Everything posted by JSGerson
Scott - Thanks for the praise. Martin - Oh I'm sure there many more little traps like that still to come. I just hope I ketch them early enough so that the "fix" won't be catastrophic.
- 974 replies
- rattlesnake
- mamoli
Very nice. It may be a small, cheap model kit, but it still takes a lot of skill to build right. I wouldn't let the "blotches" on the inside bother you. When was the last time you saw a pristine working boat? It just makes it more realistic. It's not a flaw, it's an attribute! BTW, I like those oarlocks.
- 131 replies
- rattlesnake
- model shipways
Fortunately this meant I only had to cut open a few eye splices and lashings, remove the stay from the mast and re-install them properly once the damage was repaired. I didn’t have to reconstruct the complete stays from scratch. The Fore Stay was completed without and problems (as far as I know) and installed. The Fore Preventer stay will be installed once the bowsprit jib boom is installed.
- 974 replies
- rattlesnake
- mamoli
Fore Stay Back to the remaining stays. The Fore Stay was under construction, i.e., making the mouse, eye splices, and heart when I realized I screwed up on the Mizzen stay, Main stay, and the Main Preventer stays…bigtime. In trying to assemble as much as I could off the model, my lack of experience reared its ugly head only I didn’t recognize it at the time. I had looped the stays to engage the mouse first and then attached them to the mast. The only way that was possible was to thread them through the opening destined for the upper masts. It was just a mind block that this was the opening for the upper mast. There was no way for the upper masts could now fit. Examples of the Mizzen mouse and Main stay:
- 974 replies
- rattlesnake
- mamoli
Scott - I'm blind as a bat. I wear trifocals all the time (wearing glasses since I was 7) and when I work on the model I add a clip-on eye loupe. I've heard all kinds of stories about doing those ratlines and none of them favorable. I still have some work to perform on the bowsprit but after that I will have to take the plunge and work those ratlines. Wish me luck!
- 974 replies
- rattlesnake
- mamoli
The deadeyes were blackened the same way as before and put in place. I have been advised that they should be glued in place but I’ll decide if that is necessary when the rigging is attached.
- 974 replies
- rattlesnake
- mamoli
These deadeyes are now complete. I had to increase the teeth depth on my “knife” which I now understand is technically called a broach and was held by a hand pin vise. I also had to introduce the use of an abrasive cord. The cord was immeasurable useful in its ability to help increase the width of the slots.
- 974 replies
- rattlesnake
- mamoli
I made a similar mistake with the Mizzen mast as well and had to enlarge the top hole. Luckily the mast wedge that I had made covered just about all of the excess hole that was left when the mast was finally seated. Those tops really gave me all kinds of trouble. Yours look quite nice. The ships boat that came with the Mamoli kit was a pre-cut wooden shell and would have worked quite well and appeared to be a lot easier to use than MS's bread & butter version. Even still, I felt like it was cheating to use it since I had made most of the model from scratch once the keel and bulkheads were used. When I found the ship's boat model on Model Expo for $5 I had nothing to lose but try. Bending the ribs is the hardest part as the wood will kink rather then bend. If I could have figured out a way to draw the ribs to make a template, I believe it might have been easier to cut them out of airplane plywood. Sometimes I feel like I should have gotten a commission from Model Expo for the number of sales I inspired. 8-) Jonathan
- 131 replies
- rattlesnake
- model shipways
Martin - Thanks for the warning on loose straps, I'll keep that in mind. Ah yes, the souvenir. There was/is no chance of radioactivity because when I obtained the bar of stainless steel, the power plant was under construction - no nuclear fuel was on site. For those of you who didn't click on the provided Shoreham link, the plant was finally completed and even got up to 5% power for testing but was never commissioned. This was around the time of the 3 Mile Island incident so a lot of people (politicians, anti-nukes, pro-nukes, etc.) took a second and third look at the emergency plans if the plant went operational. They didn't like the evacuation plan. Trying to evacuate the population from Long Island NY is messy at best on a good day, never mind during an emergency. So the fully functional, brand new nuclear power plant never went on line.
- 974 replies
- rattlesnake
- mamoli
Once the “saw” was able to pass through the opening I tested the deadeye again. Success, it fitted! Now I have to do it again 17 more times only this time, I don’t think it will go as quickly as their fabrication. The pictures below show the small deadeye slots as well as the one deadeye that I was able to insert into the top so far.
- 974 replies
- rattlesnake
- mamoli
Before I decided to blacken the straps, I test fitted them to the tops. They didn’t fit into the fine holes I created for them. I was too conservative and made the openings a bit too small. The stems of the straps are about 0.5 mm x 2.0 mm. The strap openings are about 0.5 mm (max) X 1.75 mm (or less). Obviously it would be very simple to fix the openings if the tops were off the model but I can’t remove the tops without disassembling all the rigging I’ve done so far. I don’t have a knife or other tool that can be used widen the width of these very tiny strap slots. So I’ve attempted to make one. Using the excess tail of a completed strap, I’ve filed it down to the proper dimensions and then tapered one end so it could at least fit part way into the hole. In addition I filed some notches on one side to act as saw teeth which you can barely see in the image below. This is a fragile copper and silver solder tool (to be held with a pair of pliers) bends quite easy if not held just right. Using a hand drill to act as a rudimentary file, I moved the drill up and down against one end of the strap slot. This slowly made the hole longer. Using my homemade “saw” ensured the cut was straight.
