Posts posted by Harvey
- canoe21, CaptainSteve and Seventynet
- 3
- Kevin, Seventynet, canoe21 and 1 other
- 4
Hi
Have a look at this
The Marine Art of Geoff Hunt: Master Painter of the Naval World of Nelsonhttp://www.amazon.co.uk/The-Marine-Art-Geoff-Hunt/dp/1844860809
- WackoWolf, J T Lombard, Piet and 2 others
- 5
Hi
have a look at this
3M 471 Blue Fine Line Vinyl Masking Tapehttp://www.amazon.co.uk/Fine-Vinyl-Masking-Painting-Residue/dp/B00CUPL8BI
- Ray1981, thibaultron, Canute and 1 other
- 4
Hi
What masking tape are you using have you tried an anti bleed masking tape.
just a quick thought
- thibaultron, mtaylor, Ray1981 and 1 other
- 4
Hi J
The netting came from one of my daughters old party dresses (when you are a ship builder always on the look out for things to use)
Painted it on a piece of glass with clear mat varnish to stiffen it when dried cut to size and stuck it on with varnish and the rope
hope this helps
- CaptainSteve, gjdale, canoe21 and 2 others
- 5
Hi
Rainbow must have been about 20 years ago I started,but it was put away for 15 Year ish.
When I restarted I ripped the complete inside of the hull out and built it up from there deck by deck see page one of my build log.
Thank you Steve and Mike for your kind words a little encouragement always makes things better.
Hi Mark
I did not splice the served shrouds, Got a shroud marked where the serving should be and served the middle then wraped (Think the correct term is frapped) round to make a loop just big enough to go over the mast here is a picture of one that went very wrong.
Hope this helps if not let me know.
- CaptainSteve and canoe21
- 2
- gjdale, CaptainSteve, Kevin and 2 others
- 5
- CaptainSteve, Seventynet, Kevin and 3 others
- 6
- Kevin, canoe21, Seventynet and 2 others
- 5
HI
Thank you again Grant and captain Steve and GuntherMT for your likes and comments.
Have not done much in the shipyard but I have finished the shrouds and the lanyards, Not totally happy with the lanyards the way I have tied them around the shrouds, so I will leave for a couple of days before I make any decisions, but might redo with a thicker rope and see if it sits any better.
Things must be getting serious because I have glued in the bowsprit, I was leaving as long as possible so the ship was easer to turn on the work bench.
Picture next time when I start to rig it in.
- CaptainSteve, oscarmate, canoe21 and 1 other
- 4
- canoe21, CaptainSteve, gjdale and 2 others
- 5
HMS Victory by Harvey - Corel - scale 1:98
Hi
Thank you Lawrence just about to go up to the ship yard and hopefully finish the ratlines tonight.
