Posts posted by kees de mol
Very very impressive. Al those parts wich you have handcrafted. I am stunned
Wow, those sails look very wel crafted. You must be a very patient man to do this.
Beautifull build! What is it with Turkey? They build so much nice ships there. Models as well as full scale ships.
Hello Jan,
The white stuff is filler to fill the gap between the straight sections and the upper curved section. I will try to simulate the hull plating but it will be very difficult because I have very little refference material
Well what can I say.
I glued the sections together and added the topsection (wich is curved) and then I wanted to start sanding. But I had a bad feeling about it and started to measure everything again and compared it whit the plans I had. I turned out I had made a big mistake with making the drawings and the sections. The sections where not wide enough, they are arround 2 cm to short. That was a bummer
But in the meantime I recieved (unexpected) a really good lineplan wich I would not have to adjust. So I am still going strong and just started a new build. It will take some time but there will be a new update soon. This time with a good hull with good measurements
Regards, Kees
Very Interesting build this one. Good to see the carbonpaper again, I was forgotten it.
Very nice these details. I wonder what else you will show us
Today I have sawn the mulitple sections of the hull. After this I will glue them together and then it's time for sanding, sanding and more sanding. I keep the lineplan nearby to control myself while sanding and then I will have an accurate hullform.
Regards, Kees
Very clean build. Especially I like your woodcarving and turning.
- PeteB and avsjerome2003
- 2
Shame it went wrong with the ladder but the wooden version is looking better in my opinion.
In post 79 I see some nice clamps (dont know how to call them) Do you know the name of them?
Regards, Kees
I am amazed by how you did the floor of the captains cabin. Very well done
Are you now sure you have it right? Then start building quick and you will soon forget the mistakes. Good luck Veel succes!
Regards Kees
Holiday Harbor by popeye the sailor - 1:20 scale - multi build
You're doing great Popey.
