Blue Ensign
  1. Post 98 Bobstay and Bowsprit shroud fittings I have decided to add these because the strops are fitted against the stops before those of the Fore Stays. The Bobstays will also be fitted. The kit indicates the use of 3mm deadeyes to secure the Bobstays and Bowsprit shrouds which is an acceptable alternative to hearts. As the smallest hearts I have are 5mm, a tad on the large side, and as I have no appetite to make tiny 3mm hearts, I go with deadeyes of which I have a supply of the Syren 3mm resin versions. Bobstays 4993a These are quite tricky to represent authentically, as they involve served line passing through a hole in the Knee of the head before being spliced to itself, with a Deadeye or heart seized in its bight,with the splice sitting in the top groove of the Deadeye/heart. The now double line is seized together below the deadeye/heart and above the knee of the head. 4997a You sometimes have to get inventive to hold the lines taut for seizing. 4995a 5001a The 3mm deadeyes are tiny things to secure within the served line and look a little overwhelmed in the bight. They also don’t take the 0.30mm line which is the correct scale size for the lanyards. I used 0.1mm line as per the kit plans, but which seems very under size for these important stays. I’m not entirely happy with these and may revisit using slightly larger hearts and lanyards. Jib boom I have decided to include the Jib boom albeit in the inboard position. This allows fitting with a minimal increase in the overall size of the model. 4984a The boom was formed from 4mm square stock. The heel is of octagonal shape with sheave holes for the top ropes. There is also a crupper hole for lashing the boom to the Bowsprit. 4988a 5002a 5004a 5006a B.E. 08/07/2025
  2. Post 97 The Fore stays The stays are made up as per the Mains. I am using Syren 1.14mm line for the Fore stay and Morope 0.80mm line for the Preventer. The Morope has better definition than the kit kit line which otherwise is spot on for scale. (1mm and 0.75mm.) From Steel. Fore stay - 9½” (1.19mm)-13” Heart. (5mm) lanyard 3½”(0.4mm) Collar – 5” (0.63mm) seizing 1” Mouse 3x diameter of stay = 3.6mm An open heart (Syren Resin 5mm) is used for the Fore stay collar, stropped with Syren 0.63mm line. Quite often double strops were used but the hearts have only one groove so for Harpy it is single. 4948a Still a tricky little exercise forming two eyes either end of a 50mm length of served line The heart seizing is also simplified, there is only room for a couple of turns of 0.1mm line. 4963a Fore stay collar in place. 4964a 4968a 4956a I carved the Mouses from dowel. 4967a Fore stay mouse fitted. Fore Preventer stay - 6” (0.75mm) - 10” heart (4mm) Collar – 4”(0.50mm) lanyard 2½”(0.31mm) lashings 1” Mouse 3x diameter of stay = 2.4mm. This is handled in the same way with slightly smaller fittings. 4982a 4981a 4980a 4979a 4975a 4974a Onto the Bobstays…. B.E. 06/07/2025
  3. Post 96 Completing the Fore shrouds. Shrouds are a very fiddly business, and applying the throat seizings is a tedious thing. 4915a I find that using a fine needle helps with the threading of the line between the shroud and its return. 4924a 4921a 4922a The Fore shrouds gave me more trouble than the Mains; I seemed to spend an inordinate amount of time tweaking the shroud length before the Lanyards are eventually tied off. This involved unpicking previously seized upper deadeyes and re-setting. On a model a sloppy line of deadeyes is not a pretty thing. 4930a The next step is the application of the futtock staves. According to Steel these are set as far below the trestletrees as the mast cap rises above. 4931a In reality the staves were of 4” circ served line, but it makes sense to use something more solid for model purposes. I used 0.7mm ø Brass rod served with 0.1mm line. 4932a ‘Quad hands’ are a useful tool for this job, holding the bar steady whilst the outer lashings are applied. 4936a The Futtock staves are a great device for evening out the shrouds, as well as providing the anchor point for the Futtocks and Catharpins. The Fore stays beckon…. B.E. 02/07/2025
  4. Post 95 Main stay. (Part 2) The lower end of the stays have hearts turned in. I am using Syren Resin versions, (6mm) for the Main Stay and (5mm) for the Preventer. The kit provided deadeyes for this purpose are easier to fit than hearts and lanyards, but were an old fashioned option by the time of Harpy. 4901a It is easier to fit the Preventer stay and collar with the Main stay and Fore shrouds out of the way. I had fitted the Preventer stay at this point but found I had fed it incorrectly through the mast top. Annoying when you have spent time doing tiny seizing and fitting of lanyards, but I couldn’t let it stand. 4895a 4897a 4898a Lashing of the Main stay I used Syren 0.45mm line. For the collar 0.88 mm line served with 0.1mm line was used. The tricky part of the collar is forming the eye in one short leg. Main Preventer stay 4904a Stropping the Preventer stay heart. 4905a 4908a 0.3mm line used for the Lanyard. 4909a 4910a I can now attend to the Fore Shrouds. B.E. 27/06/2025
  5. Blue Ensign in his build log has gone into some detail about this. I will probably position the binnacle off to one side and slightly forward of the wheel. I also left the chimney off the cabinet. It made no sense where there is no space for a lamp.🤔 No lamp compartment, no smoke, and no requirement for a chimney. I am looking at making two smaller single cabinets that will stand each side of the wheel. B.E.