- 974 replies
- rattlesnake
- mamoli
Well, I’ve completed all 18 deadeye straps except for the blackening process. Once I got into the routine, I reduced the time to create one from a half hour to ten minutes or less and they got better. Practice makes perfect. But there is a problem.
- 974 replies
- rattlesnake
- mamoli
My, you've been busy! You are moving right along which I can't say for myself. She's going to be a fine model.
- 264 replies
- rattlesnake
- model shipways
The whole assemble was given a blacken bath and water rinse which didn’t affect the wooden deadeye. Now all I have to do is make 17 more without going crazy.
- 974 replies
- rattlesnake
- mamoli
Once the deadeye was positioned, the wire was squeezed closed. When installed into the top, the unsoldered area will be covered by the top and secured closed by the small opening. The tail was then trimmed to length and a 1 mm hole was drilled at the end of the tail for the hook connection.
- 974 replies
- rattlesnake
- mamoli
After a couple of attempts, I was able to solder the legs together yet leave enough unsolder so that I could pry the opening wide enough insert the deadeye.
- 974 replies
- rattlesnake
- mamoli
The deadeye was removed and the wire was then given its acid cleaning bath and water rinse. The wire was then placed on a very simplistic jig consisting of three pins and a 3-pound hunka-chunk of nuclear grade stainless steel…scrap (approx. 1” square x 6 inches). This was my souvenir that I liberated from a scrap heap at the now brand new, never used, decommissioned Shoreham nuclear power plant on Long Island NY were I was a Nuclear Quality Control Inspector back in the late 70’s. But that is another story (see link). The metal chunk kept the wire tail flat and butt-up together while silver soldering.
- 974 replies
- rattlesnake
- mamoli
I finally worked out this method: First I had to sand the strip of wire I was to use to remove its protective coating. That coating would prevent blackening. Then I bent the wire around the deadeye to give the general shape.
- 974 replies
- rattlesnake
- mamoli
Fighting Top Deadeyes I decided at this point I had better install the deadeyes and straps on the fighting tops before I introduce any more rigging to the masts and make my life more difficult. I had the foresight to install the blocks on the tops before they were installed but in my enthusiasm to start the rigging, I neglected to install the deadeyes and straps as well. When creating the tops, I tried to follow as closely to the plans as I could, maybe too close. I made the openings for the deadeye straps quite small about 1 x 2 mm. I quickly realized that I could not increase the openings now that they were on the model. After numerous attempts to create a strap that would embrace the deadeye and fit through the opening, I had to discard any idea of making a loop at the bottom of the strap for the hook connection, discard the idea of using a larger gauge of wire bigger than 0.5 mm even though I thought that would look better, and finally any idea that this would be easy. The wire I ended up using was 0.5mm “beading wire” (the pkg. did not state its metallic composition). I could not find brass wire at the Hobby Lobby in my town, the only hobby store around.
- 974 replies
- rattlesnake
- mamoli
- 974 replies
- rattlesnake
- mamoli
At the other end a large heart had to be installed on the line as well as the deck anchor ring. The kit provided metal hearts that had to be painted or blackened. Since I had come this far making my own, I made these as well. Starting with stock boxwood of the proper size, I drew the outline of the hearts and drilled and filed out the centers. Once completed, I stained them a darkish wood color.
- 974 replies
- rattlesnake
- mamoli
Main Stay Basically the Main Stay is made the same way as previous stays except the line is thicker (1.2mm). This required a larger mouse. My previous method would not work well at this dimension so this time used the cone method. A piece of dowel was first drilled with a hole that I could thread the line through. Then using hand files, the dowel was tapered at one end right down to the opening and painted flat black. The line itself was sized where it was to wrap around the mast as well as where it would rub against the foremast. The mouse was threaded on into position and sized into the line. During the sizing process, diluted PVC glue was applied over the mouse sizing to prevent it from slipping off.
- 974 replies
- rattlesnake
- mamoli
Thanks all. I am presently away from the builder's bench for a couple days so it will be a couple of more days before the next installment (not that anyone would notice at my work pace).
- 974 replies
- rattlesnake
- mamoli
Now for the second learning experience; blackening the metal. The is the other thing I’ve never done. I bought the product Blacken-It. From what I read, you are supposed to dilute it. I diluted it 1:1 with water. Before I dropped in the completed assembly including the deck nails, it got a bath in the cleaning acid and a water rinse. I didn’t know what to expect; I was dealing with four different materials: copper, silver solder, brass, and whatever the nails were made of. The result was interesting. Everything got darker although I would say it was not black, more of a dark brown, a deep rust. This, on a ship, would not be surprising. The deck ring was installed in position according to plans.
- 974 replies
- rattlesnake
- mamoli
After drilling and filing out the opening, the full ring was added and two holes were drilled for some planking nails. These nails would become the rivets once installed to the model. The full ring was not soldered closed to enable it to be installed to the deck plate. The open ring seam would be hidden by the half ring.
- 974 replies
- rattlesnake
- mamoli
