72Nova
Everything posted by 72Nova
  1. The rigging has officially commenced, 1st pair of shrouds are on, I used .20mm shroud laid line and 100wt tread for the serving. Scale wise I think looks pretty good. Michael D.
  2. With the modifications to the beakhead bulkhead nearing completion, this is the final test fit of the bowsprit, once the eyes for the bowsprit shrouds are fitted and the sprit sail mast rigged, it'll be glued in. Cheers. Michael D.
  3. Dressing out the bowsprit is completed with the addition of the eye bolts for the horses, I will follow Lee's explanation and use two horses. My initial plan was to install the spritsail topmast yard brace blocks on the bowsprit, but they were used later on so I'll follow Paynes plate and run them directly to the range. Currently fabricating new catheads and adding the timberheads to the forecastle rail, still a lot pre fitting left to do before installing it for good, also completed the rudder chains. Michael D.
  4. I've completed one of the pendants, I tried to replicate how their rigged on the Royal George....I know a much later date, but I do love the detail and complexity of it, Overall, I'm happy with it, the rings could be a bit smaller, but geez their already 1.5mm so I'll just run with it. Thanks for stopping by. Michael D.
  5. While the work continues on the beakhead bulkhead the scale chain arrived I had ordered for the rudder. The preliminary mockup is looking good with the pendant still left to do, the chain will be cut and a ring installed at the midway point to accept the hook of the pendant and the other end will be hooked below the gallery, whether or not chain was used, who knows?, but it looks like it belongs. Michael D.
  6. Thank you for likes, they are very much appreciated. I've wrapped up the work on the poop deck, outfitted the Ensign staff with cleats, the truck and final paint, added cleats to the deck and sides for the main braces and mizzen sheet etc. The focus now will be to finish dressing out the bulkhead beakhead, bowsprit and get that assembly installed. Michael D.
  7. The decorations on the lantern are completed, I added the remaining knees, completed the decorations above the galleries and currently working the Ensign staff. The final figures atop the taffrail will be added much later on. Michael D.
  8. Kirill, Your model looks stunning no matter the background, I especially like the last photo. Michael D.
  9. Thanks Michael, I've done somewhat the same in the past using transparent colors and all look good, I was really tempted to do a black background with the gold leafed tulle. Michael D.
  10. Adding the diamond grid to the lantern really brought it to life!!, Aleene's clear gel tacky glue works very well for this, now on to the smaller lanterns. The ladder is just placed there for reference, but actually looks pretty good minus a landing. Michael D.
  11. Kirill I might add the same diamond grid to the lanterns over the existing color I have now and see what it looks like, but as far as opening up the panes?, probably not, yes the large lantern would be possible without much effort, but the gallery lanterns as molded are solid and would require too much effort so this was a compromise. I still need to add the storied ladder, I bet it would hold 10 people after reading about it. The Vander Velde sketch showing the port side ladder leading to the port entry in intriguing also, I recall seeing only one modeller including this in their build. Michael D.
  12. The lantern is about 90% complete, some touch up and repairs still left to do, filled the gap in the deck and fabricated the knees. While not entirely pleased with the look of the lanterns panes, they look presentable, but I might try something else with later. Michael D.
  13. Adding some detail to the lantern and will need to address the gap between the poop deck and taffrail/stern, something I should've caught earlier but oh well and prep the deck for an offset Ensign staff. Michael D.
  14. Thank you, for the gracious compliment's gentlemen. This first attempt in mocking up the rudder coat ended up being the final result, is it what It looked like in reality? who knows, I must say though it really adds a finished look for such a subtle detail. Once I had the tissue paper ready, I worked my around the perimeter using PVA letting each section dry before proceeding. I used a base of red brown and a black wash to achieve a darkened leather appearance. As always thanks for looking. Michael D.
  15. The modifications to the rudder are completed, the shackles are in place awaiting the chain, something in the 30 to 40 LPI should suffice for this scale and contemplating adding the rudder coat, overall happy with the result. Michael D.
  16. Starboard side of the gudgeons are completed, at this point I'm unsure if she carried chains or ropes for the rudder and their arraignment, I'm thinking chains and if so, I'll need to search for some super small scale chain. Cheers. Michael D.
  17. Thank you for the kind comment, Frank. Rudder work continues, I modified the kits rudder by first cutting it away from the hull and then adding the details, the gudgeons are simulated by using .040" rod and .012" styrene, pintles using the same .012" styrene. Michael D.
  18. Thank you, Ian. A majority of the stern work is completed, the gun port lids are installed and added the grid design above the upper glass panes to closely resemble that of the Pett painting, for this I gold leafed tulle as this stood out better than gold paint. Up next, I'll be reworking the rudder before moving back the beak head. As always, I appreciate you all stopping by and taking a peek. Michael D.
  19. Somewhat of a crowning moment having finally glued on the stern and Qtr Galleries, all close gun port lids are on, minus the gun chaser lids and the tedious gilding is ongoing but looking pretty good thus far. Thanks for looking Michael D.
  20. I tend to agree with druxey but your latest attempt looks solid Marc. I used thread to strop my dead eyes on the Vasa, I used thinned down PVA with paint and while still wet I rolled it out on a flat surface with a metal straight edge but a paint stick would work just as well, this seems to hold the fibers in check and the end result looks good. Michael D.
  21. Shifting gears a bit I decided to do a mockup of the canon/ tackles and breech rope, at this scale I simply knotted up the ends and painted to simulate the blocks, looks convincing enough to my eyes for this retina stressing exercise. These close-up shots are great for spotting where touch ups are needed. Thanks for looking. Michael D.
  22. Your craftsmanship is on full display, just fantastic!!👍 Michael D.
  23. The inboard beakhead pin rails are completed along with the range pin rail, 28g brass wire is used for the belaying pins. I did spend a considerable amount of time to mock up the lines if using the gammoning sheave but did not like the run of the lines to the forecastle with the offset bowsprit. I'm still aways from setting the bowsprit assembly in for good but getting closer, while a bit premature I started prepping the Fore and Main stays....76mm and .88mm lines are used. Cheers! Michael D.
  24. Thank you, Kirill. The sprit topmast for the most part is complete minus the necessary blocks etc, I'm quite happy with the result, up next my focus will be set the bowsprit in permanently but first I need to decide if I want to use sheaves secured to the gammoning or pin rails and a range..... looking at both Payne's and Van De Velde plates suggest pinrails as the lines run directly inboard of the beakhead so that's what I'll probably go with. Michael D.