  6. The hull looks wonderful Ronald, beautiful work. The lower hull planking is very impressive. B.E.
  7. Post 94 Main stay. (Part 1) The kit plans show a simplified form of the Main/Preventer stays. A more authentic version includes serving of the stay collars including the eye splice through which the stay passes, and a more stylish mouse to replace the kit plastic version. The kit indicates use of deadeyes for securing the stays but I have opted for hearts which were more common during this period. I am using Steel’s tables for an 18-14 gun ship. Mainstay - 10” - 1.26mm - 15” Heart (6mm) Main Preventer Stay - 7” - 0.88mm - 10” Heart (4mm) The kit line dimensions are close to this using 1.3mm line for the Main stay, and 1mm line for the Preventer stay. For the Mainstay I am using Syren 1.37mm line, and for the Preventer 0.88mm line. The lines are stretched under weights to remove the spring before fitting. 4880a The position of the mouse needs to be tested on the model. 4881a 4884a Here the un-dyed Preventer stay serving is apparent, and the ‘weave’ of the mouse shows through. 4889a I have been thinking about the positioning of the stays. The kit arrangement has the Main stay fixed by a collar to the Foremast, and the Preventer stay running above it and beyond it to a collar on the Bowsprit. I have some doubts about this arrangement, generally Mainstays run beyond the foremast to the bow. Steel says that The main Preventer stay is lashed to the Foremast and the Main stay to the Bowsprit chock. Lees comments that the Preventer stay was usually carried above the stay but that on small ships was sometimes carried under it. 4888a Full details of my preparing and fitting of the stays and the related Mouses is fully covered in my Pegasus log, so I won’t repeat it all here. 4883a 4890a 4885a In the case of Harpy I have decided to run the Preventer stay below the Main stay, and reverse the locations of the lashings. Onto the lower end stay fixings. B.E. 25/06/2025
  8. Post 93 Fitting the shrouds. It has been some five years since I last did any shroud rigging and I’m feeling a tad ring rusty, and getting the first shroud rigged took a while, including a full ‘re-do’. 4878a Each pair of shrouds were stretched before fitting. 4828a The first shroud is slightly more awkward due to the thicker ‘served’ line. 4847a My approach is to set the first shroud deadeye (Starboard side) to the distance that suits my eye bearing in mind the norm of around 2-3 times the diameter of a deadeye. The finished space between the deadeyes worked out at 7mm. 4868a The tricky part is getting the shrouds level along the channels. 4872a I prefer to rig the shrouds purely by eye, carefully adjusting the upper deadeye to suit the line as I move along the channel. 4869a Not decided yet whether to dye the round seizings to match the shrouds. 4875a 4877a The next stage is to make up the Main stays which are fitted before I attend to the Fore shrouds. B.E. 23/06/2025
  9. Post 92 Pendents of tackles I have re-visited these as the blocks and seizings looked too heavy to my eye, and as they are fitted before the shrouds, need to be attended to now. I unpicked the seizings and re-used the Pendents. This time I used a 2mm diameter thimble from Chuck’s new Resin range. 4798a 4810a It is quite small but matches the size of 5” suggested by David Antscherl in his FFM Book (Vol IV.) The next size up 3mm, looked a tad too large to my eye. I think this range of thimbles will prove very useful for ship modellers. 👍 Gaff and Main Boom This is an opportune time to attach these to the Mainmast, easier before the shrouds are rigged. I used Boxwood parrel beads rather than the shiny black kit versions. 4854a 4855a 4848a These were coloured using Dark oak wood stain. 4843a No rigging for these items but seized together for convenience. I may rig the sheet simply to hold the booms in place. B.E. 21/06/2025
  10. Cheers Guys, lowered topmasts it is. @ Andy - I wasn't thinking of making up the yards but that is certainly an option, thank you. B.E.
