Posts posted by DaveRow
Update from the Shipyard - Thursday 14th August 2025.
The shipwrights(🤔) needed a break from hull planking.
We decided to move onto the aft sides, top strake, boarded side rails with gun ports.
From the RMG Draft of the Sirius(previous Berwick); not much detail on the side rails other than the height.
Reviewing a number of colour paintings and the Sirius model in the Australian Powerhouse Museum(PM), I adoption the boarded side rails with 3 x Gunports per side.
For me it makes sense the Sirius had solid side rails at the back for protection during the long arduous journey to the other side of the world.
I filled in between the "Long Top Timbers" with balsa wood to provide a solid base to glue the outer side rail boards onto.
I made a jig to hold the bottom & 2 sides of the Gun Ports to make sure all are the same.
Finished Gun Port, ready for the outer boards to go on.
- BANYAN, chris watton, Maxthebuilder and 1 other
4
More progress from the Shipyard - Thursday 7th August 2025.
A bit of a push over last week to get all the 1st layer planks onto the hull has been reached.
I spent a few hours fairing(sanding) the planks today.
I did carry the upper planks too far down the side.
However, for the first layer it's been a good refresher on planking before the 2nd layer of planks.I'm pretty happy with the outcome so far.
Port Bow
Port Stern_Side
Port Stern
Starboard Bow
Starboard Stern_Side
Starboard side
I'll be marking out the Wales & thickstuff's, Sheer Strake, and the Channels next
17 hours ago, alpayed said:
Hi Dave. Sirius had a capstan on both decks (same shaft). Unlike the capstan in my drawing. It probably had the pawls on the lower section. See pic. The pawls on your model need to be moved up so they drop into the ratchet more and probably on the lower section. I am not sure why the ratchet is not shown on the "Berwick" draught Note that they flip over 180deg to allow rotation in either direction.
Here also is G Rapers watercolour of Sirius. there is a lot of detail in it. Also a rigging plan that may be helpful.
Regards Allan.
Excellent.
I did see the capstan was a double one.
I see now, the pawls are not shown on the "Berwick" draft.
I might just take the pawls off the 3D Capstan I made. possibly too much detail anyway.
Thanks for adding the rigging plan - I have similar >> below
On 7/13/2025 at 1:34 PM, mtbediz said:
I hate to say it, but your garboard planks are unfortunately incorrect. They've climbed too high, which will cause plank congestion in the bow later. If you want to plank your ship correctly, remove the garboards now and remake them as shown in the photos. If your ship has a second layer planking, take this into consideration when making the second layer planking. Other than that, everything is going great so far.
I should point out.
The ship model in your pictures, has a finer entry bow.
The HMS Sirius is a Bluff Bow ship. Very similar to the "HMB Endeavour" I build a while ago.
I am trying to match the planking of the article below, which is the actual bluff bow "replica" of the Endeavour.
Even with the replica build; "the Garboard strake has been allowed to creep up the stem, and if this had been kept a little lower they may not have needed as
many dropped planks." (This was noted by a member of the Replica board)Most of my planking to date on my model, follows the natural lay of a plank over the frames.
More progress from the Shipyard.
Slow progress on the 1st layer planking.
Another 3 planks added from the keel. All 6mm wide.
The first 4mm wide plank of 12 has been added, where they go over the curve section of the frame.
As I had not kept the garboard plank shorter, the rest have swung further down.
But being 1st planks, I have learn't.
- mtbediz, Ronald-V and Thukydides
3
Your correct.
I've had a bit of a time to get the following bow planks onto the keel.
The 2nd layer, will be done differently as you have pointed out.
Since last post, more first layer planks have been added to the hull.
And some 3D items in the pipeline.
I've made a start on a few planks against the keel.
Also marked out the lines for the tapering of the planks(in groups of 6)
I'm using 6mm and 4mm wide planks.
4mm where the hull curves most, 6mm on the straighter sections.
I usually pin each plank onto a frame and use plastic clamps, in hope to get the planks butted up neatly.
This doesn't always work, especially where planks are curving a lot. Sandpaper time then...
Here we are transitioning from a run of 6mm to start of 4mm planks - stern port side.
Here we are transitioning from 4mm into 6mm planks - stern starboard side.
The next few pictures are some works in progress on creating 3D Models and Resin Printing.
I'm hopeful that with the right details and finishes, they will look presentable installed on the ship.
Also been testing some paint on the 18 pound Carronade Cannon Base.
Come up pretty good I reckon. Bit more touch up to do underneath(for the beady eyed)
Same for the 18 pound Carronade Barrels.
And the 6 pound Cannon barrels.
