Everything posted by Landlubber Mike
Nail pusher nightmare
Landlubber Mike replied to Beginner's topic in Modeling tools and Workshop Equipment
Sorry, I just took a look at the picture I posted and that's not the one you should get. You should get the spike insertion plier, which is made for railroad hobbyists: 82839. https://micromark.com/products/spike-insertion-plier?srsltid=AfmBOoq6h4b-crYCTpersqedVh736nmLtl-aoZZ_psiQrbNZzpW_rTtR Unlike the tool I posted below, this one has a narrow slot for the nail head and the vertical slot for the pin shank itself. So, as you are inserting the pin, it is fully supported by the tool. -
I've tried a variety of pin pushers, including the Amati spring loaded one which worked great until it broke. Find yourself a pin insertion plier. It makes inserting pins super easy without needing to pre-drill holes, hammer the pins, etc. For me, I use pins to hold the first planking against the bulkheads while the glue dries. I don't push them all the way in, just push until the tool comes into contact with the plank, and once the glue has dried, I go back in with this plier and pull the pins out. Often times I can re-use the pins. Micromark sold this under #85282. It makes first planking incredibly easy. -
Looks fantastic Glen!! I think the laminated decks help avoid the out of scale planking look that is typical on SIB builds unless you go to extreme measures to try to replicate the deck planks in scale. Unfortunately, I think most decks - generic or ship specific - have those little dots. I think I have this sheet at home from Mk1 Design: https://www.scalemates.com/kits/mk1-design-md-00001-wooden-deck-sheet-a--982896 KA Models also makes a similar deck: https://squadron.com/1-700-ka-models-uncut-wood-deck-sheet-a-05mm/ My guess is that once you add masts and deck items, along with the looking through the glass, the dots will disappear to the naked eye.
I circled back to this one and made some good progress. It's a little tricky for this kit in that although Five Star did a great job making a kit that is a lot more to scale than the Aoshima kit, especially with the included resin and PE parts, the issue is that some of the details are omitted so I've been using the Aoshima kit as a guide to figuring out what I need to add. I painted the hull in the typical IJA camo scheme: Next I glued in the wooden decks that I cut out of a generic 1/700 wooden deck sheet, and I've been adding the various details to the deck including bollards, anchor chains, winches, etc.: Before putting on the flight deck, there's a lot of details that go on these interior decks - pipes, bollards, stairways, platforms for the carried planes and vehicles, etc. I've got most of those all painted up right now, so it's just a matter of figuring out where to place them so that they do not interfere with the supports for the flight deck. Thanks for looking in!
- 40 replies
- Five Star
- Akitsu Maru
1960 Corvette by gsdpic - MFH - 1/12 - Multimedia
Landlubber Mike replied to gsdpic's topic in Non-ship/categorised builds
I bought this kit last year when it came out as this is one of my favorite cars (hope MFH puts out more of these types of non-race cars in the future). I need to get a lot better building car models before I tackle mine, but it will be great to follow along on your build. The kit is definitely impressive in a lot of ways with all the various parts and details. -
Thanks Alan, good to know! Happy New Year my friend!
- 40 replies
- Five Star
- Akitsu Maru
Nice haul! You must have been on Santa's nice list. What do you think of the tweezers? My go-to are the ones from Dumont, but I got one from Anyz that could be a game changer, just will take some getting used to. That rolling tool is nice. I already have one that size (and one bigger) or I would have gotten the Dspiae one.
- 40 replies
- Five Star
- Akitsu Maru
Wow, £20?? That's a very good deal! If it's too intimidating, you can always start out with a less complicated model from AJM or Niko. With your skills, you'll be fine 👍 For resin attached to the blocks, I use a couple of different methods. Side cutters tend to work if the attachment is thin. For larger attachments, I'll use a fine razor saw to saw them off the block and then sand off the remainder. Be very careful if using side cutters as if you don't hold the small part while cutting, it can shoot off into God knows where (don't ask me how I know that). When I saw the dazzle camo from your picture, I had to pick one up. I didn't realize that the British warships had such cool dazzle schemes. AJM has kits of quite a few of them. I missed out on the Ark Royal, but along with the Vindictive, I bought the Jervis Bay and the Argus. Check out the dazzle scheme on the Argus! Will be a lot of fun building the interwar biplanes in 1/700! The good thing is that these 1/700 scale ships don't take as long to build as larger scales, even when you get a detailed PE set. Because I haven't been able to get to my airbrush setup the last week, I've been working on an IJN light cruiser and in a week, have it halfway built already.
- 40 replies
- Five Star
- Akitsu Maru
Thanks Rob! I tend to like the 1/700 scale due to the very wide range of subjects available and just having something smaller on the bench. Personally, I really enjoy the challenge of the PE work. The only tricky thing in this scale is that you have to have very steady hands to do the PE work, and you probably need decent eyesight. On the hands I'm very lucky, but the eyesight is certainly worse than it was five years ago but I've found that using a good light source and magnifiers that I can do a decent job. You're ten times the modeler that I am, so I'd say go for it if you are so inclined!
- 40 replies
- Five Star
- Akitsu Maru
Thanks Andrew! I still am learning but have slowly gotten better model by model. Did you start the HMS Vindictive yet? I bought it and a couple of other AJM Models 1:700 kits when Squadron had a big sale earlier this month. I’m not sure what to think. The hull is beautiful and the instructions didn’t seem too bad. The resin detail parts need some work though, and a lot of the parts all look the same at this scale. My Albatross kit from Niko was much the same, so hopefully it will similarly turn out well in the end. The Polish mixed media kits (AJM, Niko) are very detailed kits with crisp hulls but the resin detail pieces are some of the weaker parts of the kits in my opinion. The Five Star mixed media kits like the Akitsu Maru and Seishu Maru are opposite - very crisp parts (especially the smaller amount of resin details) but less comprehensive (they seem to take shortcuts and I feel like I’m supplementing the kits quite a bit) and instructions are mostly just pictures of the assembled model.
- 40 replies
- Five Star
- Akitsu Maru
Looking really good Alan. You're near the finish line! For the Vallejo water effects products, I was suggesting them mainly because they have colors for the various oceans and seas. I don't know if I'd use those products in a 1/700 diorama setting. I tried using it for my Hannah Ship-in-Bottle build, and I found it was taking forever to dry. That was likely exacerbated by being inside the bottle with little ventilation, but it seems for scale, etc., your approach makes more sense.