  11. Thank you Glenn for your very kind comment, much appreciated. Post 91 Topmast options I’ve yet to decide how to display the Topmasts, so I’ve been having a play around before the shrouds are fitted. The possibilities are: In the usual raised position. 4749a 4751a .. but this is a non starter, I haven’t room for another tall masted model, but she would look beautiful fully rigged. In a lowered position secured by Top ropes. 4755a 4760a 4756a This has the advantage that it doesn’t increase the height very much. Also provides an interesting rigging arrangement. Secured on the Gallows. 4761 4766a The simplest and obvious location for stowing non fitted Topmasts, but tends to obscure somewhat Chris’s beautiful little cutter, particularly if I decided to store Sweeps on the Gallows. With the Cutter atop the masts on the Gallows 4768a 4770a 4771a a recognised arrangement, which on a practical level clears the deck and displays the cutter to the full extent. I don’t need to decide until the shrouds are fitted, but the lowered Topmast position is the one I’m favouring. B.E. 19/06/2025
  12. I have now dipped the pins in a dark oak stain which I think tones them better with the model and provides a range of subtle shades. 4811a An original pin is second from the right. (excuse the working detritus) Working on the thimbles now, modifying the Pendents of tackles, I think they will be 👌 Hard to imagine from even a short time ago such fine detail on items so small. Cheers, Chuck. B.E.
  13. Post 90 Another little packet of wonderments Eights days from order another little packet has arrived from across the pond. Amongst the contents are a supply of Chuck’s new 1:64 scale Resin belay pins. I have been keen to see how these fit Harpy, and you might say I’m highly delighted. 4777a These pins slot into place as if made for the kit, and in an instance have made all other kit provided Belay pins at this scale, obsolete. 4779a These are fitted as supplied without any colouring, but could be darkened if required. On my build they won’t be used for their designed purpose as I’m not rigging her, but they do look good in the racks. 4789a I did do a strength test on the pin and they performed just fine. More likely to pull the rack off the bulwark before the pin breaks. Thanks Chuck, a great job.👍 B.E. 17/06/2025
  14. Post 89 Now for the tricky bit -Topmasts The kit version Topmasts are simplified but will still take some careful work using 6mm dowel. There is tapering and creating the flared hounds, and a clean rectangular head. Accurately shaped topmasts are the most complicated masts to make because they have both square and octagonal lower sections, a tapering round mid-section, rising to flared hounds, and a rectangular head. Additionally sheaves set at a diagonal angle are required in the heel. I do happen to have a couple of topmasts I made earlier during the course of my Pegasus build. These were made to Steel’s specifications, and again by luck closely match the kit sizes. 007 The Topmast drawn out and prepared for shaping on a ‘V’ cradle. Square stock is used throughout, it is easier to round the section between the lower mast cap and the Topmast hounds, than create the non round sections from dowel. 028 The lower section showing the square and octagonal detail and the Top rope sheaves. 029 The head section detailing the hounds. 025 The completed Topmasts. 4744a 4739a I had to adjust them slightly to fit Harpy, the critical area being the fit between the fid hole created by the crosstrees and trestletrees. In reality the Topmast should slide up through this section using the Topropes. The kit has the Topmasts at the same length for both Fore and Main. This follows the Steel table for a 200 ton Brig. 4740a The masts I have used are based on a 300 ton sloop where the Main Topmast is slightly longer by around 12mm. Harpy is a Brig sloop, and in my version I have gone more Sloop than Brig, based on the vessel weight. 4748a As it happens the Fore Topmast matches the Kit plan drawings. The extension at the bottom is the block below the heel, which has the lower Toprope sheaves. Onwards… B.E. 16/06/2025