Have also developed a 3D Model for a Capstan to print & paint.
And before someone asks, it does not turn - yet !!
See how it turns out.
Well, always more planking to get on with. Dabble with 3D development whilst glue dries.
A bit of an update from the Shipyard.
Since last post of the actual hull, the gun ports have come to light.
The side planking has been brought up level with the upper deck.
The front/bow planking has been raised to where the Gunwale rises from the ships side to the Bowsprit area.
Probably best to return to the hull bottom and finish off the planking(1st layer).
1 of the 12 per side Gun Ports cut into the first planking layer.
Slowly
On 6/28/2025 at 10:19 AM, BANYAN said:
coming on really well Dave, that is some pretty neat planking for a first layer. Interesting reference material also; I may need to have a look at one or two of those also. Which would you recommend as the better (all round) of the two 'First Fleet' books?
cheers
Pat
Re: "The First Fleet" books.
Alan Frost first published 2011
Rob Mundle 2014
They are pretty much the same.
Both tell the story/need for lowering the numbers of convicted/felons in London/England, and the threat of the French establishing a colony/base in the pacific.
Although both books go into the background of the Sirius, previously the Berwick, neither really delves into the finer details of the ship's details.
I preferred Alan's book.
I found the "The Sirius Past & Present" has more details on the Sirius than the other two.
I'm presently into another book "The Investigator" Matthew Flinders voyage from England to circumnavigate/map Australia(as now called) proving it was a Continent.
Reference Materials.
3 books I have read to date, I have tagged relevant details of the ship, attempting to gather as much details as possible of the ship itself.
Much has been written of the journey of the Sirius to Australia(1787), until her ending at Norfolk Island(1790).
Many journals of those on board, accounts of daily life, happening on board and port visits. Not a lot on the actual ship itself(that I have not found to date).
- mtbediz and GrandpaPhil
2
A quick Photo.
I do believe I have neglected to show the plan I purchased of the "Berwick (1781) - Technical Drawing" ZAZ5405 held at the Royal Museums Greenwich.
The plan does show good detail of the hull's starboard side, the upper & mid decks, along with the half frames(to the left), and hull lines at the bottom.
No detail of the Taffrail, gun openings, though just the top edge.
More than adequate to get the hull into shape.
- GrandpaPhil and BANYAN
2
Back in the Shipyard after a cold snap has started in Brisbane.
I have continued to add on more of the first plank layer.
Progress slow, having to pre-bend the "bluff" bow planks, and run then down to side to the stern.
I'm adding 4mm wide planks where the frames curve, wider 6mm planks on the flat'ish areas.
The Bluff Bow. Brings back memories of when I did the same on the Endeavour many moons ago.
Cannot have enough of these little clamps. I use them to hopefully pinch the planks together, ending up with a smooth joint.
If not, some sanding work to do later.
The Transon planked.
I made this little Jig to shape/bend the planks after soaking in hot water, gently bending each around the posts.
Fast forward after a few more planks have been added.
Not all the planks worked out(bend well) on the bow.
Not enough fairing on the frame edges. I'll try better on the next run moving towards the keel.
I/m not going to hide and errors on this build.
Nothing a bit of sanding will fix.
May cut the gun/port holes that have been covered over next.
Bit of a break from planking
- BANYAN, GrandpaPhil and CiscoH
3
On 6/19/2025 at 5:44 PM, shipaholic said:
Hi Dave
Just found this new build of yours. Welcome back to the shipyard.
Have you seen the model of HMS Sirius at the Powerhouse Museum, there are some good photos on their website. Might be of useful reference
I will follow this build with great interest
And later on if you need help with mast and spar dimensions I have a copy of the book "Steele's Elements of Mast making Sail making and Rigging" which is the book that Marquardt referenced when he wrote the Endeavour AOTS
Cheers
Steve
Hi Steve,
Thanks for checking in on the build.
I do have a number of pictures of the HMAS Sirius from the Powerhouse Web Site.
I have Steels "Standing_Running_Rigging 500 Tons 24 Guns TABLES", unless their is another set closer to the tad under 512 tons the HMS Sirius(Berwick) was rated at.
It's another long part-time build for me.
My shipyard had been shut down for a few weeks, whilst I was on holidays.
Not a lot of progress, just a few 1st layer planks to either side of the hull.
The first plank I added was just below the gun ports, aligning the top of the plank level with the bottom of the gun port.
I made up some rods & wingnuts, with a tapered wedge to pull the plank in to get full contact to shape of the frame.
Well that was/is the aim.
Close up of the rod/nuts & wedges, packers, whatever I could lay my hands on to pull the plank flush to the frame/s.
