![](https://modelshipworld.com/uploads/set_resources_21/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
ppddry
Posts posted by ppddry
9 hours ago, Mark P said:
Hi Jingyang;
Thank you for your reply. The level of your draughting skill continues to amaze me. I am competent with 2D CAD, but I could never achieve what you make look so straightforward.
To answer your queries:
The taper of the standard as compared to the knee of the head below it is now shown correctly above. However, the shape of the standard needs to be revised. It actually curves upward at its forward end, and is scarphed into a thin, curving extension piece, which extends up behind the figurehead. The upper edges of both the standard and the extension are given a small chamfer.
The rounding over I was referring to is to the timber right at the front of the knee of the head, below the figurehead. This should be virtually semi-circular. The cambered cladding piece which you show attached to the forward edge would not have been made so. Such thin wear pieces are attached lower down, where the leading edge is a hollow curve.
One last point is that the gammoning slot is cut in the head of the gammoning piece, which extends well down, and is the principal timber of the knee of the head. There would not be a horizontal joint below the gammoning slot, curving up as it goes forward. If you can, take a look at one of the excellent practicums by Ed Tosti or David Antscherl; or study a build log here looking for a part of the framing plan showing the knee of the head. They know far more about this than I do, and have illustrated it very well.
Again, if you are already aware of this, and it is just because I am looking at a work still in progress, please accept my apologies.
All the best,
Mark P
Hi Mark,
Thank you very much for your explanation! I deliberated on this very issue during the build.
I read Ed Tosti and David Antscherl's books and was aware of that they shew different configurations for the knee of the head. But since they are of different classes of ships and I did not have the contemporary plans showing the construction of the knee of the head of the Porcupine class of ships, I decided to just follow the plans in the Anatomy of the Ship book. I think I will have to do more research into the contemporary sources before I can further revise this part.
As for the rounding at the front of the knee of the head, I have been trying to maximize it while keeping the width at the top of the timber marked as 5 in plan B2/2 in the AOS book the same as the width of the front face of the timber marked as 1 in the same plan.
Best regards,
Jingyang
On 2017-02-24 at 0:44 PM, Mark P said:
Hi ppddry;
Absolutely wonderful draughting work. The level of detail incorporated is something that would reward many hours of studying your drawings, and there would still be more to find.
One very small point, given by someone who knows he can never equal what you have done here, but I hope you would like to know it, is that the knee of the head tapered forwards, and was much narrower below the figurehead than where it was bolted to the stem, which you show correctly. However, the standard in the head, at the top of the knee, was narrower, and almost parallel sided, and did not follow the taper of the timbers below it, leaving a ledge where the standard sat on the knee. The leading edge in the upper part of the knee was also rounded over, quite noticeably at the top, diminishing to nothing as it went down.
If this has been left as a chamfer deliberately, apologies for raising it before you have finished.
All the best,
Mark P
Hi Mark,
Thank you very much to pointing out the inaccuracy! The following picture shows the standard as of now. It seems that I need to modify it further. Also, do you mean the two light blue edges should be rounded near the stem post but remain sharp near their front end?
Best regards,
Jingyang
- igorcap, PeteB, harvey1847 and 3 others
6
On 2013-08-05 at 9:42 PM, Experiment said:
Brilliant work,
I have been playing around with the idea of doing a similar project with the same plans. I am hoping to construct a 3D model while also actually building the model for real.
I was wondering which drawing from the book you refered to in order to obtain the inner surface for the frames? Is this done from the cross sections in the book of the different frames? Or is their an easier way?
Thank you so much for the help, and the inspirational work.
best regards,
Experiment
Hi Experiment,
Yes, it is done from the cross sections in the book, corrected with the scantlings of the frames listed in The Shipbuilder's Repository. I just sent an reply to your PM.
Best regards,
Jingyang
On 2013-06-14 at 4:29 AM, harvey1847 said:
Absolutly Amazing!
Some pictures look like an authentic witchcraft job...
