Piet
Everything posted by Piet
  1. My thanks again to everyone looking in and crowding in my dockyard and your likes!!!! @ Dave: Thanks and yes, it went rather smooth this time. The biggest job was already done, the blades. The rest was a piece of cake - - - so to speak. Practice makes (almost) perfect @ Jan: I'm going to call you Eagle Eye Jan - - - no more Amateur for you my friend And thanks for your confirmation to my fix, it worked out okay and I'm sure my father would give you also a pad on the back. @ Pete48: Thank you. And yes, I'm also rather pleased with how she's turing out. Showed it to my neighbor and she was flabbergasted and almost fall over when I could demonstrate some of the things actually working. Okay folks, this'll be my last post till we have safely arrived in Coraopolis, PA and have set-up the confuser again. No more work on the O19 till after we come back home in hot and sunny Florida on July 8. But then I need to mow the lawn and do some other things like - - - doctor visits to begin the next round of BDG treatments. Y'all hang in and we'll be in touch! Cheers,
  2. Well - - - surprise, surprise, surprise - - - I did manage to get some work done after all. I remade the port propeller and salvaged only three blades, which is okay. So, I remade the hub and cemented the three blades in it, all before lunch. This gave the epoxy time to cure enough so I could repaint the hub and started polishing the blades. It looks okay for me, they all track but still need to be balanced - - - you read John Lad?? I also finished the three blades for the starboard propeller and cut the grooves in it for the blades. They are actually ready to be cemented into the hub but - - - Being busy tomorrow gathering "stuff" to bring with us to PIT, packing and still mowing the lawn I may not have time to log on to MSW. But all yuns can do without me for a while I'll be reading a lot of build logs while with the kids Okay, here are the pics of the three bladed propeller and again my thanks to Jan for this good catch, bravo! This is the photo of the O19 on the ways and close to launch with the three bladed prop clearly visible. It could have spit me in the eye, that close. This shows the remade port propeller with THREE blades this time, looking forward and above. It took me 2 hours to so Another shot looking aft. Taken from the side. Cheers,
  3. Thanks to everyone for visiting and your likes,. WOW, I'm overwhelmed by all your support ! @ Dave: Thank you for your compliment and the best wishes for our trip. Yep, there are a lot of crazies on the road but we'll be vigilant. @ Remco: Yep, I agreed and have kicked myself for such a stupid error. I Had that same photo Jan posted hanging on the wall right before my nose. Stupid is as stupid does No, no, Remco - - I can't make any excuses but you are just too nice trying to cover for me @ Wacko Dave: Thank you dave for your well wishes and yes, we'll try to make it a great time, he is a good kid. @ Mark: Thank you too and we'll be in touch. Cheers,
  4. Thank you all for dropping in and your likes. @ Pete48: Thank you, thank you but did you see jan's comment ?? Yeah the prop came out okay but - - - @ Remco: Thank you as well for the compliment, but I have to remake them @ Jan: Ah yes, eagle eye Jan - - - it's a good thing somebody keeps me straight thank you for spotting it. Yes, of course the prop has only three blades. Here I went assuming again and not checking the photos in my archive. The actual manufacturer's drawings only give me one blade that seems to be centered, making me think it has four blades. I have that picture hanging on the wall as well with a few others but - - - I didn't check Okay, everybody now in unison - domkop Thank you. Okay, enough fun at my expense, now I need to get back to work and redo the props. No biggy, just a minor set-back. That gives me two less blades to make too What is this, two strokes? So I have one more before I'm out I better start paying more attention!! Yeah, it sure looks like a tedious job - loading mines. Gino mentioned to me that dropping them was a nerve racking experience, very noisy and scary. I don't know how much work I'll be able to do in the next few days. Gwen wants to leave at 0600 next Tuesday morning. We are driving up to Pittsburgh, PA to visit our daughter and grandson. 13 hours on the road. I'll take my big iMac with me though so I can stay in touch with all y'all. This'll give me some time with artwork. Cheers,
  5. Magnificent Remco, a real class act. Thinking about it - - - I could use something like it - - - taking orders?? Cheers,
