Everything posted by Kevin Kenny
- 1,127 replies
I relocated the lights on the work bench. They were too far back and did not light up the front of the model. The bench is now perfectly lit.
- 1,127 replies
You have been given a lot of great advice Mango. I have just completed a series of 10 videos that you might find useful if you have the time. They run about 20 minutes each. I have just completed planking a swan class ship . This is the first one in the series. best regards kevin
- 20 replies
- Planking
- Lining out
Greg, Ill try that method on the other side and see how it goes thanks k
- 1,127 replies
- 1,127 replies
- 1,127 replies
- 1,127 replies
I have a Cameron drill press which is the best in class. I got it years ago from Charley files who developed and sold the Preac table saw. Its the second most used tool in my shop after the Byrnes table saw. I also have a beautiful XY vice. It is expensive.
- 9 replies
- Vanda-Lay Industries
- Drill Press
Not sure if it can be done now that you have rigged the ship. But the material of choice is Silk span. Here is my video on it there is another excellent video by Tom Lauria
Strange you should ask. It was only yesterday i found some in the supermarket and purchased three packs. I am now experimenting with them.
- 1,127 replies
I do not find they quarter very well. Is there a special technique or blade to get it to strip all the way down?
- 1,127 replies
- 1,127 replies
This round of treenails is actually 6840. Just to be correct.
- 1,127 replies
Thats exactly what we needed Mark. I have added it to the description of the video.
- 1,127 replies
- 1,127 replies
Greg right now I am using the draw plate with Juniper but experimenting with the needles. I just ordered some 18 gauge needles and have some 20 gauge needles but they quickly clogged up. I will be using the draw plate for this exercise. kevin
- 1,127 replies
I will get my vet to locate them in due course. The ones he gave me produce a treenail size .040 which is just under 2” with a size that says 16 G. The smaller ones i got are 20G so i am hoping to get 17,18,19 and see what size they produce. Ill keep you in the loop. best kevin
- 1,127 replies
I hate using pseudonym, any way. “no idea” have you figured out the various needle sizes that would produce the correct size treenails. in 1/4” scale i am looking for 1”, 1.5” and 1.75”, in imperial measurement that would be .021, .03 & .036 and in metric it would be .56, .78 & .94. once i can confirm these numbers and find a good supplier i would post this data in the video description with the appropriate link. Also, have you figured out the best speed for the drill press. Its quite clear to me that if the speed get above 1000 RPM the needle get to jot. I started lubricating with silicon and it works great. I even sprayed the wood and all the burning stopped. kevin
- 1,127 replies
Stuglo, i assume you are asking about the needles used to make the tree nails. The sharpened point was cut off and the blunt end sharpened evenly. This was used to drill the wood and i was able to fill the blank with 65 holes each having a treenail in it. This took about 2 minutes. Its still early days as these needles cut 2” treenails. I need to get smaller needles before i sign off on this method. In the mean time i am using treenails made on the jim Byrnes draw plate.
- 1,127 replies
It has started. I am using the same wood as I used to plank the model so you should have to look carefully to actually see the tree nails. Just putting these few in i now realize that i am going to be making lots more treenail stock. .
- 1,127 replies
