull. 2818 Fitting these is a tedious business, I fit the lower pair before the upper. 2819 Once glue is applied there is a frantic check before the glue dries to ensure that they look right from every angle. There’s always that nagging doubt. 🤔 2822 2823 At this point I have modified the building board to allow better access to the Bow area. 2829 I will review my efforts in the cold light of tomorrow morning to see if my eye is still satisfied. As with Sphinx I will not be fitting the wash cants. Aesthetically these baulks of timber spoil the line of the cheeks and wale and they don’t seem to feature on Navy Board style models which is good enough for me. They are in any case quite tricky things to shape without them looking lumpy, and I’m happy to have a ‘get out of Jail free’ card to play. B.E. 22/11/2023
- 648 replies
- Indefatigable
- Vanguard Models
Thank you Allan, I'm fighting the Head works at the moment but once that's done I can give the whole hull a good tidy up before sorting the colour scheme. B.E.
- 648 replies
- Indefatigable
- Vanguard Models
Post One hundred and nine And more fettlin’ This seemed an opportune time to assemble the Catheads and open up the apertures. Only the basic assembly at this stage, finishing will be done later. 2766 2769 The completed Catheads are 6mm square so a fair bit of filing is required to open up the bulwark location. Flat and triangular needle files were used for the purpose. The triple sheaves are patterned on the catheads and require drilling thro’ if they are to be rigged. 2788 The line of the sheave is offset to counter the stive of the Cathead, so that the tackle hangs vertically. A slight round to the faux sheaves improves the look. Back to the stern The decorative mouldings are now fitted around the stern and Qtr galleries. The trick here is to ensure that the upper counter mouldings match up with those of the Qtr galleries and have a neat finish at the corners. Failure to achieve this will certainly catch the eye and detract from the overall look of the model. In working this area position of the model is everything to get the right viewing angle to secure the mouldings. 2772 For me raising the hull at the stern gives me the best approach. 2780 I start with the upper counter rail, followed by the corresponding Qtr gallery rail. 2774 2778 I thought about applying a mitre joint to the corners but opted for a straight butt joint which worked out ok once carefully sanded. Atop the rails a strip is added to create a simple profile. 2791 2793 2802 Fairly satisfied with the run of the rails, but for the present I’m moving onto the Headworks. B.E. 19/11/2023
- 648 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Eight Capping rails. A little more progress but exceedingly slow. I have now added the Capping rails for the waist, along the gangways. 2761 The kit version which were a tad short were replaced with Boxwood versions. 2760 I lined up the inner edge with the Qtr deck and Foc’sle mouldings and shaved the outer edge back to the outer line. 2753 Poop rails were trimmed slightly at the aft end but otherwise fit without issue. 2754 The Qtr deck rails line up accurately, and are fitted as with all the cappings, with the inner edge flush to the bulwark. The tricky ones are the Foc’sle cappings, but even so are not far off the Bow Bulwark shape. 2750 As part of my modifications the rail continues to enclose the bow. 2749 2756 The Bowsprit slips below the rail and Bow Hook to tenon into the step on the deck below. 2751 2759 2758 The fettlin’ continues….. B.E. 16/11/2023
- 648 replies
- Indefatigable
- Vanguard Models
Thanks Theo, there's such a big expanse of hull, and they do add a degree of elegance, and accentuate the beauty of the sheer line. They still need to be fined down a little which is what I'm working on at present. Cheers, B.E.
- 648 replies
- Indefatigable
- Vanguard Models