  6. I continued with the port propeller today but didn't quite finish it. I managed fitting all the blades to the hub in relative good position as far as all being at the same distance to the hub and fitting inside the space behind the prop bearing housing. It was now time to cement the blades to the hub. I used the slow cure two part epoxy cement giving me the time to position the blades equally spaced, and being at the same distance to the hub and all tracking the same. For that I used a small steel machinist square and a piece of wood. Hey, sorry but no fancy equipment here and one has to do what one has available that works Of course now Jud expects me to balance them too! I put a small piece of ⅛ tubing in a piece of wood so I can set the prop hub on it. As the cement was curing I performed the final adjustments to the blades and went inside the house to have lunch. After lunch I started cutting out the blades for the starboard prop and scribed the outlines on each peace of copper using the blades from the port prop as templet. I used my tinsnips to cut the material away on the outside of the scribe lines and then sandwiched all them together and clamped them at the root end with a small pair of vicegrip pliers. This way I could see the scribe marks and the contour of the blade ensuring that all will be the same. The rest has to be done on an individual base. It's putting the twist and camber in that's critical. The first thing I do is bend the root into a slight curve as a start for the camber profile. Then I work my way up bending the blade into a slight curve mimicking the camber profile. I then put the blade into my bench vice at the root end end, between two pieces of plastic to not mar the blades, and with a pair of duckbill pliers I bend a twist into the blades. Right now all this is just guesswork by eye. The final shaping comes when I start fitting the blades into the hub. Now I file more of the profile into the blades on the convex side and after I have one blade pretty close to being to my satisfaction I use it as the standard, marked, and place the next blade in top to check the shape of that blade. It may need more or less twist or more or less curve. Adjustments are done with a piece of ¾ inch dowel and a small hammer and the duckbill pliers. As y'all can imagine this takes a lot of time and it doesn't matter wether I have done one already that came out okay, this is a new model to shape. When I'm happy with the twist and curve I use a few fine files to do the final shaping for the blade profile. Polishing will come after the hub is painted and then we can cement the props to the shafts. Well, that's about how I did the port prop and expect the starboard one to work out okay as well, keep fingers crossed. Okay, here are a few pics from today's efforts, hope you enjoy. Here you see the propeller mounted to a small piece of ⅛ inch tubing in a block of wood. I placed a small machinist square next to a blade and rotated the prop to see which blade needs to be adjusted. I lucked out again and all were very close Here I used a small wood strip from the junk pile that was just the right thickness and tracked each blade for their correct tracking position. I already determined that they were all shaped the same so checking in just one location for my purposes was sufficient. Here too I lucked out After the epoxy cement had cured enough I started to clean the blades and made a beginning of polishing the blades and painting the hub red. After the paint had dried I had to put it on the boat - - - of course. I am thrilled at how nice it looks, just like the real boat! Final polishing will be done after the prop is balanced and then given a coat of lacquer to keep the copper bright. This is a cloe-up, using flash. Another close-up without flash. It shows a little more detail. Here is a shot looking alongside the hull aft, using flash. Cheers,
  7. WOW, thanks to all 28 who clicked the like button, I'm overwhelmed by your generosity. @ Pete48: Thank you, and yes, I guess they'll have to suffice. Still working on them. @ Popeye: Thank you my friend for your kind words. Yep, the hardware, lots of work and lots of scrap too - - - well actually not that much @ Carl: Thank you too. It was mainly me who was / am using the whip urging, poking, admonishing myself. I'm like Nenad, talking to the model and myself as well, mostly when I screw up something - - - then it's "domkop," and that's the good word, the others I can't write here on this forum @ Nenad: Yeah, it was and still is a difficult job to make it come out okay. I was really very apprehensive, more like afraid, tackling the props. Had several ideas in how to do them but in the end I decided to make four individual blades and cement them into the hub. You can see the end result in the next post. @ Jud: Thanks Jud and wow, you know about balancing propellers? I'm impressed! Hmmm, do you want me to perform a static as well as a dynamic balance? Okay - - - I'll have to make a balancing rig first though Is this a challenge??? Yeah, I did my share of balancing aircraft props in my repair shop, only static though. Cheers,