2 planks per side now on.
This is going to take some time..................
- GrandpaPhil, KARAVOKIRIS, ccoyle and 4 others
7
On 5/9/2025 at 5:19 PM, Jim Lad said:
Just caught up with what you're doing here, Dave.
The 'Sirius' is an interesting ship to me as one of my ancestors travelled on her on her last voyage from Sydney to Norfolk Island.
Do you have a copy of 'The Nagle Journal'? A very interesting book and written by an American who was part of the Sirius' crew on the First Fleet voyage.
John
Hi Jim Lad,
Good to see you checking in on my new adventure in the Shipyard.
I do not have "The Nagle Journal". I just had a quick look on the Internet.
Might see if I can pick up a second-hand copy.
I've got a bit of reading/research to do, however another piece of reference does not go astray.
Back in the Shipyard.
Progress has been somewhat slow.
The shipwrights have been crafting the hull portholes for the cannons. 12 per side on the middle deck.
I decided to frame and square off each porthole to aid the location & I'm in no hurry. So why not add extra frames and sill/heads in now.
A view of where the Deck is at, with Hatches framed around, masts holes located, generally looking very straight. The Sirius(Berwick) had a flat upper deck to carry long lengths of timber on the Baltic Trade Route.
I also added in some extra Bow framing to aid in the line of the forward planking. Not faired yet.
Off for a 3 week holiday, so no work on the Sirius for a while.
- KARAVOKIRIS, BANYAN, Thukydides and 1 other
4
Whilst waiting for the 2 Pack Resin to dry on the hull construction(many times).
Research on the MHS Sirius shows some conflict from several sources as to the number and size of guns she carried.
http://www.hmssirius.com.au/the-early-years.html
Refitted as an armed storeship:
The Berwick was purchased by the Navy before she was completed and fitted out as an armed storeship. As Navy property, these types of ships were despatched to various parts of the world for iron, copper, pitch, hemp, tar and timber. Timber was the main cargo carried, which was required to meet the Navy’s immense needs. These storeships had to be armed as prize-takers, pirates and enemy ships also patrolled the shipping routes.
"The Berwick was then refitted. Her hull was coppered to guard against worm infestation which was prevalent in tropical waters, masts and yards replaced, ballast was adjusted to compensate for the addition of guns and accommodation quarters refurbished. The guns recommended were twenty two to twenty four 9-pounders on the middle deck and six 4-pounders and four 18-pound carronades on the upper deck. However it is not known for sure if this particular arrangement was met.
Commissioned as HMS Sirius"
Orders came through in October 1786 for the Berwick to be outfitted for foreign service and she was duly commissioned as HMS Sirius, a 6th Rate ship of the Line. Her status had now changed from armed storeship to armed escort requiring changes to the type and number of guns she carried. It was now set down that she should carry four 6-pounders, six 18-pound carronades and eight swivel guns. It is interesting to note that, officially, carronades did not figure in the ratings so an extra ten six-pounders were put on board(DR Note: stored in the hull ?).
A few sources simply state "When completed she carried 10 guns, four 6-pounder long guns, and six 18-pounder carronades"
Probably work on showing: four 6-pounders, six 18-pound carronades and eight swivel guns
That brings me to what can I do to enhance the detail for this build.
I have been trying my hand in 3D Printing for some months now. mainly small figures for my sons to paint.
Being a design draftsman in my first trade(paid employment), I still like to "design things".
Below are the 2 types of armament mentioned above I have created/printed (still somewhat work in progress)
Will see how they paint up for use on the ship's fit-out.
PS: The 6-pounder cannon was sourced on this Web Site:
Cheers
Dave R
- davyboy, ccoyle, GrandpaPhil and 1 other
4
An update from the Shipyard.
Some more progress on the hull framing, upper deck supports & deck layout.
I've been checking along the way to keep the frames straight, square without any twist.
The top deck: I have added the mast locations, hatches, capstan and a few other notable items/features from the "Berwick" plan.
Where the masts and hatches clashed with frames, I added in beams under the top deck. Bit of an over kill ?, extra strength 🙂
At the stern:
- 8 curved frames added to support the stern cross planking either side of the rudder,
- a "butterfly" extension for the mid deck cabin which extends out either side,
- a "H" frame to tie the top deck to lower deck. this frame will provide a solid foundation for the stern of the ship(windows etc.)
More of this area in future posts.
Cheers
Dave R
- KARAVOKIRIS, BANYAN, davyboy and 3 others
6
Another update to the Shipyard.
I decided to add the Mid Deck in as planned from the cut-out in each of the frames.