  15. Post 88 Detailing the Bowsprit I originally thought I would not include the Bowsprit Cap on this build because I knew what modifications would be required to address the kit simplification of this part. On my build the cap would be fully exposed without the distraction of rigging. Although still a tricky exercise it is easier to re-make the cap rather than fiddle with the kit part. The real thing is angled top and bottom to match the Bowsprit stive, and holes cut at an angle to the cap which should be vertical to the waterline. The holes are slightly offset to port to accommodate a Jackstaff on the starbaord side. The kit dimensions are 19.3mm(L) 8.1mm(B) 4mm(thickness) I worked the replacement using Steel as a guide (300 ton sloop) Procedure. The new cap is cut from spare Pearwood fret. I used a length of 15mm wide strip of 3mm Pear. The finished version worked out at 20mm(L) 9mm(B) 3mm(thick) 4702a The holes are marked using the kit piece as a template. The tricky part is deciding on the angle and holding the piece at that angle for drilling. 4701a I used the mill for the purpose of drilling the initial holes that were then progressed using files, maintaining the angle. 4703a 4707a I had to cut the rebate for the Bees with the Bowsprit in place, not ideal but fairly straightforward. 4729a Here a trial fit of all components. The Bees are provided with the slots for the Topmast stays but lack the Bee blocks that should sit beneath them. I added these using small lengths of 2 x 2.5 Pear strip. 4716a 4731a The extra width of the cap allows for the Jack staff which is made from some 2mm dowel reduced to around 1.3mm ø. Blackened, drilled out brass eyes support the staff. 4717a A check is made to ensure that the cap is vertical before the glue sets. 4726a 4730a Onwards… B.E. 14/06/2025
  16. Thank you, Nipper, much appreciated, I do enjoy writing up my log which I do on a daily basis, not entirely altruistic I use it as an aide memoire. I’ve jut looked back to see what I did with the Bowsprit Cap on Pegasus, a good few years ago. It is satisfying to think that my write-ups are a help to others. @ Mark – Glad you are finding this stuff of some use. Cheers, B.E.
  17. Post 87 Lower mast rigging - Part two Fore and Main shrouds I will be using dyed Syren 0.88mmm line for the purpose. 4653a The line lengths are held under tension for a few hours before fitting to take any spring out of them. The shrouds are put over the masthead in pairs starting on the sb side, then working alternate sides. The shrouds are served for the centre section around the masthead and down to the futtocks. The Foremost shroud is usually served overall to counter chafing from the sails. 4679a Once served I attend to the seizing on a dummy masthead and then slip over the real thing. This is much easier than making up the full mast sets off model, and then doing the work with the masts in place. 4682a The shroud is re-dipped in the colouring solution. 4688a When rigging I always work from aft forward so I begin with the Main mast. Fortunately there are an even set of shrouds so on this mast I can avoid the complication of a splice. Fore Mast There are two sets of two and a single spliced shroud that I have fitted over the masthead first. 4684a This foremost shroud, as with the Main shrouds, is served overall. The spliced section needs to be formed first as with the Pendent of tackles. This is a lengthy piece of serving covering 650 mm overall, and as can be seen there is a degree of kink in the line by reason of the serving. 4687a I put this set under weights to even the line out. 4692a 4693a 4694a The shroud sets are all made up; they will now be removed for final fettlin.’ I have been having second thoughts about the Pendents of tackles. I think the 6mm blocks (15”) look a little heavy, and the seizings a little bulky. I have some of Chuck’s new resin thimbles on order, so a replacement set will be made up. B.E. 12/06/2025