  8. Stunning - - - amazing - - - jaw-dropping!!!!! The detail at that scale is beyond belief but we see it!! Keeps us entertained with your masterly work. Cheers,
  9. The going is slow making the propeller blades. I can't use a grinder because it clogs up and they get hot is a second holding with my fingers. No, can't use clamps either, can't see the scribe marks and loose sight of the shape. They are egg shaped and equal on each side of the centerline, the slightest deviation shows up like a sore thumb. But that's okay, I have the time. Nobody is standing behind me with a whip and I get paid by the hour Okay, I re-routed the dingy boom cables first thing this morning. Thanks again Amateur Jan, good catch!! I managed 2 more blades for one of the propellers but they need more work. I purposely made them larger then called for. I'd rather file away metal then having to start over when they turn out too small. You can take away but can't add on metal I also added ⅛ of an inch of wood to the hub to bring the blade field a little more aft. That way I can have slightly longer blades and they won't interfere with the hull and outer dive plane supports. Even so I had to grind away some material on the latter ones. Hopefully I'll have one prop finished by the end of tomorrow. Well, here are a few pics for yuns to view and don't be shy with your constructive criticism This is for Amateur Jan. It shows the corrected rigging of the dingy boom. Now, the load cable is still not running the same as on the drawing because I did not put a pulley below deck in the dingy compartment as it's supposed to be. I had to run it through a hole in the deck on the starboard side of the aft con. I could have put a 3 mm pulley down below but then I would have a problem demonstrating the works because the string would pull with a too large an angle. Remember that this was also an afterthought. If I had planned this from the get go I would have certainly done so. This shows the four semi finished propeller blades loosely stuck in the hub. Here is another shot taken from the front and slightly above. Here we can see just a hint of the profile. The metal was not thick enough to machine the profile in the blades. That would have been a devil of a task to do by hand. For this model's purpose I think this should suffice. Here is another view but more from straight above. Cheers,
  10. Thanks for visiting everybody and your likes, it keeps me motivated. @ John Lad: No fuse yet, we'll have to wait for the rest of the shells. The black powder makers are a little slow too. I need a couple of cases before we can go on war patrol against the many big gun ships that are on the horizon @ Remco: Hmmmm, can't see the profile eh? Well, that's a good thing for me then Actually they do have a little. To make them identical we have borrowed Mobbsy's Merlin No, really, you just stack a few on top of each other and then start filing. It Kinda works out okay but is a slow process that's why I have only been able to get 4 semi finished. No problem for me??? I'm no Merlin But thanks for your confidence in me. Let's wait and see how everything turns out before we brake out the Champagne. @ Dave: You make me blush Thanks so very much for that compliment and no, it's not a kit although many kits going on in MSW are very challenging indeed. Come and visit again, the coffee is always on. As you may have read on my log, this build is in honor of my father. Cheers to all,
  11. Hey Nenad, talking to your model is one of the prerequisites for all modelers. When the model answers that means you and the model are in tune. Next requisite is talking to yourself and of course also answering. Ongoing dialog with model and self keeps the modeler sane, especially with repetitive tasks. I do it all the time, especially when I screw up, then I call myself all kinds of bad things, like "domkop," or "you stupid idiot." Fortunately my wife, the Admiral, is from a seafaring family and knows some about boats and ships. but she does ask very intelligent questions. Now I hope I can answer her and not stumble and make a fool of myself Have fun with the hundreds of copper plates and listen to some good classical uplifting music. We are anxiously awaiting the completed coppered hull. Cheers,
  12. Hoi Freek, now that's totally awesome! Nice job on the helm. Three masts eh. Will they be square rigged or fore and aft? Kidding of course.
