Posts posted by mtdoramike
Absolutely beautiful work. I love the string caulking for the decking.
Mike
Thanks George. Yes, that was the best price hands down that I found for a display case of this magnitude WITH wood base and frames rather than clear view or fish tank look. I don't think people really consider the "after the model situations like displaying such a beast". I knew going in that I wouldn't be keeping the Vic so I had no worries about where to display her. Now, I knew that I would have to get a display case for her and assumed the cost would be $500.00-$600.00 and boy was I wrong. You can make a display case this large for about $600.00 as long as you know that you will more than likely be left with either red oak or some other type of wood readily available at your local lumber yard or home improvement store.
Mike
Well I have the display case on order from Abordage total on the 55 X 40 X 20 (inside measurements) with plexi and mahogany base and frame is like $870.00. I also ordered and received the special name plate from North Country Trophies in WI. total on this was $6.00 for the two inch X four inch brass engraved plate. I will also include a nice binder along with the model and display case, which will give a bio of the real Victory as well as a sequence of events while building the model as well as a list of people and companies that I have dealt with during the build of this model as honorable mention. The name plate is stunning.
Mike
- clearway, GLakie, Dimitris71 and 1 other
- 4
You do realize that a kit is just a kit is just a kit, meaning a kit to a moderate to skilled modeler is only the beginning steps. Once you have the kit and the basics, you can make it your own version of the ship by research, modifications and a little more money, time and a bit more work. If you have the ability, you can buy the Constructo kit and make it into the Amati version and probably will have a lot more fun building it. I really like Constructo kits for the plans, materials especially the wood as well as the price. Yes, some if not most are not totally 100% accurate, but that is something that you can change.
Good luck with which ever you choose.
Mike
I don't blame Micromark for selling items, just like I don't blame ebay for some if not a lot of junk they have listed. It's up to the consumer to do their research BEFORE buying. Typical someone else's fault mentality. I have bought from Micromark in the past and will buy from them in the future.
PS: I just noticed Micromark has the Artesania Latina HMS Victory kit on sale for $499.00 where other places want over $600.00 for it. But I already have that kit, if I didn't I would be all over that like a tic on a hound dog.
Mike
Here is a little update on the Victory ship model Library donation. I stopped by the Library the other day to meet with the head of the Library and to check and measure for placement of the ship model and case. I was asked to do a power point presentation with pictures of the progression of the model build as well as a short biography of the real HMS Victory ship to include as to why I chose the Victory as the subject for the build at the model unvailing. But like I told the Librarian, power pointing was well after my time, so she said they would take care of putting together most of the presentation. I'm also including not only the ship model, but I'm also donating the display case as well as a nice binder with the history of the Victory, history of the building of the model as well as anyone or company that I have dealt with during the build of the model will also get honorable mention as well, which will accompany the model.
I hope to have plenty of pictures and possible a video of the unvailing to post on MSW.
Mike
Birchwood Casey is what I use as well and it works great.
- clearway, Dimitris71, GLakie and 1 other
- 4
hahahahahaha, I did the same as you, but mine in no way came out as nice as your gun ports. Maybe your pencil was sharper than mine.
It's looking beautiful. Those gun ports look perfect. I wish I could cut gun ports that nicely.
Mike
It's looking great so far. Now as far as the supports go, I would just add a little piece of wood to the bottom of each one or use wood filler or putty to fill the small gap until it touches the deck and then paint them. You could even make the pieces of wood a little wider to look like the base of columns to appear to give them more support. I'm not a perfectionist nor a purist. I'm more about function than form, so with that said, I suggest making the attempt at some sort of correction since the supports actually hold up the deck. I always look at painted models as being able to get away with a multitude of sin versus natural wood models, which shows EVERYTHING! Good luck.
Mike
- Eddie and Mike Dowling
- 2
I agree, Model Shipways or Blue Jacket for beginners for sure. You will also have the advantage of quick support from these companies versus other manufactures. My recent Artesania Latina kit was missing several parts, but was eventually replaced by Latina which took well over a month to finally receive. But I have bought other Latina kits in the past without any issues at all.
Mike
- Dimitris71, clearway and GLakie
- 3
Well, my wife would answer with THOUSANDS of dollars because she is always pointing out that it seems every time I go to the store, I buy various types of glue. But I look at it more like how much glue do I use per model and that is any where from $100.00 to $200.00 depending on the size, complexity of the model and how low my stash of glue is getting. I use primarily CA glue and have for the past 15 years on well over 20 or so models and have not had any issues with it. But you must understand the basic principles of using CA glues, like fumes, quick set and the ability to make what ever you are gluing at bit brittle at the joint as well as over bloom. I used to use water based glues on hull and deck planking, but I found that it was very messy and would stain the wood, or would not allow wood stains to penetrate the glue and made the finish very poor. I also have CA fingers most of the time, so I know that I'm in the middle of a build.
Mike
I used some of the HMS Victory wood from the real ship that I received from England to fashion the bitts and the anchor davits from. These will be left natural to show the beauty of the wood. I hope to use more of the wood from the real Victory ship on other parts of the model, but it is VERY brittle and dry.
- msberkman, clearway, Dimitris71 and 1 other
- 4
Wasa by marktiedens - FINISHED - Corel - scale 1:75 (Vasa)
Beautiful work.
Mike
