Martin W
About Martin W
  • Gender
    Not Telling
  • Location
    The Litchfield Hills of Connecticut
2,478 profile views
  1. Nicely done, Tim. There are lots of details there to look at and to draw any view into the inticacies of the build. I hope in your new house you find a place where you can admire your work. Cheers, Martin
  2. The two supervisors are doing a good job, because the one working seaman has tied those ratlines nice and neatly. Cheers, Martin
  3. That is some tricky work with lots of problems to solve. Like you, I wish I had taken care of all that very early on, but there's no way of knowing for sure just how everything will line up. The shots of your process show a very handsome build, regardless of all the tooth-grinding you probably went through. Cheers, Martin
  4. Nice work as always, Peter. Your Bosun looks like he's just about to haul the boat up by himself. Even for a strong-looking guy like him that would be a feat! Cheers, Martin
  5. Nice work, Ron. I'm pretty much at the same stage and dreading the task of figuring out/ guessing at the angles of the lower plates. Most of all, I have to admire your clamps. You hint that you made them? Wow! How about giving us some background on those? I have long thought that miniature handscrews would be invaluable in all sorts of situations, and so I would love to see how you fabricated them. Are they beech? ash? Cheers, Martin
  6. Some attractive developments, Ron. Your steps are very neat work, indeed. I like tung oil for lots of applications, but it takes a long time to polymerize if the weather is at all cool, and until it does it serves as a magnet for dust. But there's nothing like it for deepening the natural tones of wood. Cheers, Martin
  7. Well done Ron. I have to admire your determination to work through a problem. To my mind, that's one of the key attractions to model building. Setting up, or designing a jig to get something done is very often the biggest step. But, if you're like me, in 5 months when you have to do something similar you'll look at that those holes and wonder how you ever got them done. Cheers, Martin
  8. Thanks Peter, BE, and Mike. Peter, Winkie is probably a little too good with those small pieces, which go straight into his mouth. I'm not sure how longer screws will work, since I don't know exactly what they would screw into. I'm going to give that a try if I can find some longer screws that are still thin enough. They have to have the length to pass through the base and then into the keel and plywood. BE -- He hasn't encountered any bears . . . yet. He and the turkeys mostly ignore each other, but the herd of deer that passed through our woods a few mornings ago set him off growling and barking for an hour until I took him out and let him sniff their tracks. The Proxxon mill is definitely on my list, along with all the full-sized power tools I really, really need to make my life complete. Thanks for checking in, Mike. The work space is big, but I will probably manage to fill it up all too easily. Photos are on hold for a while, as the charging port on my phone has gone haywire. The repair shop says it might get a part in next week. Meanwhile, I've got the three lower masts shaped, and am finishing the cheeks for the foremast. I'm hoping to get the upper masts done this afternoon and tomorrow, and then I can start on the mast heads. I'm reviewing lots of build logs in hopes of getting the details right. Cheers, Martin
  9. Ahoy Nils -- Sorry to see that you've laid aside your build for a while. I think many of us have faced challenges we'd never expected before -- I've been following the difficulties in Germany with the vaccines, but I hope you & Marianne get yours soon, and that you find your way back to the Zeesboot. Cheers, Martin
  10. Thanks to everyone who clicked "like" -- it's comforting to know I haven't been entirely forgotten. Great to hear from you, BE. I'm with you entirely on having as many electrical outlets as possible: I like to have them no more than 4 ft apart. My plan is to get two circuits wired at 120v (I'm still in the States) with 20 amps apiece to cover all the basic power tools, and two other circuits at 220/240 v dedicated to the saw and dust collector. Right now, though, I'm just trying to get my hand back into the build. Last night I was rooting around in my wood supply and found 2 masts I'd made in Oklahoma. I have no recollection of working on them. One disappointment came a few months ago when I was using my milling machine to cut a small mortise. As I began lowering it for the cut, the turning knob fell off. Then I noticed that the 3 knobs for the X-Y table were also badly bent. Who knows what happened, but I haven't been able to get it working at all. As long as I've had it, it's mostly been the cause of bad language on my part, but it did help with some delicate cuts. I've started looking at the Proxxon mill. Here is my young apprentice, Winkie: I'm off to cut cheeks. Martin
  11. And here I am 8 months later. There was an unbelievable amount of work involved simply in getting the new house organized, and the pandemic hasn't helped. After I got to a point where I could begin to think about modelling again, I had to set up a shop/boatyard somewhere. This house has a large basement and a very large garage, but neither has adequate power. The garage is heated and insulated, it has better light, and in the warm weather I can open the door and let my dog (a rescue who is still afraid of just about everyone) hang out. That became my choice: The workbench I made in the autumn, it's just construction grade lumber but will do the trick for a while at least. I hope that over the next several months you'll see the overall area improve as I paint the walls and figure out something to lay over that hard tool-damaging cement floor. One setback came when I unpacked the Fly. Both it and the Rattlesnake made the trip just fine, but the Fly stayed in its shipping container until just about a month ago. I kept it in the basement thinking that it would be safe from all the jostling and re-arranging we'd been doing. My guess is that the crew who installed the central air system might have bumped into the crate, and the result was that when I carried the crate upstairs I heard a sickening rattling inside. Here's what I saw when I took the top board off: That's a serious list. Luckily, none of the delicate details were damaged -- it was only the keel that snapped off, and I can easily glue that back on, though I doubt I'll be able to use the mounting posts again to display it. Now to work: A few pieces of deck furniture remain to be constructed, but I think it's time to start on the masting and rigging. I have a bag of birch dowels, but they are all too short to serve as masts. So I got some birch from the Lumberyard which I can cut down to narrow square stock for the masts and spars. I've got the foremast shaped, and am now working on the mainmast. Here I'm cutting the area for the cheeks: I'd like to use my Proxxon lathe for these, but I don't have the extension bed, and the main mast anyway is too long for the regular bed. Once I finish the basic shaping of this mast, I'll move on the the mizzen, and then upward. Cheers to all, Martin
  12. Congratulations on a fine build, Jason. As I and others have already said, the quality of your work is most impressive for a first build -- it's even hard to believe that this is your first one! Your photos show off the many nice details that will give viewers lots to look at. You'll definitely want to get some kind of case, or the dust will coat the rigging in no time. Such a beautiful model deserves a proper display. (And if you find a place nearby to help you build a case, let me know!!) I can absolutely agree with you that the journey is the more enjoyable part. Figuring out how to solve the problems posed by each detail is a delight matched only by researching the 18th century when these magnificent ships really did get built and sailed. Do you have plans for the next build? All the best, Martin
  13. Very impressive, Jason. I think there's a good reason this detail gets omitted so much, and that is, as you say, it isn't easy to figure out how to get them done. Your detailed account solves that problem for the rest of us. Many thanks! Cheers, Martin
  14. Nice work on the bands. I always had a bad time with those, as the angle of the timber made fitting anything flat a challenge. You've worked it out well. Cheers, Martin
  15. Your strategy of alternating sounds good, and if I ever manage to get back to work, I plan on following it. Those are nice boats, and they add quite a bit of visual appeal. Cheers, Martin