  13. Well, let's see - - - what did I do today, oh yeah, drove to the eye doctor for my annual check but it was a no show and had to reschedule it for after the 4th of july. Gwen and I will be in Coraopolis, PA visiting our daughter and grandson for two weeks - - - yippeeee. We are leaving next week Tuesday. Gwen suggested that I bring my big-screen iMac with me then I'll have all the pictures in my archive to show Troy, our grandson. He's totally impressed with his great grandfather and what he's done. I had plenty of time before lunch and started with the propellers. I first made a card dummy prop blade to use as a template. Transferred the outline to my 0.6 mm copper plate with a steel scribe. Then, using my jeweler's coping saw with a metal cutting blade, cut them out. Yep, it's a slow process but using tinsnips would curl the metal too much and I want the curl to be my way, not what the tinsnips give me. After I had the rough pieces in my hand then I used the tinsnips to cut away the parts outside the scribed lines. Then I used a file to file it to the scribed line and cut a small "pins" into the bottom of the blade to assist it in cementing the blades to the hub. I then bend the curved profile in the blades by hand and eyeball. Remco send me a few drawings of the blades and their profile but by using thin copper I cannot actually carve blades to match those on the real boat. However, I think they are shaping up quite nice. I did some extra filing to at least give it some of the profile. I carved four small diagonal grooves in the hub to receive the blades and drilled the holes for the "pins." The hubs are oak and quite hard so I used a small broken drill bit as a router in my Proxxon hand tool which worked great. I try-fitted two blades and it seems to look okay. So far I only made two blades for one propeller, six more to go. The filing left quite a few marks on the copper so I'll have to do some serious dressing and polishing but that's all part of the process and fun. I still need to reduce the length of the blades so there is still a lot of filing yet to do before they fit. Here are a few pics I put for my archive. Enjoy. Here is one of the hubs with two blades. They are already pre-bend into their pitch, there is still some bending and twisting to be done before I'm happy. This gives you an idea of what I am talking about above. I still need to drill the pin holes though. Here I have propped up the hub on a piece of copper tubing and pressed one of the blades in a groove. Cheers.
  14. Thanks to all for looking in and the likes !! @ Jan: Okay, now I see what you are saying. Yes, I reversed the routing . I have been telling everybody - - - me - - - domkop My hat's off to you for tracing the runs, you are one sharp dude and thanks for questioning, it's much appreciated I'll reroute the ropes tomorrow and take new pics. @ Popeye: Thank you very much. @ Vivian: So good to see you here and thanks for your kind words, even though I am a "domkop." Cheers to all,
  15. What I should have added yesterday is one more reason for me having the gantry boom hanging kinda low is that I need to run antenna wires over the top of the gantry. Normally, when loading a torpedo the boom is pulled up to a higher angle, of course, to get a good loading angle on the torpedo. I don't know yet if I'll change things later on to show the torp actually being in the process of sliding into the loading tube below deck. That would really be the cat's meow but then I would also need a bunch of characters on deck handling the operation and that's not in the plans - - - so far But one never knows - - - - - - Today has been very slow in the dockyard. I have been mulling things over to what project / model I should tackle next. I have been procrastinating the propellers for many months now and think it's time to cut the mustard - grab the bull by the horns - and make the props. I'm really a little apprehensive tackling this difficult project. But then again, I have enough copper sheet so I can botch-up a lot of blades. As I was thinking and thinking I made a proto shell for the deck gun. I wanted to see what was involved making a bunch to fight off those large and heavy guns from Sjors and Mobbsy and perhaps a few others who want to do battle I know, they need to be a little smaller and the grenade more pointy but the idea is there. At least I don't have to make powder bags, water mops, stampers and steel balls I have not filled the shell with black powder (yet) so it's still a dummy ((like me )) One thing I see is that I really should use brass for the shell casing, copper won't do. But it's just a prototype. Thanks everyone for visiting and your likes, it's really very encouraging. Here is the prototype deck gun shell standing on the deck next to the loading breech. I still need to add the outlines of that on the gun. This is a plastic boat from my Thermopile clipper kit to hang it temporarily on it's boom. I was tired of seeing a socket wrench hanging off the hook. Cheers,