This will all me the option to possibly mount a couple of Caronades on this deck !
The ply frames all look a little untidy atm.
I'll sand them up, and apply a sealer to all inner surfaces.
Next to make sure I've got all the work/cuts and surfaces done before the Top Deck goes on.
Cheers
Dave Row
- Thukydides, BANYAN, KARAVOKIRIS and 2 others
5
- KARAVOKIRIS, BANYAN, davyboy and 1 other
4
4 hours ago, BANYAN said:
Hey Dave, great to see you back at it, and with another classic build with particular interest to Australians.
Looking forward tio following your progress. My build is a little stagnant at the moment for various reasons, but I really hope to get back into it this winter.
cheers
Pat
Hello Pat,
Was wondering if any of the "Endeavour Build days" were still plodding along.
Yes! an Iconic Ship, but not much authentic information about.
Still, I will give it my best on the hull.
PS I'll see what you are building in your log. !!
Cheers
Dave Row
The Shipyard has made a little progress.
From the RMG Technical Drawing I created a Keel and frame sections onto paper at 1:60 scale.
These were transferred(glued) onto Ply and in process of cutting out:
- the Keel is cut from 7mm Marine ply.
- the 11 frame sections cut from 4mm & 7mm Marine ply(6 mid ship frames from 7mm ply, 5 bow_stern frames from 4mm ply)
- a few extra frame shapes cut for extra strength to the bow
- still to develop the stern ply shapes.
A lot cutting, sanding, and preparation for squaring all items up on the keel.
More details to follow.
Dave Row
Hello to all the Ship Builder's around the world.
Time for me to drop anchor and build another ship "HMS Sirius" (approval from the Admiral has been gained) after nearly 5 years away from the Shipyard.
This will be my first Scratch build of a wooden ship. The first being a Kit of the HMB Endeavour (build log on this site).
The Sirius has held much interest to me, it is part of the Colonization story of Australia - my birth country.
This ship is going to be somewhat interesting to construct. Details of the ship is lacking, but this does not deter me to take on the task.
To my knowledge, no Kit or AOTS book is available. However, in saying this I have gathered material & information over the past 5 years to which I will refer to during the build process.
The one defining piece of material (which I now have) is the "Berwick (1781) - Technical Drawing" ZAZ5405 held at the Royal Museums Greenwich. The plan, as I was informed: "As far as is known, ZAZ5405 is the only original drawing we hold of the ship you are planning to model".
She was built in 1780 for trade with the Baltic States. She had a displacement of 511 tons.
Originally, she was named the HMS Berwick, an armed store ship, but prior to its departure for NSW she underwent refitting to be a 6th rate at the Deptford Yard and in 1786 renamed the "Sirius" - after the major star in the Southern sky. She carried 16 guns.
Sirius was selected to be the flag ship for the first Fleet (11 ships) - the fleet that carried the troops and convicts to Sydney. She was commanded by Captain John Hunter.
The fleet left Portsmouth on 13 May 1787, and arrived at Port Jackson on 26 January 1788. Sirius carried most if not all of the first fleet's administrators including the Governor Arthur Phillip and Major Robert Ross commander of the marines responsible for guarding the convicts in the colony.
On 19 March 1790 Sirius was wrecked on the reef at Norfolk Island while landing stores. With the settlement still on the brink of starvation this was a major catastrophe as it left the colonists with only one ship.
So, into the shipyard I go.
Dave Row
HMS SIRIUS By DaveRow - Scale 1:60 - POF - as she was fitted out for the "Flagship of the First Fleet" to Australia - 2nd wooden ship build
Hi Steve,
Thanks for looking in on the progress.
Watercolours, paintings, sketches !!
I have several pictures/paintings of the Sirius. All "historical" representations I assume. Between them have 3 versions of bulwarks/rails.
It's similar for "how many guns did she carry on board".
By all references in the books I've read to date, All her "Berwick" guns were removed during the 1786 refit "Her commission stated that the Sirius 'would' be armed with four 6-pounder carriage guns, six 18-pounder carronades & eight swivel guns", a very light armament. "Then on 31 October orders were given to obtain: 10 more 6-pounders to be put on board....". But it was unsure how many actually made it on board as "with respect to the guns, camp equipment, tents etc that were ordered from the Tower,...he[Phillip] had not specified and quantity, therefore I cannot judge what room may remain[on the First Fleet ships]
Bulwarks or Rails !
So back to the rear.
I pondered for some time what to do back there.
I wondered if I was on board for that arduous journey, most of the time out in open waters, what would I prefer on either side whist on watch back on the aft deck area !
However, I wasn't, but went for the Bulwarks anyhow.
