Posts posted by DaveRow
Hi Pat, Slowly getting there.
Shipyard Update:
I moved onto the Anchor Buoys.
First up what it should look like and what to make it/them(2 off) from.
Below pic from the AoTS.
I turned up a 13mm long inner "cork" buoy, from a off-cut of dowel, then lightly stained it.
Made hoops from 0.45mm dia rope(at 1:60 = 27mm dia full size) for top and bottom(to go tightly round the buoy, just on either side of its widest part).
Slings from 4 pieces of rope cut and an eye spliced into the middle.
Left Pic: With some clips and hooks, I managed to create a stable means to attach the sling to the top and tuck under the hoop.
Right Pic: Then invert and same as above.
First attempt: finished Anchor Buoy. In hindsight, maybe should of used a rope 1 size smaller.
Onto making the 2nd one next.
- Fernando E, zappto, BANYAN and 2 others
- 5
Hi Blacky,
Hull coming along very well indeed.
Hi Pat,
I don't know much about how the Etching works.
However, if one can get metal items made from the drawing method, that conjures up a lot of applications.
Thanks for sharing.
PS I am looking forward to seeing the assembled Skylight.
Thanks Rod, Dashi, Fernando, Pat and others recently looking in on the build log.
Shipyard Update:
Slowly been working away tidying up the loose rope ends, esp. the ones the deck.
Main and Fore Course Sheets
As a distraction, started on the Sheets and Tacks to the lower sails. Added them in loose to see how they run.
Since I am not adding sails, will still show the sheets, tacks in place hoisted up with the the Clew Garnets.
A couple of starter pics, details of the sheet ends and blocks(to EyeBolt, Bumkin, Main Corse Sheet return block):
Sheet and Tack coupled to Fore Clew Garnet Block. Fore Sheet start from the EyeBolt back through the port fairlead/block
Below: ForeMast Sheet and Tack to the Clew Garnet
Below: MainMast Sheet and Tack to the Clew Garnet.
Starboard side sheets I added on last night.
Next is to add the Spiritsail Course Sheet to the 2 clew lines.
Life in the shipyard is always busy, just have to make time to get in there.....
- md1400cs, Beef Wellington, dashi and 1 other
- 4
Hi Pat,
The Skylight looks like it will come up very nice.
Did you draw the 2 sheets of brass pieces up ?
Great details you are creating.
Hi Fernando,
Accidently found your new log.
Have pulled up a chair to follow along.
Shipyard Update:
I've ordered an Acrylic Display Case from a Plastics Company in Brisbane for the baby to reside under soon.
A base needs to be made for the case to slot into and the cradle needs some touching up for the display.
I'll post a picture when the case arrives in the shipyard.
- dashi and Fernando E
- 2
Hi Rod,
Fine job your model has turned out. Nice tip for the Flags.
I received my set a couple of months ago, but not tried to attach, set yet. Another task on the list.
Here's to a new year and modelling.
Shipyard Update:
The ongoing rolling up of the Rope Ends.
This task(s) is taking some time to get through.
Below the Stb. Fore Mast area. 12 rope ends alone in this area.
Below the Port ForeMast Shrouds area.
Stb. ForeMast Shrouds. I use several ways to tie the rope ends into a loop. This way using a cranked set of tweezers, holds the rope loop(coated in 50/50 pva/water) whilst it dries to form the oval loop shape. After I tie it up onto the shroud, ratlines.
Many more to move onto.
- dashi, Fernando E, BANYAN and 2 others
- 5
Shipyard Update:
Mizzen Mast
Starting to clear up the loose rope ends.
Port Side:
Starboard Side:
- dashi, Beef Wellington, md1400cs and 3 others
- 6
Shipyard Update:
Mizzen Topsail Clew and Sheets
A small step to get back into things for the shipyard.
Took me a while to work out where I was at with the Rigging - after 2months away from the Yard.
One rigging item I noticed was the Mizzen Topsail Clews and Sheets needed doing.
So there is a set either side of the Mizzen for the Topsail Clew(bottom corner of the sail) to attach to, allowing the sail to be furled up(Clew) and pulled down(Sheet). Well I am nearly 99% that is how it works.
Below is the Port side setup, notation in the picture folks. Top Yard being the Topsail Yard, lower the Crossjack Yard.
A close up at the end of the Crossjack Yard.
The Clew after coming down from the Topsail Yard - position "98" as per Mr Marquardt AoTS. page 120/121.
And below the bottom of the mizzen, Sheet tied to a cleat. Position "102" as per Mr Marquardt AoTS. page 120/121.
And now I notice I have not left much length in the tail ends of the ropes to roll up.
- rvchima, md1400cs, Beef Wellington and 3 others
- 6
On 12/6/2018 at 6:07 AM, rvchima said:
Pat,
I've been through the AOTS book many times now and completely overlooked the deck plan on pages 120-121, maybe because it's sandwiched between many pages of sail rigging. That plan will help a lot, but I'm afraid to look to see what I've done wrong already. At least the spiritsail yard brace pin 11 isn't used yet.
Rod
Rod,
I PM you a pdf. booklet on the rigging.
Shipyard Update:
I am still alive.
I have what some say, been on "Shore Leave".
Our eldest son got married in late Sept, followed by a 2 week holiday.
Then short stint back home, catching up on the home side of things, and some work.
Then away again for my sister's 60th for a week in early Nov'.
Then back home, where a whole lot of work and jobs to catch up on.
So today I planned to get back into it. However a lot of dust in the air, so don't want to unwrap the boat and get dust over it.
Then I realised, I need to work out where I am at anyhow.
So this log (thank god for the build log) helped out in that regard.
Thank you all for the recent look in's, comments and kind words. Much appreciated.