  16. Bummer Popeye but with your abilities it'll all come out just great. It just takes a little more time but that doesn't alleviate the frustration. Cheers,
  17. Thanks everyone for visiting, your comments and likes @ Remco: Quote - "Is the little diagonal support arm installed on the wrong side? Now the load pulls on the arm instead of compressing it, putting a lot of tension on the bolts keeping it in place." Yes, it's in tension. It's welded to the "skinny" post and bolted to the deck structure below the deck surface. Bolts in sheer are very strong and should pose no problems. From an engineering point of view I'd rather have it in sheer anyhow. This is also in accordance with the drawings. Thus your suggestion is not what I was asking. No price for you. @ Jan: Quote - "The lower 'winch' is rewired in the last pic, compared to previous ones (the cable does not return to the point it started from) . I still don' t quite understand how the systemn works: the upper 'wire has two fixed endpoints, and two fixed points were it connects to that thing in the middle. IN thepic the line is straight, so the boom can't go any lower than now depicted. However, the amount of cable that can 'remocved, by tensioning the lower pulley is very limited, so the upward movement of the boom is also very, very limited. When upward and downward movembet are som limited, what' the use of this constructioj over a rigid boom? Hmmm, rewired or wound differently, could be. That would not alter the operation of the "come-along" ratcheting winch though. Looking at the pics again, the feed cable coming from the "come-along" runs through the small pulley that's Bolted to the lower attach point of that triangular piece and then goes back to the aft side of the "come-along" , which is hooked into that swivel bracket on the top of the post. This allows the boom to move up or down through the action of the "come-along." The cable or chain that runs from the top attach point of the triangular thingy is hooked to the top of the swivel plate that's attached to the top of the post. It's supposed to be a safety cable or most likely a chain. The cable that runs from the triangular gizmo through the large pulley is attached to the top of the post. As we crank the "come-along" or ratcheting crank, one way or the other it allows the boom to move up or down BUT we must first disconnect that "safety" cable or chain. I used a cord for that but it should be a chain so its length can be changed by linking the links at their appropriate position. Y'all know how that can be done with chains, right? Yes, it was very difficult modeling all this to its proper scale and it's indeed impossible to make the movements exactly the same as the original. However, it does not require much up and down movement of the boom. My model of the ratcheting winch is way over scale and that throws everything off. Once the torpedoes were loaded they just unhooked everything and stowed the parts inside the con. The boom itself was secured to a bracket on the deck. The dingy boom I had to rerun the cables because I routed them in the wrong holes in the deck. I didn't retake the pics. Eagle eye John hit that one on the nose but that was not what I was referring to. So, no price for Jan either @ Pete48: Thank you but you didn't take a shot at finding my error @ Jud: Thank you very much. Okay, what I was looking at after the gantry was all completed and tried to load a torpedo I found that the gantry was too far away from the loading tube below deck. I placed the gentry at a position as indicated on the drawings but forgot that I had to extend the access hatches further aft then the drawings show. I installed the loading tube at a to slight of an angle. Therefor my error. So this afternoon I managed to pry the gantry gently loose from the deck without doing any damage I moved it to where the drawings tell me to put it and now I can load torpedoes. As Jan pointed out there is very little movement possible the way my model shows but, as I explained, my "come-along" ratcheting winch is way over scale making my arrangement really not workable. That's the problem with trying to make things workable at this scale. If I had made this ratcheting winch to scale it would have to be a static gizmo of perhaps only 2 mm but then the entire gantry assembly would be static with no movement at all. So, this is the best I could do under the circumstances. This shows the forward gantry in it's now location. I'll have to readjust the winch a little to tighten everything up. I might try making a sling for the torpedo so I hang it on the boom in a loading position. There may have to be some additional rework to the rigging but that'll have to wait till later. Cheers,
