Chuck Seiler
Everything posted by Chuck Seiler
  1. No worries. thanks. The posts I have mic out at .508"/12.9mm x 12". Would it fit?
  2. Were you able to determine if the vertical post could be removed/replaced?
  3. Bob, Agree with all. I may check with Larry to see what collar options he has. Alternatively, I may just mount my older corded Dremel (I recently found while cleaning) that is symmetric. But, since one can never have too many tools, I am still eyeing the set--up Gregory is trying out.
  4. I have a Dremel drill press from Vanda-Lay (MSW sponsor). It is a great piece of equipment but is designed for older models of Dremel that were more symmetric. I am having trouble ensuring accurate alignment when I change out the drill. Most times it works fine, but with real precision, even 'a little off' is not good enough.. I got extended posts for my Vanda-Lay press. I believe they are 1/2" diameter. 12mm is .47" That may be an option. Larry at Vanda=lay sells those separately.
  5. If this was made of wood, no problem. Metal is not my forte. Where would one get one? What is the diameter of the post?
  6. The vertical shaft (?) on the original press is only 8.66 inches. At 5.31 inches in height, will this rotary table fit?
  7. Did you attach a vice to it, or s all your work free standing?
  8. TWO WEEKS LATER... Have you had opportunity to use the press more since last posting? Any further revelations?
  9. My error. You mentioned you were working with 1/32" material and my thought was you needed a blade smaller than that. I missed the fact that you wanted to make dadoes...which would have required the 1/32 blade. Personally, I use slotting blades because that is what the saw originally came with. They work for me and I am a creature of habit.
  10. It is coming along nicely. I am about at that stage mow and am studying the plans before I start rigging in earnest. There is at least 1 block assembly that needs to be placed on the mast before the shrouds and forestay are rigged. I don't recall if the rigging plan mentions that. Will you be mounting the sails? I don't plan on sails, myself, and I am trying to figure out how to handle the lines that would normally be attached to the sails...like the one running thru the slot on the mast.
  11. The blade you want will be dependent on your saw. I don't see where you mentioned it. The blade(s) would be dictated by arbor size and how much of the blade will stick up above the table. I have a Byrnes Saw and can use a 1.5 inch blade...maybe even 1 inch. I say that because with 1/32" material you will want a very thin blade but it need not stick up above the table much. The link for MALCO Gregory gave above is where you need to go. I am currently looking at "HIGH SPEED STEEL" "JEWELER"S SLOTTING SAW". Blade # JS114006120 is 1.5 inch diameter and .006 inches thick (.15 mm). There is a large selection to chose from. https://www.malcosaw.com/product/js114006120/
  12. Are they carbide or high speed steel?
  13. A #76 drill bit is .02" and #70 is .028". If those are too small for the chuck, I believe there are mini chucks availabe with 1/8" shaft that can be chucked into the drill, IIRC they go down to 0.
  14. I have seen that when evaluating drill presses, speed and torque are both issues to consider. Determining speed is easy, as it is almost always given. How do you determine torque?
  15. Richard, Well done!!! The Chesapeake Bay Maritime Museum replica has some sort of arrangement to hold the yard next to the mast. I have not fully figured it out yet...I will worry about it as soon as I get close.
  16. My recollection is that Olah's maritime archeologist husband Khorum (sp?) mentioned the yard in his review of the kit.
  17. Welcome aboard and Happy New Year. ~formerly from Warminster, PA
  18. Baltic birch used in model RC aeroplanes. Michael's used to sell it. Hobby shops, wood working stores, Amazon. Great quality. Various thickness down to 1/16", or less.
  19. Richard, Could you post a close up, top down picture of the leeboard/chain connection? I still don't see how being connected only to the interior support post keeps it from flopping around. Did you paint or chemically darken your leeboard iron work?
  20. I've decided that my primary goal is to enjoy the process/enjoy the hobby. My skills improve and I work towards having a masterpiece that will be on somebody's mantle 100 years from now, Meanwhile I have met all sorts of interesting people and can swear in multiple languages.
  21. I would heartily second (3rd and 4th) the above recommendations to NOT do a frigate as your second model unless you DO have the skill set. I have seen way too many CONSTITUTION models started, then donated because the modeler was in way over their head. Most people make mistakes in their early models and learn from those. Frigate models require a much larger investment in money AND time...I would think you would want to be proficient before starting one of these. A half @$$ed SULTANA is one thing. A crappy model you intend as a showpiece is a cow of a different color. Don't dismiss the drudgery of repetitive processes. It is one of the primary reasons models are set aside and never finished. I look forward to what you come up with and will be looking for your build log.
  22. Another valuable lesson learned...if things don't look right, don't be afraid to rip it out and fix the problem. If you try and work around the problem the errors tend to compound. "Ripping" is not the correct verb either. I actually prefer "deconstruct" by soaking the joint with isopropyl alcohol and (when the PVA glue is soft) gently removing it.
  23. Understood, but I would think the water pressure from the boat moving through the water would press it up and back.
  24. I am curious to see how you manage the lee-boards. It seems to me that there is nothing holding them in place except for that chain running over the gunn'l to the support. I am also perplexed by how it is rigged. The lines, blocks and sheaves appear to be used to retract the lee-boards, but there is nothing to deploy them or keep them from being forced up by the water flow. Perhaps I am missing something(s).
  25. I didn't name it, I just reported what was on the tube.
