Posts posted by Rich.F
Just a small update, I have been reading the manuals, and looking at other build logs to get a idea of whats next on the to do list..
The Lower deck planking between 4 & 12 bulk head, I wanted to make sure that every plank will be the same, (although i'm guessing this part will not really be seen) so I'm going to use this time and space to try out a few/new ideas, I,m going to try tree nails
I made a little jig to cut the 80 mm deck lengths (if this is wrong size please let me know) also made an extra bit if I have the need for 40 mm (half) and then after we had been shopping, a nap and lunch, Lol, I thought of a jig for the tree nails,
I'm happy how this has turned out, and how the few planks I have glued in look, (Will edit picture of this in a few days)
- Shipyard sid, Aussie048, src and 2 others
5
- Bindy, src, jdbradford and 1 other
4
Thanks very much for your kind words of support and help so far,
Hi jerry.
The pictures are well. Fantastic.. they really are...
Hope mine will be half as good.
The following pictures i found last last night on the ""JoTika" Web site,
http://www.jotika-ltd.com/Pages/1024768/Victory_04.htm
Well I Have Started to glue the parts in place, once I have done, ill upload some pictures..
HI David
Thanks for the info, I think from the pictures you provided they don't slant, as much as i think. ill dry fit these over the next day or so. (( If you dont mind leave the post)( Might need to refer to it again, and may be others)..
Tc
- Shipyard sid and maddog33
2
thanks everyone, for likes and comments, very appreciated,
- maddog33, WackoWolf, Shipyard sid and 8 others
11
Hi Sam Great work as normal. yes the cannons look nice as you have them in the picture, not sure is they would have been like that at the time, You have it how you want it
looking great glen, may i ask what primer did you use?
- MarisStella.hr, Aussie048, dafi and 5 others
8
HI Sam, Welcome back, glad you both had a good break, Pictures and build looking great as always,
Hello to all,
Just a small update, I started to paint the areas for the gun ports,, then i ran out of paint..
so I sprayed the area in stead,,
I have installed one side (ATM) of the Gun port patterns, I need a few 3mm brass pins to hold some in place as a few sprung out and needed to be re glued,
Pins should arrive tomorrow, so ill get the other side done over the weekend
Could anyone clarify the supports in the Picture (13), Do these get broken out? hope so, so have i got something wrong?
- MarisStella.hr, Aussie048 and dgbot
3
HI All,
Sam Thanks Very much, last 5 months with is just sat here i have itchy fingers
Brian, That's er yes, a problem, Hence I had to build the conservatory :s
Lawrence. Im also glad, after so long of it just sat there,
Al ready I have sat here while on lunch breaks reading the PDF copy of the manual, A few things to get head round, but thats week/months away..
Weekend been a little busy already, While im on call (Covering) Work has been busy,
- dgbot, Shipyard sid, maddog33 and 2 others
5
Hello Wes, Hello , Welcome and good luck with your build.
Either way, good luck vince,
Hi, I found this, made by Mamoli.
http://www.cornwallmodelboats.co.uk/acatalog/Mv80.html
hope this can help
HMS Victory by Rich.F - FINISHED - Caldercraft - Scale: 1/72
Thanks to everyone that stops by.just a small update, I have finished planking this lower gun deck, I think it looks ok, im not over happy but as your not going to see most of it, im going to rub it down over the next few days as i have noticed a few wood shards,