Do not understand how you change from 2D to 3D. Can you explain us this a little bit. On other thing, Are you able from the model in 3D to get a full set of plans to make her for real? The question might be pretty obvious but I only work in 2D and I´m not familiar with the 3D stuff.
Best wishes Shipwrigt!
Daniel.
Hi Daniel,
Sorry for the VERY late reply
. The process is as follows: firstly the 2D drawings of the frames are imported on to different reference plans in Solidworks, then draw the boundary of the hull surface with the help of other imported 2D drawing curves, finally use the boundary surface feature in Solidworks to construct the hull surface guided by the curves. As can be seem from the pictures below. And Yes, a set of 2D drawings can be generated from the 3D model.
Best regards,
Jingyang
- PeteB, mtaylor and harvey1847
3
On 2013-03-23 at 1:02 PM, Garward said:
Hi, Jingyang!
This HMS "Pandora" in scale 1:48model russian master Narim Majgeldinov is constructed.Your 3D model looks perfectly!Hi Garward! It is a gorgeous model! If I recall correctly this is one of the models that inspired me into undertaking this project
It has been a long time since the last time I visited this website, check the messages (I am very sorry that I did not check them and reply earlier), or updated the model. A lot of things happened over these years, and I had much less time to indulge myself in my hobby than before.
I made small progress on the model over the years, but still far from completion. As can be seem from the attached pictures, the beakhead and bowsprit are completed, with their standing rigging in place. The 6-pr guns are also placed at their ports.
Hi,
your 3D Pandora is outstanding. But be warned ... when it comes to the rigging ;-)
You might have taken notice of mine here:
www.navaltales.de
Rgds,
Stefan
Stefan, your model looks impressive!
I am working on the figurehead now, and it is already quite a struggle, not to mention the rigging ...
Thanks everyone for the good words!
Garward, thank you for providing more details about the Pandora model. That’s the very model that inspired me into doing this 3d build.
Bernard, that’s a great video! I have seen it before, but I still couldn’t help but watched the full 10 minutes of it again.
Tony, it’s alright. My progress is slow so it is good to have something else to fill in the gap.
- BANYAN, mrjimmy, avsjerome2003 and 9 others
12
- Bill Morrison, PeteB, tkay11 and 9 others
12
Hi Tony, Does the software you are using have any surfacing commands like "lofting" or "boundary surface"? Such commands should do the job. The following figures show the process of using the "boundary surface" command in Solidworks to generate the hull form from a set of station lines and some other assisting curves.
Very nice carvings, Igor! And thanks for introducing Sculptris. I will give it a try.
Thank you everyone for the kind words!
Bava, at the beginning I came across this model of the Pandora (It seems that it was built by Woodeater and/or his friends. By the way, does anyone know whether Woodeater has come back to MSW 2.0? It is always a pleasure to see his and his friends’ builds.):
http://www.shipmodels.com.ua/eng/models/elite/pandora/index.htm
http://forum.modelsworld.ru/topic8068.html
I was amazed by the details of this model and decided to build a similar one in 3D, thus this project.
WackoWolf, I worked on this project intermittently and it took me about two years to get to this point. You can do it a lot faster if you draw something everyday.
John, I am looking forward to see your project!
Jingyang
2012-06-05: assembling the stern to the hull, adding the rudder chains
2013-02-11: ladders connecting the lower deck to the upper deck, chain pump winches, iron pillars on the upper deck, shot racks on the upper deck
2013-03-04 to 05: forecastle planking and fittings, quarter deck planking and fittings, catheads, stove, capstan, forecastle planksheer
Incredible work! It shows so much detail of a physical build! Thanks for showing all the interim work to get to the more complete-looking model.
Thank you!
HMS Pandora 1779 in 3D
in CAD and 3D Modelling/Drafting Plans with Software
Hi Mark,
That's a good point! I think I will dig deeper on this. Thank you for pointing it out.
There is another inaccuracy you may notice is that the gammoning loops are not arranged correctly. I tried to draw them in the correct way but the results always look awkward. So I drew them as they are now.
Best regards,
Jingyang