I hope to shortly bring more pictures of the final end to my build.
Still lots to do though.
And Christmas is nearly upon us. !!🎅
- BANYAN, Fernando E and dashi
- 3
Hi Rod,
The rigging is coming along great guns.
Keep focused captain
- Fernando E and BANYAN
- 2
Shipyard Update:
Leech and Buntline Blocks
I have been slowly working on adding the Leech and Buntlines to the yards.
For the Main & Fore TopSail lines.
Somehow I(someone in the shipyard ?) missed adding the Leech line blocks to the TopSail Yard Double Tye Block.
So instu, I drilled(tunneled) through the top of the block, under the ropes to fit the 2 missing blocks.
Above: Red arrow points to the 2 x 3mm blocks added to each Tye Block(Fore & Main Topsail Yard)
At the same time I found I'd missed the a 4mm double block(Red Arrow) under the Topmast Trestle which picks up the Leech & Buntline ropes from below.
There is 1 per side under the Trestle.
To add the above, I moved the Lift Block(white arrow) back behind the middle arm. The new run of the Lift rope is actually better.
Getting very tight up under the Trestle.
On 9/19/2018 at 11:21 AM, Vinnie said:
Starting to really come together now Dave...and she’s spectacular...will look really good in a nice case somewhere in the house. You mightn’t be game to consider but have you decided whether you will do another boat once this beauty is finished?
Got to negotiate with the Admiral where to display the outcome.
Another Wooden Boat is being considered.
I have one in mind, which from what I have seen to date, has not been built much to detail.
And that is probably because their is not much published detail about her.
Matter of watch this space to keep the Intrigue.
- md1400cs and Fernando E
- 2
28 minutes ago, BANYAN said:
Unless you pointed that out Dave, only the more knowledgeable riggers would have known Looks good and nicely done.
cheers
Pat
True young fella.
I'm looking at the Leech, Buntlines, Sheets etc. to do next, deciding how far do I go on adding more and more rope/s work.
Looking at James Lees and K.M. AoTS a few differences to decide on which way to go.
Probably keep on truck'in along.
Shipyard Update:
Yard Tackle & Yard Tackle Falls
The Main and Fore Mast Yards have a Tackle at the end of each.
K.M's. AoTS has indicated a thimble at the end of the Pendant(# 11 below), which I had prepared many months ago.
I attached a Double block to the thimble, however...
James Lees The Masting & Rigging........ , page 71 states "The Yard Tackle was introduced about 1685 and comprised a pendant spliced to each arm with a long-tackle block spliced into the end. Up to 1706 the pendant was one third the length of the yard length: after 1706 it was one quarter the yard's length. ... The long-tackle block was retained until well into the 19th century and it was 1840 before an ordinary double block was used instead."
Well the shipyard has made a bit of a bungle here and used a double block.
The Tackle Falls as noted in Lees "... comprised the pendant block a single hooked block. It was quiet long........ to lower boats etc. to the water. When not in use the tackle was hooked to the Futtock shrouds and made up along the yards.
The Yard Tackle Tricing Lines(outer and inner) were used to pull the pendant and fall up to the yard. etc...
Fore Mast, Port-side Yard Tackle falls made up along the yard, hooked to the Futtock Shroud(below)
I authorized the yard( ! ) to attach a block to the Futtock to hoist the single hooked block up to the Futtock. This brings it up closer to the Futtock than a Inner Tricing block on the yard - IMHO. The hooked block can be raised/lowered from the deck along with the outer Tricing line.
The Fore Starboard Yard Tackle hanging before the Inner Tricing Line attached.
Outer Tricing attached.
All up not exactly as it probably should be, but works for me and demonstrates the methodology.
REVISION
Update to above Yard Arm Tricing Line Blocks
I've added another Tricing block(red arrow'd below) to the stays - all 4 locations
I had run the Outer Tricing line back through the Clew/Garnet Block(wrong) - Blue arrow'd block below.
The Outer and Inner Tricing lines are belayed to cleats on the first and second shrouds of the Main and For masts. So now have 2 blocks on the stays to hove the Tackle up through blocks on the shrouds, on same shrouds as the cleats below.
The ol' saying "Happy Jan"
Above:
Outer Tricing Line "in Red". I dropped in down below the other inner block to clear the hook block as it comes up.
Inner Tricing Line "in purple" is up near the Futtock for the hook to latch onto.
The angle dangle of the Yard Arm Tackle.
I'm now happy that this all works better and frees up the Clew Block for more ropes/work.
- dashi, Fernando E, rvchima and 2 others
- 5
On 9/14/2018 at 12:02 PM, BANYAN said:
Very neat and good looking rigging Dave. What type of parral beads are you using; the one I used were not so nice and uniform in size and shape?
cheers
Pat
Hi Pat,
I had three beads I had collected over time. Pic. below.
The left is plastic ~3.5mm dia. which I sanded the 2 holes as they had dags on each end. Used on the 2 Main & Fore yards.
The middle is plastic with a largish hole and was shorter than the dia. and I thought not really good for a parral bead. But I did use them on the Mizzen Gaff.
The right was metal 2.5mm which I blackened is spherical and i used for all other smaller parrals. Used on other smaller yards.
Each was consistent in size.
I've since applied a clear varnish to the metal beads(shine them up) and 3D printed on the boat. brings them up a bit, any blemish, I'll take as sign of realistic wear from use. !
I got them from Art Supply stores. I drop into them when I see one, always looking for items to use.
I'll look at for some if you wish... Not expensive.
- Fernando E and GrantGoodale
- 2
HMCSS Victoria 1855 by BANYAN - 1:72
Hi Pat,
Deck fit-out looking seriously good man.