  18. Thank, you, thank you, thank you for your likes and visiting my dockyard. All yuns are in my thoughts. Hoi Remco and thank you for that big compliment, I'm overwhelmed and I just wish that all you folks could actually visit and see the real McCoy. Most of the times photos can make errors stand glaringly out and at other times they can make a model look pretty good but I'm thrilled with the way she's taking shape. Even Gwen, with her VERY critical eye, can't find much to critique about, other then some paint touch-ups,she just ask questions on what all those gizmos are and do. The dockyard was closed Friday and Saturday. Yesterday I did a lot of necessary research, some on health and some on other issues. However, I opened the dockyard this morning and felt all your presence so I had to be extra careful in doing things correctly I actually attempted to install all the forward gantry parts and complete it. The attempt was successful, even after having to mow the front yard! And write our daughter a happy daughter's day letter. After everything was completed and tested and admired my handywork, I noticed a grave error!! I won't tell yuns what it is but like to open it as a quiz. The first one who can point it out winds a BIG prize Here are a few pics I took for my archive and add them to this post for your viewing pleasure. This shows most of the parts in a state of assembly to the port-side forward gantry post. The boom elevation "come-along" has a "cable" wound around its drum and that long "cable" end dangling down is the fixed cable for the "come-along" and is fastened to the fwd part where the hook is. The small clothe pin is holding one of the thimbles that is actually in process of being whipped. It'll hook into the swivel plate aft and on up on the gantry post. The "come-along" is also hooked to that swivel plate. The "cable" thats being held by the large clothe pin will be rapped around another thimble with a hook that'll be hooked to that canted part right above the swivel plate brackets. The pics below will show the completed gantry. Here we see the upper "cable" thimble being whipped. A side view of the completed gantry installation. There is a little slack in the come-along but that can be taken out by winding the cable a little bit more on the drum. Okay, I might as well post the question here, can anyone tell what's wrong with this installation? The torpedo is just stuck into the loading tube below deck and may guid you into finding the problem. I had to hang some weight on the boom tackle to keep everything taught. The black line coming out of the deck torpedo opening is to lower and raise torpedoes. In real life this cable goes to an electrically driven drum. Another shot looking aft. Looking forward. Looking straight aft. Don't look at the mess on the build board, just too lazy to keep cleaning things up and still needing some of the stuff. Hey Remco, busier yet!! Cheers,
  19. WOW !! That stack is really looking spiffy Popeye and so is that back cabin. Cheers,
  20. Hello all and thanks for visiting, your comments and likes, it means a lot to me. @ John (Lad): thank you John, yep, the crew was always busy when loading torps and mines but especially when in action against the enemy. @ Wacko Joe: Thanks and you make me laugh. When I posted all them pics I thought about you and Sjors, yuns like plenty of pictures I'm glad you enjoy my build progresses toward completion. @ Amateur Jan: Yep, I have used strands from telephone wires. They are super fine copper wire but in using them in this application prevents me of actually demonstrating the gantries work, they'll be too stiff for that. I should have soaked them in boiling water first. Guess what I'll use for the boat's antenna wires, yep, one single strand. I'll stretch them to harden them and make them stiff to prevent a sag. wait and see. @ Chief Don: Great seeing you here in my dockyard, welcome. Thank you very much for your very kind compliment, coming from you, Kevin and a few other "old" submariners it's especially appreciated. @ Pete48: Thanks agin Pete!!!! @ Carl: Thank you Carl and now you make me blush Well, actually I do have a few more small hand tools and a few other small shop tools but yes, most was all done with small tools and let's not forget the strong fingers Okay, the dockyard was closed today. Had a doctor's appointment to hear the verdict on the bladder biopsies. We are still in limbo on them because of conflicting reports from the lab. The biopsies were send to another lab for a second or third opinion. Wont know for another 10 days. Cheers,