  18. Post 86 Lower mast rigging - Part 0ne My approach to rigging. The limited rigging I will apply to this build will be based on Steel tables for a vessel of 18 - 14 guns of 300 -250 tons. The principle rigging will consist of: Pendent of tackles – 7”circ – 15” Single block- 6mm Lower Shrouds - 7”circ – 0.88mm - (5mm Deadeyes) Forestay - 9½” – 1.19mm - 13” Heart. (5mm) Fore Preventer stay - 6” - 0.75mm - 10” heart (4mm) Mainstay - 10” - 1.26mm - 15” Heart (6mm) Main Preventer Stay - 7” - 0.88mm - 10” Heart (4mm) The kit line dimensions are close to this using 1mm line for the shrouds, and 1.3mm line for the stays. The kit indicates use of deadeyes for securing the stays but I have opted for hearts. I begin with the Pendent of tackles, which are omitted from the kit rigging plan, but are an important feature of naval ship rigging. These go over the head before the shrouds are rigged. I covered my approach to making the pendents in my Pegasus build log. They are spliced over the mastheads, and I followed the method described in TFFM book Vol 1V. 4654a 4657a Syren 0.88mm line is served overall with 0.1mm line, I used the kit provided line which is Gütermann Polyester. Steel indicates use of a single block attached to the pendent, but a thimble would also be appropriate, an opportunity perhaps to try out one of Chuck’s new additions to his fittings, a 2mm option would be about right. 4669a 4666a 4674a I used 6mm single blocks, mainly as I had them to hand. 4665a At this time period the pendents extend a little below the Hounds. B.E. 08/06/2025
  19. Thank you Mark, once the seizing is complete I use a scalpel blade to carefully cut the tube and remove it. Regards, B.E.
  20. Post 85 A short post about Long Guns Harpy has two Bow chaser six pounders which I have been thinking about how to display. These are the last two items to be fixed to the deck, ideally done before the masting and shroud rigging begins. I had thoughts of lashing the Long guns inboard, parallel to the ports, but I couldn’t quite decide on the lashing approach, so I took the soft option and positioned them run-out. 4638a The breeching rope is 3 x the gun bore length, using 4” circ line – 0.50mm dia at scale. I actually used Syren 0.63mm ø line. I will only be attaching the Breechings, as I did with the Carronades. For those in mind to attach the side tackles:- Tackles 1½” circ line - 0.20mm ø at scale Rigging blocks single 5/6” size -2mm-2.5mm at scale. 4641a I find it useful to use small sections of tubing to secure the breeching line for addition of the seizings. 4649a I used Morope 0.1mm Polyester line for seizing, it is the finest 0.1mm diameter line I have found. 4647a Quite fiddly to seize the breechings on the model, a better job can be done using an off-model jig. The downside is that it can also be fiddly fitting the bulwark ringbolts with other deck fittings in place, and the guns may have to be fitted at an earlier stage of the build. 4650a Onwards…. B.E. 07/06/2025
  21. Post 84 Completing the masts. The Pin rails and a driver boom saddle are added to the lower mast sections. 4576a Fore mast Pin rail, beautifully cut slots for the pins. 4575a The Pin rail on the Mainmast really needs fitting before adding the lowest ‘iron’ mast band otherwise it won’t slide up to the correct position. The tops which are traditionally painted black down to the hounds, are now attended to. I used Vallejo Black/grey for the purpose. 4570a I love the planking detail Chris has engraved into the tops, I used a slightly thinner mix of paint in this area so as not to obscure the detail. 4579a There are five iron bands spaced equally along the Masthead. For these I used 1mm slices from heat shrink tubing. This gives a subtle shade difference to the painted head. Atop the iron bands are a series of battens designed to protect the rigging from wear. 4581a Kit provided pieces are of 0.6mm strips which I found a little thin to notch over the bands. I replaced these with some slightly thicker strip which allowed a shallow notch to be cut. There are eight of these on each masthead; a small detail the top ends should be sniped to follow practice. Steel also notes that; battens should have rounded edges for the rigging to slide down easily. 4603a Steel also notes that; The afterside of Mizen masts in ships, and mainmasts in brigs, to be coppered in the wear of the gaff and boom. An easy addition using copper tape if so motivated. 4604a 4606a 4607a I now have the overall size of my model version which will require a cover of 30”L x 9” W x 16” H. I can get this organised while I continue with the build. B.E. 04/06/2025
  22. Wonderful stuff you are now producing Chuck, and I think us modellers appreciate the extra mile you go. It has been a great experience using your resin blocks and deadeyes, and the other little detailed fittings. Did you decide whether to produce the Belay pins at 1:64 scale? Regards, B.E.