  21. Hi Popeye, well, looks like you have most of your tool problem or the lack there-off, solved Yea, a lathe is great but for model building there are other and cheaper options that work just as well - - - although slower. Do you have an old fashioned coping saw? The one you can put those thin multi teeth teeth per inch in? Okay, I bought a Proxxon jigsaw because I saved-up the money but I could have done the same jobs with my very old coping saw my mom bought for me when I was a young lad. It just takes more time but it can do the job. A lathe? Do you have a ½ inch or ¾ inch electric drill? You can make a neat little lather for wood turning with them. Mount it to a ¾ inch piece of plywood, add a tool rest and you van even add a tailstock. Turning chisels? Some of the Exacto blades can work or a kitchen paring or potato knife can be converted into turning chisels. Did I need a lathe to turn those brass pulleys? No, I could have used that old jigsaw with metal cutting blades. Cut the groves and finish with a file, then cut them off the rod and finish with a fine file. Do you have a drill press? Great, you can make masts and yards, tapered and all. No? Again, the ½ inch or ⅜ inch electric drills cane be used just as effective. Sandpaper and lots of time. A planer for thinning planks? I don't have on, would like one though. I use a small wood plane and files and sandpaper and time. You have time don't you ???? Could I use a mini bench saw? Yes indeed. So far I have been able to use handsaws. Oh, I forgot, I have a Sears bandsaw and a sanding machine, indispensable? Hmmm, they have saved me a lot of time but again, it's all about time and convenience. I have a 10 inch jobbers saw but not used for model building. My wife wanted to make furniture therefore we bought the 10 inch circular saw and the band saw. With the right and self made attachments you can cut planks to less then 1 mm thick. Not to belabor the idea about all those fancy tools and equipment, we can do with a lot less. One thing I would invest in is a Dremmel type tool. That'll be a real asset and a set of mini drill bits. You can make mini router bits from broken drill bits etc, etc. You have a very keen mind Popeye with great ideas and innovation seems to be in your blood, let it fly and the sky is the limit - ooh - pun intended Cheers,
  22. Hello again and today was rather productive and enjoyable. It's nice when things work and fall into place without any snags. Started out in the morning finalizing the parts for the dingy loading boom. I had to install the few 3 mm pulleys in their brackets and secure the pins. Then I made the cable shackles a bit smaller yet to see if the cables still go around them and it worked. I whipped two of the cables that I put around the shackles and secured them with nail polish. So I thought why not assemble the whole blooming thing! It only took about half an hour for the boom and rigging was completed Then I heard some thunder and figured to quickly mow the backyard before the rain. Then I had some lunch, read the mail and ventured back into the garage aka the dockyard. I took a few pics of the assembled loading boom and discovered I had reversed the boom cable and the loading cable, so I quickly re routed them, no prob, done in a few minutes. With the success in making the shackles smaller I now also made the ones for the forward torpedo loading boom smaller and what a difference that makes. I "quickly" whipped the cables around them and prepped a few more parts for the forward boom. By that time the grass was dry enough to finish mowing the southside of the backyard. I don't like to mow when it's whet, I'm using an electric mower and one never knows - - - By that time it was time to call it quits and downloaded the pics and put them in my O19 file. Okay, here are a few pics of todays work. This shows the whipping of one of the shackles. Here are all the parts laid out for the dingy loading boom on top of the drawing. Here is a side view of the dingy loading boom, sorry about the camera movement. A shot from the rear. Looking straight forward through the torpedo loading gantry at the dingy boom. It's getting busy. A close-up of the dingy loading boom. I had to hang some weight on the loading hook to keep the cables taught. A look kinda from above. I had to stand on a small ladder here. Cheers,
